Question about Singer Sewing Machines
I have a singer 31K 20 that won't pick up the bottom thread can anyone help please?
  • Singer Master
  • 12,515 Answers
Install a brand new needle and confirm it is installed correctly.
Changing thread brands may be helpful. AVOID old or bargain bin threads. Focus on spending a bit more for better quality thread.
If it still does not work, it could be the machine is out of time. Search for sewing machine timing or take it for service.
Posted on May 21, 2017
    Top Expert:
  • Singer Master
  • 51,247 Answers
Adjust te needle thread tension
check the needle /hook timng
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
  • 1788 Answers
SOURCE: I have an old singer sewing machine 401A. The top
You can download a manual for $10 at www.sewingmanuals.com and it should help you. A couple of suggestions though, is your needle inserted correctly? Flat side facing the rear of the machine, fresh needle? Threaded correctly on top and bobbin area? Is your thread good not too old and the same type in bobbin and top? Did you leave a long enough tail in the bobbin thread? 3-4 inches which you hold with your left hand. Is the thread in the bobbin unwinding the right way? Are you turning the handwheel towards you, not away from you at least two revolutions or until you see the thread loop? Try these suggestions, and I am sure one will work unless your timing is off and it needs professional service.
Posted on Sep 20, 2010
tunde007
  • 2382 Answers
SOURCE: My old Singer sewing machine
Hi, try re-timing the machine. Select "straight stitch," then take the bottom off the machine to see underneath the bobbin case area. Open the faceplate and look for two marks on the needle bar around where it enters the machine. Take out the bobbin case to see the hook. Turn the balance wheel toward you so the needle is going down. Stop turning when the needle is just about to start on its way up. The bottom mark on the needle bar should be just about to enter the machine, and the point of the hook should be just above the eye of the needle. If it isn't, tilt the machine backward and loosen the two screws on the vertical gear so you can move the hook to where it should be. Tighten the screws and put everything back so you can test your setup. If it sews a straight stitch correctly, try it on zigzag wide stitch. If it misses one side, repeat the timing process.
Posted on Jan 22, 2011
I received a 221 singer feather light as a gift.... Love using old machines. It will not pick up the bobbin thread. When it cycles the top thread hangs up and breaks.
Lucky you!
First thing to always try is a brand new needle. A lot of sewing machine problems are due to an old, dull, bent needle.
Most likely the machine has been knocked out of time--the needle and hook are out of sync. Search for sewing machine timing or take it or service.
https://singer-featherweight.com/blogs/schoolhouse/how-to-thread-a-singer-featherweight
Dec 12, 2017 | Singer Sewing Machines
I am trying to thread the bobbin case on my machine.but everytime i do the needle won't pick up the thread.i have a singer slant 404.the diagram isn't very helpful.
if you can't find the spring, then it might be missing. take it to a sewing machine repair shop to find out if it's missing
Jan 17, 2012 | Singer Sewing Machines
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
My Simple Singer sewing machine will not thread the bobbin thread. For some reason it will not pick up the bobbin thread from the bottom of the machine, does anyone know how to fix this problem?
Your needle may be in backwards, flat side should face rear of the machine or you bobbin is unwinding in the wrong direction, refer to your manual and dvd. Call Singer at 1-800-4singer if problem persists. Good luck
May 30, 2010 | Singer 3116 Simple
Sewing machine timing problem
Singer sewing machine needle does not go directly down into opening of foot, it hits the back plate of foot. how can i align it.
Apr 23, 2009 | Singer 14SH654
Bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Oct 14, 2008 | Singer 3116 Simple
Needle will not go down and pick up bobbin thread
Check for a thread jam in the bobbincase. Lower looping is most commonly caused by a lack of top tension. Raise the presserfoot and rethread themachine again. Once threaded put down the presserfoot and pull the thread through the needle. if it pulls through easily it is still not threaded correctly. When threaded correctly the needle should bend but not break when you pull the thread through. good luck.
Jan 29, 2008 | Singer 1507
Singer sewing machine model 6012 c
hi
thank you
Dec 15, 2007 | Sewing Machines
Sewing Machines Logo
21 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
