Question about Food Mixers
I need help with my wiring on my mixer it's a crypto peerless the speed control switch needs fitting the model is EL20 has any one got a wiring diagram it year is 92 ?
2 Suggested Answers
elidagolding
SOURCE: Can I buy a work shop manual for a crypto peerless mixer model EL 20 year 92
Hare you can go and get your mixer model
The Best Kitchen Stand Mixers of 2017 Top 10 Reviews
Posted on May 25, 2017
Won't spin on speed 1,2 and 3 but will spin on higher speeds.
There is a speed control module in them. look it up on e=Bay they have all sorts of them depending on model.
Mar 19, 2015 | KitchenAid 5KSM150PS Mixer
Why wont my classic kitchenaid mixer switch off
Good Morning,
There is a spring inside your mixer attached to the speed control switch and speed control arm, the spring can sometimes get caught on the slide bar that is just below it inside the mixer. The other reason is that the speed control switch plate in the rear of the machine (that the spring attaches to) vibrates the three speed adjustment screws out or in and the spring will pull the speed switch (control arm that you use to control mixing speed when using the mixer) back to the stir position after you try to turn the mixer off.
If it is a spring problem you will have to do a full tear down to get at the spring and either free it or replace it. If it is a problem with the adjustment screws on the speed plate, that can be handled at the rear of the machine and is twice as easy to get at but sometimes much more frustrating to adjust. There are "YouTube" videos on the internet that will walk you through the process of adjusting your speed control plate just Google "adjusting speed on kitchenaid mixer" I hope this helps. please let us know if it does and if you have other questions just post them here and we will "FixYa"
Sep 11, 2014 | KitchenAid K45SS Classic Stand Mixer
KITCHENAID MIXER WON'T TURN ON ?
Remove the brush caps on the sides of the motor housing and check the carbon brushes. If they are worn out replace them. They are keyed and will only fit properly one way so be observant. If that's not the problem remove the back cover and check for broken wires on the black control plate. Make sure the switch on the bottom inside of the control plate is making contact. If still faulty check the cable for continuity to the control plate, cable connects to the black wire and the white wire on lower left of control plate. After that you need to check for continuity of the field coil windings. Only thing left after that would be the phase board pcb just above black speed control plate at the back.
Sep 07, 2014 | KitchenAid K45SSWH model 45SS Classic...
The mixer would not come up to the speed when speed lever is moved from off position to any other speed provided. The mixer would start spinning and then stops immediately. Any suggestions?
You either need to adjust the speed control switch under the rear dome or you need to replace the switch, I think you can find on YouTube videos on how to adjust speed control switch and the part is easily available on the internet. AND!! you can do this repair without a full tear down.
Sep 18, 2013 | KitchenAid KSM75WH WhiteTilt-head Stand...
Regreased kitchenaide mixer now won't turn on
Did you remove the carbon brushes. If so they go back in any of four ways. But only one way works correctly. If you did not remove the brushes then you need to set the speed timing on the speed control switch at the rear of the machine and you can find a YouTube video on this exact exercise on YouTube of course. You may have also reattached the wires to the speed control switch to the wrong connectors hence no work.
Sep 12, 2013 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid artisan mixer
The most likely answer is that you need a new speed control switch and there is a possibility that you may need a new worm gear. Can you give a more detailed explanation? What happened last time you used the machine?, what was happening when the problem occurred? What caused you to open the back cover? what else did you inspect or take apart or open up? Please send more info.
Jan 03, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Crypto Peerless Dough Mixer Diving Key broken
have you solved the problem , if not phone heartland catering spares 0121 243 3336 they specialise in crypto
Oct 23, 2009 | Food Mixers
The latch/switch on the speed control board is stuck
You need to take the back cover off and then split the gear cases to find the mechanical reason why the lever is stuck. Take the motor off the pedestal, remove the planetary and undo the 9 screws that hold the bottom gearcase to the top housing. You will need to unplug the white and the black wires from one side of the speed control plate.
Jun 14, 2017 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
51 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
