Question about RCA Televison & Video
Mi tv is rca 2014 only vertical color - RCA Televison & Video
    Top Expert:
  • RCA Master
  • 75,581 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on May 21, 2017
RCA LED LCD TV Vertical Line Problem
Sounds like your display driver board is broken. Try claiming warranty.
Jul 02, 2016 | RCA LED55C55R120Q 55" LED TV 1920x1080,...
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
I have a RCA Scenium HDLP50W151YX1 that has distorted Color (Bad Picture)
I am parting out my tv it was playing good when I shut it off we got a wall hanger we don't need this tv let me know what part you need I'll sale them cheap 2705898074 call me if you want
Oct 02, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
CODIGOS PARA EL DAEWOOD TV DEL CONTROL REMOTO RCU403A
NO SE EL CODIGO DE MI CONTROL REMOTO RCA 403, PARA MI TV MAGNAVOX..... AYUDENME, PLIS
Jan 28, 2010 | RCA RCU403 Remote Control
3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
Oct 11, 2009 | RCA D52W19 52" Rear Projection Television
Digital or not????
You can get the owner's manual at;
http://www.bottomlinelcds.com/manuals/PLTV-32CM-owners-manual.pdf
You need a converter box.
Specifications
General
Dimensions
33.07"W × 25.83"H × 9.09"D
Weight 45.54lbs
Panel Type Active Matrix TFT LCD
Screen Size 32" widescreen (16:9)
Color Range 24 bits (16.7 million colors)
Max. Resolution 1366 × 768
Pixel Pitch 0.51075mm (H) × 0.51075mm (V)
Sync Range Horizontal: 30–80kHz
Vertical: 50–85Hz
Contrast Ratio 800:1
Brightness 500 cd/m2
Viewing Angle Vertical: +/–85°
Horizontal: +/–85°
Response Time 16ms typical
Inputs 2 × progressive scan component video (RCA)
3 × composite video (RCA)
1 × S-Video
6 × stereo audio (RCA)
1 × SVGA (15-pin D-Sub)
1 × stereo audio line in, 0 dBV nominal (1/8" TRS)
Outputs 1 x composite video (RCA)
1 × stereo audio (RCA)
1 × subwoofer (RCA)
1 × headphone (1/8" TRS)
Video Formats Supported SDTV: 480i
EDTV: 480p
HDTV: 720p, 1080i
TV Tuner NTSC-M, CATV, 181 channels
TV Audio Mono, Stereo, SAP
Parental Controls V-Chip (TV PG, MPAA)
Picture-In-Picture PIP, PBP
Closed Captioning CC1–4, TEXT1–4
Speakers 2 × 10W
Plug and Play Compliance VESA DDC1, DDC2B
Power Supply 100–240VAC, 50–60Hz
Power Consumption Operation: 232W
Standby: <3W
Storage Temperature 0 to 60°C
Operating Temperature 5 to 35°C
Apr 08, 2009 | Protron PLTV-32 Television
The picture is drawn in from the sides
this problem we cal vertical fault..cause by capasitor is not in good condition at vertical area or loose solder at the vertical ic
Dec 08, 2008 | RCA F35673MB 35" TV
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
