I cannot get what other people write on screen because I have move it up how can Leix it
1. Main Functions
• Diag
Performs unit test of devices installed on the board.
• Display Error Log
Error log is displayed. Displayed contents can also be saved in an USB memory device.
• Factory Initialize
Restores the unit to its factory settings.
• Network
Checks the wired network connection.
• Version Up Not used.
• System Information
Displays the system information of the unit.
Displays information such as the software version, drive information, etc.
• EMC Test Mode Not used.
• Drive
Write drive OP data and check drive.
2. Menu Tree
3. Service Mode Menu (Top Menu)
This is the top menu of service mode.
Each function is accessed from this screen.
[1] Moves to Diag screen
[2] Moves to Log screen
[3] Moves to Factory Initialize screen
[4] Moves to Network screen
[5] Moves to Version Up (DISC version update) screen (Not used)
[6] Moves to System Information screen
[7] Moves to EMC test mode screen (Not used)
[8] Moves to Drive screen
[9] Moves to HDD mode (Not used)
[UP]/[DOWN] Moves the cursor [ ENTER] Moves to the screen of the item selected with the cursor.
Electronics Equipment Repair Center
on Feb 14, 2015 | Sony Televison & Video
Google screen only (all other screens are correctly positioned) has moved right, can't access right side of screen. can't adjust
Press the windows key on your keyboard, and while holding it down, press the the left arrow key. that will move it to the left.
Dec 05, 2014 | Google Chrome
How can i put the app store app back on the home page of my ipad2?
Touch and hold app to move until it starts to jiggle.Drag app to bottom of screen placing with other apps ,scroll screen to home screen,take app from bottom and move to home screen.Apps can be moved to any screen as long as they jiggle.
May 25, 2012 | Apple iPad 2 Wifi 16GB
I have an HTC EVO 4g ... Somehow I moved my menu that normally sits right above the: home, menu, back, and search buttons. Now it has moved to the right side of the screen and is driving me nuts!! How...
To "Drag or Move" Screen Contents (widgets, menus, icons, etc.) around the Home Screen:
1. Tap and Hold the item to be moved for 2 Seconds (or till short vibration).
2. Now, while still holding the item, move it to wherever you would like on the screen; move item to the screen's edge and hold it there for a second to move to the next screen.
3. Release it while hovering over the new location on the screen.
Sep 28, 2011 | HTC EVO 4G Smartphone
When I move the mouse off the side of the screen
Try changing the screen resolution of your screen
Aug 19, 2009 | Apple Computers & Internet
I can't see my 6288 screen and want 2 move my contacts to sim
first make ur screen changed then only u vl be able to do
Aug 05, 2009 | Nokia 6288 Cellular Phone
The my Meeba won't move when I move the screen up and down. How can I fix it?
I also had this problem, try gently pulling the screen away from the tube when you move up and push in when you move down. Also try moving the screen down to the very bottom before you press the buttons to turn it on
May 24, 2009 | Mattel My Meebas Interactive Pet
Screen moves
WinXP: Right click on blank desktop, click Properties, click Settings tab. Move the "Screen resolution" slide bar so that the whole screen is used up. In your case the vertical resolution is higher than the screens or horizontal resolution is not high enough.
Screens tends to do scaling. Check the "Native Resolution" of the screen and set it as the Screen Resolution.
Apr 16, 2009 | Acer Aspire 3000 Notebook
When I move the cursor to play a game, the whole screen moves too
How are you moving the cursor? Is it time to change the batteries in the mouse, if it's cordless...
Use the scroll wheel and the CONTROL key - spin the wheel back and see if the screen shrinks. Then click elsewhere on the screen to make sure you're not dragging the whole gameboard around.
Nov 11, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
