Routers
Problem for Routers
Generic problem for all Routers
I have two Dell 2350 Wireless Routers try...
By davisbabme on Jul 25, 2009
I have a Dell 2350 Wireless Router that I am trying to use as a repeater or a bridge with another 2350 and I can't seem to get the settings right. I have looked up the help file but when I follow it step by step it doesn't always match up with what I see in the setup tool. For example when it says to enable WIRELESS BRIDGE there is no "wireless bridge'' option, only ''Enable this AP as a root AP'' or ''Enable this AP as a Wireless Repeater'' so I chose the latter. Next, the instructions direct the user to input ''...the Wireless MAC address of the other Dell Wireless 2350 Broadband Router that you want to bridge.'' Where do I input that address? Does anyone have the step-by-step sequence for setting these up for a bridge link or as a root and repeater? Thanks.
Solution #1
posted on Jul 25, 2009
Not Rated)
kakee
Rank: Wiz
Rating: 81%, 451 votes
The first router must the root AP and the second should be set to Wireless Repeater. Follow the steps on how to resolve this setup.
1. Get the Wireless MAC Address of the main router. The router has two MAC addresses, one is wired and 1 is wireless. To determine the wireless MAC address, go to Status page of the router, there's a sub tab there for wireless and you'll see the Wireless MAC Address. Take note of it.
2. Access the setup page of the 2nd router. Change the LAN IP address to 192.168.0.2 then save. Power cycle it by just turning it off for 10 seconds then turn it back on. You can now change it to Wireless Repeater and there's an option for you to type the Wireless MAC address of the main AP. Make sure all wireless settings are the same on both routers like SSID, Channel and Encryption Key. Save your changes after that.
3. From your computer, try to ping the 2nd AP which is 192.168.0.2. If it replied back, you're all set.
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
I need the latest firmaware for my viewsonic wmg80
Answer
I seemed to have lost the speed when I set up the security, is that possible or is there some other... (More)
Answer
I have a belkin g router ever since I started using it my computer freezes up and I have to hard... (More)
Answer
my westell versalink 327W router works when my computer is connected to it but it is not sending out... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
