I have a Visio Smart TV, while watching The blueray the tv goes black and no signal for a few seconds then continue. We have changed cables, inputs, and blueray players. help?! Thank you Tina G
  • 21 Answers
SOURCE: input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Posted on Jul 26, 2008
SOURCE: Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Posted on Nov 03, 2008
ladywinn
  • 5138 Answers
SOURCE: screen goes black randomly during use and tv shuts off
check your capacitors cp150 114 120 if any of them is puffed up on top it is bad replace all 3 cap. 2200uf 1`6v and two 220uf 35v. also resolder FBT pinns.
Posted on Feb 20, 2009
  • 4 Answers
SOURCE: No signal input when connecting PC to LG TV via HDMI
Do you also have a computer monitor attached to the computer when attempting to use the HDMI?
Posted on Mar 30, 2009
pilot210
  • 39 Answers
SOURCE: Maxent mx-42vm11 screenflashes black and acts like it loses input
Check on ebay for the repair kit if you are versed with a soldering iron.
Posted on May 18, 2009
What channel do I put my LG TV on to connect my Sony blueray player to watch netflix
channel is not the correct path
you need to be thinking What input source do I need on the tv
atv dtv - THIS IS FOR AN ANTENNA CABLE
hdmi1 hdmi2 hdmi3 av1 av2 these are input sources
look on remote for input or source button .
HDMI 1
Apr 18, 2016 | LG 42LC2D 42 in. LCD HDTV
My 55inch LG 3D smart tv is not working properly. When you turn the tv on the LG home screen comes on for a few seconds, and then the screen goes black. What is causing this
it's set to the wrong input device ? the one you currently have it pointed to has no input
also it's possible that cable plugged into current input channel has gone bad or become disconnected from it's source
Hdmi cables are unfortunately famous for this as they have no Lock device to keep them inserted into ports
most TV's nowdays shut off if not provided an input for a few minutes
Jun 01, 2015 | LG 55LM6700
My pc is connected to my tv using an hdmi cord, it frequently cuts out and says no signal
Sounds like either the laptop's hdmi output, or the tv's hdmi input is the problem. You can findout wich one by connecting the laptop to another set and see if it still happens. If it goes away then it is your tv input, if it is still there it is the computer.
Jan 28, 2013 | LG Televison & Video
Screen goes blank while watching TV and playing DVDs
First thing to do is replace the cable with a new high quality one. They can go faulty. If that doesn't work, check that you are outputting the correct signals from your devices, plus it is set to pick them up. If that doesn't work you might have a fault possibly on the TV.
Mar 19, 2017 | Marantz NR1602
Philips blueray player not working with lg smart tv
If you press play after welcome screen, you should see picture.
Jan 18, 2018 | Philips Televison & Video
I HAVE A VIZIO LCD TV AND WHEN WATCHING ANYTHING THROUGH THE hdmi INPUTS LIKE BLUERAYS THE SOUND GOES STATICY AFTER 30 MINS. AND TO RESET IT I CHANGE THE IMPUT CHANGES THEN BACK AND THEN ITS FIXED. WHAT...
This problem happen to all the HDMI inputs?Only one HDMI input,that one properally is shorted.Might even the HDMI cable is old,and worn out.U have about 6 HDMI inputs on ur tv,rent about 3 DVDs movies and watches test out all ur HDMI ports out.
Mar 25, 2010 | Vizio VW42LF 42 in. LCD HDTV
While watching tv on our new 42in.lcd flat screen and hooked up to our new hd cable box from comcast there are intermitent total signal losses from 3-5 seconds . Tv says searching for signal for a few...
yes we have to do a process of elimination to fix or narrow the problem down. try another box and see the results.if box work on another tv then u have tv problem
Aug 17, 2009 | Polaroid FLM-2632 Television
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
