The mode selector dial will not move automatically while the the machine is washing or spinning it works if i move the dial manually through each cycle
  • 60 Answers
SOURCE: Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Posted on Sep 14, 2007
  • 209 Answers
SOURCE: Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Posted on Oct 04, 2007
  • 1294 Answers
SOURCE: Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
Posted on May 10, 2008
localwonder
  • 6784 Answers
SOURCE: Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Posted on May 27, 2009
SOURCE: washing machine will not advance through the wash cycle
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Posted on Aug 12, 2009
Ge front load washer won't spin automatically
then I can only think you need a new timer motor . call a repairman
May 11, 2016 | GE GFWN1100LWW
Maytage Dependable Care washing machine will not operate. Lid switches, timer check out. Fuse is good. Machine is getting power. Machine will not fill, agitate, or spin. Timer does not advance.
Sounds like the timer motor is fried. Remove it, connect it to a 110/120 volt power source and listen to it. If you can hear it running, then that's cool. Next, move the selector switch to the next mode manually and see of your machine responds to that. If it does, then the motor for the timer needs to be replaced, it probably lacks the torque needed to move the selector switch around.
Jan 23, 2014 | Washing Machines
Hello, I have a Maytag legacy series washing machine and recently it stopped working properly, first it tripped the breaker, then in regular washing mode it washes normally but skips spinning and water...
Sounds like a bad relay array, or timer module. The little motor that makes the selector move (and then trip the function switches inside the timer module) could have trouble moving the selector past a certain point. When the machine stops, press your ear up against the timer module. Do you hear the little timer motor running? Yes? then it's probably the timer module itself, not the timer motor. I say this because you can manually move the selector to activate the modes.
Jan 03, 2014 | Maytag Legacy Series Top Load Washer
The Spin Cycle does not work
Suspect that the Timer module is faulty as it does not move automatically to the SPIN mode.
You need to try with another program cycle to confirm or otherwise replacement is the only option. check on cost and options..
Jan 16, 2013 | Washing Machines
Washer is full of water but will not spin
if your washer has old dial selector ,does it continues and finishes "cycle" without spining or does the selector stops moving also you could have a bad timer ,newer ones will have some sort of electronic module
Feb 23, 2012 | Kenmore Washing Machines
Washer when set turns on and fills and agitates. But will not move to next cycle automatically. I can manually move the dial to rinse / spin and it works properly. But again won't move to final spin...
From the way you discribe it, sounds like you have a bad timer.If you decide to fix it yourself be sure to mark the wires before removing the timer.
Apr 06, 2011 | GE Washing Machines
Washing machine won't drain but it will spin.
sounds like a motor problem, the motor turns 1 way to agitate and the other way to drain and spin
Feb 16, 2010 | Kenmore Washing Machines
Wont spin to drain water
try moving the dial manually to spin mode if this works the timer is shot. if not the transmission is shot
Jul 30, 2009 | Washing Machines
Dial won't move automatically
The dial is not a timer that moves through the prog, it is a selector switch, which selects the programme you require, and therefore does not move round
You need to check the filter re the spin prob.
Remove rear panel, remove large black hose from bottom of tub, remove filter, and clean.
Refit filter and hose.
Test for leaks
Plz rate my solution.
Thanks
Jan 11, 2009 | Hotpoint First Edition WMA20 Front Load...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
