Question about Building Materials
Remote opens door to let me out but wont (sometimes) close when I am through
Merlin Brand
  • 3197 Answers
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Posted on Sep 12, 2009
  • 3197 Answers
SOURCE: remote code for a merlin power lift
I think you will have better luck checking around the Australian forums for help with this door opener.
Posted on Apr 14, 2010
swolfinor
  • 504 Answers
SOURCE: garage door opening/closing problem
Could be a bad wall button or a smashed wire.
Anytime a door opens and/or closes by itself, or remotes work intermitantly I look for a smashed wire between the motor unit and the wall button or a bad wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Posted on May 29, 2010
  • 244 Answers
SOURCE: My merlin 230T won't open or closes with remotes
Unlock the LOCK
Posted on Jul 11, 2010
  • 14 Answers
SOURCE: 97 chevy ventura sliding doors wont open automatically
the plungers are not making good contact swivel them around
Posted on Sep 25, 2010
Merlin M802 remote not working it has a new battery and the red light flashes when button pressed but won't open or close the door
need to reprogram it to the opener. push the 'learn button' then push the remotes button. door should then respond.
Dec 22, 2015 | Building Materials
Merlin prolift 230T won't open with remote. The chain goes around but it does not open or close the door
someone unlatched it to open by hand and the disconnect needs to click back in . give it a wiggle (the rope)
May 08, 2015 | Building Materials
How to program a remote control for Merlin Garage Door
Each manufacturer of aftermarket remotes for Overhead doors has a specific sequence for a specific door opener mfg and model #. And those sequences are include in the printed matter in the packaging of the remote. If you have Merlin remote and Merlin opener contact the local Merlin installer for the sequence.
Oct 13, 2014 | Building Materials
I cant get the remote control for a Merlin garage door to program, 2 new remotes 2 new batteries.
go to manufacturer website and contact them for a detailed step by step procedure, ask any school child to help you with programming the electronics, call a garage door specialist to come program it for you.
Sep 20, 2014 | Building Materials
I have a Merlin 230T garage door opener and it has started to run in the opposite direction. ie; it is closed now and when I use the remote control it tries to close more
Pull the emergency release handle. Use remote to open door then close it again with the remote. Now re engage the emergency release. That should put the chain in the right position for proper operation.
Aug 28, 2014 | Building Materials
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
Remote code for a merlin power lift
Mar 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
27 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
