Question about Kodak Office Equipment & Supplies
Problem with kodak carousel 650H slide projector - remote control not working
  • 412 Answers
SOURCE: Just bought a kodak 650H
Chances are the projector you bought needs a slide change solenoid link or at the very least, an adjustment to the timing of the slide changing mechanism.
Posted on Nov 03, 2010
  • 412 Answers
SOURCE: We have a Kodak Carousel 650A projector. (140
The purpose of the "SELECT BAR" on a Carousel 650H is to eject the slide. If you press & hold the select bar it allows you to rotate the tray to the slide you want (or Zero & remove the tray). If you can not advance or reverse the slide tray using either the remote buttons or the buttons on the side of the projector, then chances are you have a broken part in the slide change mechanism. The possibilities are numerous, and really requires a trained tech to analyze your specific failure. Sorry the news isn't better (or simpler!).
Posted on Nov 12, 2010
  • 412 Answers
SOURCE: my slide projector carousel does not advance
Does the projector run in reverse?? If so, then what you are facing is a timing adjustment.
If it does not cycle in either direction, then there is a high probability that the solenoid "link" is broken. The "link" connects the cycle solenoid plunger to the slide change mechanism.
The good news: There are still parts available (www.micro-tools.com). The less-than-good-news: both fixes are difficult and best handled by a factory-trained repair dealer.
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: projector broke
Given the age of the projector, chances are the cause of the problem is a broken "Link". The "link" connects the cycle solenoid plunger to the slide change mechanism. The "link" is made of plastic, and over time it gets brittle & cracks, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair that requires dis-assembly & a service manual - - best left to a factory-trained repair dealer.
Posted on Jan 04, 2011
  • 412 Answers
SOURCE: I have a Kodak 650H
The answer for the 2 machines is similar, but the repair is different. The clutch contact wire on the 650H has burned through the clutch contact. If it has just worn a notch in the clutch contact, you can bend the contact wire slightly to get it away from the notch. If the tip of the contact wire is burned off, you will be better off buying a used slide projector from someone, as parts for this generation of machines are long gone.
For the 4600 the problem is the same but the parts look different. Refer to the attached diagram for detail. The wire must rest at the center of the pad. You can use this diagram to roughly locate the similar parts in your 650H. Good Luck !!
Posted on Jan 29, 2011
My slide projector light won't come on. Every thing else works
Check the base where the bulb connects, pins get bent and don't connect to bulb at times
Nov 18, 2014 | Kodak CAROUSEL 650H ELH Light Bulb Lamp...
My Kodak 650H slide projector carousel won't advance?
Chances are what you need is a new cycle solenoid LINK. They can be purchased from: www.micro-tools.com They should have instructions to help you install the new part, as well. Good Luck!!
Jim
Apr 10, 2014 | Kodak Carousel 600 Slide Projector
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
Kodak carousel makes a buzzing sound and will not advance
Your problem is most likely related to cycle contact adjustment. See the attached illustration for the parts involved and the SPECIFIC POSITION of the contact parts:
Sep 08, 2012 | Kodak Carousel 4400 Slide Projector
CAROUSEL WILL NOT ADVANCE, FORWARD OR BACKWARD, MANUALLY OR BY REMOTE
If the projector is indeed a Carousel 650H, then the chances are that the LINK that connects the cycle solenoid plunger to the cycle lever has broken/cracked. This LINK is made of plastic, and over time the plasticizers that keep it flexible evaporate into the atmosphere, leaving the part brittle. The good news is that while Kodak no longer stcks parts for any slide projector, the company that purchased their repair parts is: www.micro-tools.com This is not an easy repair, but once the part is replaced it will last a very long time! To purchase the part, contact micro-tools. I believe they have specific directions for making this repair, if you feel you can do it. If not, contact an authorized repair center to make the repair for you. Good Luck!
Feb 22, 2012 | Kodak Office Equipment & Supplies
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
I have a Kodak 650H carousel slide projector and it won't stop advancing the slides unless you turn it off. Will the answer for the 4600 work on this type also?
Jan 26, 2011 | Office Equipment & Supplies
I am looking for a replacement bulb for a Kodak carousel projector model # 650H where can I find one
The 650H uses a 300 watt, 120 volt lamp with an ANSI code of "ELH". You can order "ELH" lamps from Bulbman (www.bulbman.com).
Aug 08, 2010 | Kodak Office Equipment & Supplies
We have a Kodak Carousel 650A projector. (140 slide carousel) Cannot advance the slides using the remote or the select bar. Putting in the individual slides with the carousel off the select bar will eject...
Jun 20, 2010 | Office Equipment & Supplies
Projector broke
Apr 01, 2009 | Kodak Office Equipment & Supplies
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
