Question about Dishwashers
Dishwasher not getting water - Dishwashers
My dishwasher was working fine until yesterday, now it doesn't seem to use all the soap, I tried 2 times and there was still soap left over.
Hello there:
It doesn't get the dishes clean dot_lineone.gif 1. No water
Make sure you get water to the dishwasher. Check to see if the watershut-off valve (located under the sink) is open. If you get water tothe dishwasher, but there is still no water inside during the fillcycle, the problem might be with a faulty water valve (located at thebottom of the dishwasher, behind the kick panel, on either side), inwhich case replace the water valve. There are also screens and filters that need to be cleaned to ensure proper operation so please check these as well
2. Not enough water
If there is not enough water, the dishes would not get cleaned. Thiscould be caused by a partially closed water shut-off valve (locatedunder the sink), or a faulty dishwasher water valve (located at thebottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Makesure there is no debris blocking the holes inside each spray arm. thee are also screens and filters under these arms that may need toi be cleaned
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.if not increase the hot water heater temp
5. . Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside thedishwasher. Try cleaning you dishwasher using a dishwasher cleaner.There are a few out there, we recommend Dishwasher Magic®.
Jan 13, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Does not clean like it did soap dispences goes through the cycles does not seem to have the pressure
Hello there"
Please go thru this list that i have provided for you and check each item ok
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, we recommend Dishwasher Magic®.
Jan 12, 2010 | Bosch SHU3306UC Built-in Dishwasher
Dishwasher wont fill with water
Sep 11, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
AEH Favorit 50730 dishwasher seems to work fine other than the water never gets hot. Is it easy to replace the heating element or whatever that could be faulty?
If this dishwasher is a residential dishwasher the water that is supplied to the unit is from the hot water side of the sink supply. The dishwasher does not heat the water it uses water from the water heater that is connected to the house. It sounds as if the dishwasher is hooked up to the cold water supply instead of the hot water supply. The heating element you see in the dishwasher is for drying purposes and not for heating water. I would check the hot water supply for your dishwasher to see if that could be the problem. Also remember unless you have a recirculating pump on the hot water there will be an amount of water in the pipe from the water heater and the dishwasher that has sat and cooled down over a period of time therefore when you turn on the dishwasher you will not get hot water immediately due to the distance the dishwasher is from the water heater. You will notice when you turn on the hot water to thew sink you do not get hot water right away you let it run for a minute before it gets hot since the dishwasher is connected to the same valve as your hot water to the sink it acts the same way.
Good luck on your repairs hope this helped.
Dave
Sep 02, 2009 | AEG 24 in. Favorit 50730W Free-standing...
Dishes not getting clean
Check the following to address this issue.
1. No water
2. Not enough water
5. Not enough soap
Jun 19, 2009 | GE GLD4600NCS Built-in Dishwasher
Dishwasher wont take water
Jun 12, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Just a little water seems to be coming into the dishwasher and the dishes are not getting clean even on the Potscrubber cycle
1. No water
2. Not enough water
5. Not enough soap
Jun 06, 2009 | GE Dishwashers
Kenmore Elite dishwasher not cleaning well and leaving dark stains on the dishwasher walls. water pumps in to correct level and pumps out. First cup of soap the water is just warm. Second up its hot and...
1. No water
2. Not enough water
5. Not enough soap
Jun 04, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
My Maytag dishwasher Quiet series 100 gets no water
I would cheak your float switch witch is located on the bottom of inner dishwasher move it up and down may be stuck.then try.If that will not work you may have a bad micro door switch.Good luck:)
Apr 08, 2009 | Maytag MDB5100A Dishwasher
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
5. Not enough soap
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Dishwashers Logo
19 people viewed this question
Top Dishwashers Experts
