Question about Hammer Drills
Have an Ozito 4100 hammer drill. Very happy with it. Using in hammer mode, but it has started cutting out with increasing frequency. Seems like a heat overload problem. On/off switch checks OK. Ideas?
comax
  • 154 Answers
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Posted on Apr 13, 2009
  • 104 Answers
SOURCE: stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
Posted on May 23, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
SOURCE: Why doesn't my HP 1501 Makita hammer drill work
The problem was the cord at the base of the drill. The wires were broken, cause by constant bending. After souldering the wires, the drill works perfectly.
Thanks.
Posted on Jul 29, 2009
  • 583 Answers
SOURCE: When I was done using the hammer drill to drilling
open your chuck as far as it will go look down inside the chuck and you should see where it has come from ,if that is where it came from it will be right hand thread probably allen key or very small socket
Posted on Aug 15, 2009
Charging instructions for Ozito hammer cordless drill
what model ?
CORDLESS HAMMER DRILL
cdn1.blocksassets.com/assets/ozito/ozito...manuals/.../LHD-7100-Manual-Online.pdf
Apr 28, 2017 | Hammer Drills
Where do I buy brushes for GMC RHD 1050k rotary /hammer drill in Australia? Thank you.
you probably won't as the GMC operation went broke
I am led to believe that ozito took them over so there is a possibility that the ozito hammer drill will use the same brushes
It is worth a try
other than that, many electric motors use generic brushes so may be an appliance repair shop that has a lot of repairs to hand drills and small electric motors may be able to supply a set of brushes
a sample would be a big advantage when asking around
Apr 05, 2016 | Rotary Drills
My drilling machine 26mm active pro brand. i am using drilling one hrs ok after running problem hammering mode stoped only running not working for machine not proper working in hammaring mode.what...
Sheared hammer pin, stuck hammer or failure of a bushing or washer. A sharp tap with a rubber mallet in an area not likely to be damaged can sometimes free stuck hammers, if not it's a disassembly.
May 10, 2014 | Drills
Normal drill function works but hammer no longer works
It sounds like it's way overdue for a rebuild. That includes orings and grease and maybe brushes. Hilti.com should get you either a parts breakdown or a phone number to Hilti to see if you can still get parts.
Mar 29, 2014 | Hilti Drills
Keeps switching from hammer to drill
There is a spring loaded detent that keep the switch from moving. It is either dirty or needs replacing. The whole front of the unit needs to be opened to access it.
Is this your unit?
Parts:
Website: www.ozito.com.au
Email: enquiries@ozito.com.au
I hope this helps. Please give feedback.
J
Dec 09, 2013 | Drills
Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Jul 24, 2010 | Bosch Drills
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
I have the same problem. 1199VSR hammer drill. The tool is 18 months old (out of warranty) and has barely been used - I think I used it for for two jobs - all together about 12 1/2" diameter holes. It...
Check the motor brushes for breakage, badly worn, or weak springs (heat damage). Keep track of brush wear pattern when removing and reinstall in the same orientation.
Jul 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Mar 25, 2009 | Makita Drills
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Drills Logo
74 people viewed this question
Top Hammer Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
shall39
Level 1 Expert
Are you a Hammer Drill Expert? Answer questions, earn points and help others
