Question about Garden
Lost a screw is it probably the air mixture screw it came out of the back of the carburetor on A techumish go cart and will not idle
  • 1,043 Answers
If the cart runs at all then the fastener you are looking at is probably not the air mix. screw it is most likely the screw that sets the idle when the cable returns. The idle screw rest against a half moon shaped stop and the screw holds it open to the desired idle.
Posted on May 21, 2017
I have a Briggs & Stratton Vanguard 16 HP motor. It idles fine and it runs OK at high RPMS. But it backfires thru the carburetor during accelerating. Any suggestions?
On some float-type carburetors, you can adjust the air-fuel mixture and engine speed at idle. Check for an idle speed screw designed to keep the throttle plate from closing completely, and an idle mixture screw that limits the flow of fuel at idle. If your carburetor contains these screws, proceed below.
  1. With the engine off, remove the air filter and air cartridge.
  2. Locate the idle mixture screw and turn it clockwise until the needle lightly touches the seat. Then, turn the screw counterclockwise 1-1/2 turns.
  3. If your carburetor has a main jet adjustment screw at the base of the float bowl, turn the screw clockwise until you feel it just touch the seat inside the emulsion tube. Then, turn the screw counterclockwise 1 to 1-1/2 turns. Replace the air cleaner assembly and start the engine for final carburetor adjustments.
  4. Run the engine for five minutes at half throttle to bring it to its operating temperature. Then, turn the idle mixture screw slowly clockwise until the engine begins to slow. Turn the screw in the opposite direction until the engine again begins to slow . Finally, turn the screw back to the midpoint.
  5. Using a tachometer to gauge engine speed , set the idle speed screw to bring the engine to 1750 RPM for aluminum-cylinder engine or 1200 RPM for engine with a cast-iron cylinder sleeve.
  6. With the engine running at idle , hold the throttle lever against the idle speed screw to bring the engine speed to "true idle." Then, repeat the idle mixture screw adjustments from Step 4 to fine-tune the mixture .
May 02, 2017 | Briggs & Stratton Briggs Stratton Intek V...
What is the adjustment screw under the throttle?
Hi Darren, on the right hand side of the carburator there is an idle adjusting screw with a spring behind it, turn screw clockwise to increase idle counter clockwise to decrease idle. At the front of the carburetor on the bottom of the venturi bore there is also an air/fuel mixture screw inside a carb body lug that may or may not be plugged with an aluminum cap that's about 3/16" thick. This cap can be drilled out to acess the air/fuel mixture screw. Turning screw clockwise will lean out mixture and lower idle, turning screw counter clockwise will richen mixture and raise idle. Start by turning gently the screw clockwise until it just barley bottoms out then back it out 1 3/4 turns. You need to balance the two adjusting screws to obtain an idle of 950-1000 RPM then back out air/fuel mixture screw 1/8 turn, snap throttle to confirm responce, you may continue to back out air/fuel mixture screw untill desired throttle responce is achieved, if you see black smoke coming out of exhaust you have gone to far and need to turn screw back in 1/8 turn at a time, final adjustment should be made with the engine at normal operating temperature. For more information about your question please visit the websites below. Good luck and hace nice day.
CV Performance Tuners Kit part 1
CV carburetor tuning part 2 Mixture screw adjustment
Harley CV carb mod
Adjusting Throttle Cables on Harley part 1 by Dr Chaos
Jul 09, 2015 | Harley Davidson FLSTC Heritage Softail...
What are standard settings for idle and air mixture screws
The idle speed will be dependent on model, particularly if 4- or 2-cycle, 2, 4, 6 cylinders, etc. If your engine uses carburetors, I'd say no less than 600 RPM, maybe up to 850 RPM at idle. If your engine is fuel injected, the computer should set the idle speed and air mixture for you (if it's functioning correctly), and a big twin could idle as high as 1150 RPM .
Your Idle air mixture settings are important for proper idle. A good approach is to let the engine tell you what it likes. For this method you will need either a tachometer or a vacuum gauge. Here are some steps to guide you.
1) If the engine will start and run, go from there. If not, a good initial setting is to turn the idle screw(s) all the way in (GENTLY--don't break the seats!), then back them out about 1 1/2 to 2 1/2 turns.
2) Attach either your tachometer or vacuum gauge to your engine. Tach is connected to the ignition system (usually at the coil); vacuum gauge would be connected to a manifold vacuum port. (The bike's built-in tach MAY work for this, but they are often not graduated finely enough.)
3) If using a tachometer, warm up the engine. Working on only one idle mixture screw at a time, begin turning it IN until RPM begins to decrease. Then back the screw OUT again until you achieve maximum RPM on that screw. Feel free to "play," turning the screw in and out until you achieve highest RPM at at minimum turn-out (if you leave it turned out too far, bike will run rich and foul spark plugs; if not far enough, bike will run lean and hot). Now do the other idle mixture screws the same way. Finally, go back and do all the mixture screws again (and again and again, if necessary) until all throttle bores are synchronized.
4) If using a vacuum gauge, engine temp is not as critical, but go ahead and warm it up anyway. Similarly to the tachometer method, turn the mixture screws in until RPM drops, then out until max vacuum reading at minimum turn-out. If you have multiple mixture screws, do the same on each, then repeat on all screws until you feel they are all synchronized.
5) Throughout the process of adjusting idle air mixture screws, you will probably have to adjust the idle screws to keep the engine in the RPM range you want it to idle. (If adjusting air mixture screws has no effect on the engine idle, the minimum requirement is probably a carburetor rebuild.)
6) Have fun getting to know what your engine "likes!"
Oct 14, 2014 | Motorcycles
Air intake problem or carburater problem?
Check there are no air leaks around where the air intake rubbers are at your carburetor. It sounds like your bike is running too lean or weak which means your air/fuel mixture is running on too much air and not enough fuel. This would explain it running smoothly when you put the choke on as the choke "chokes" the majority of the air from the carburetor and allows more fuel to flow through the carburetor creating a richer mixture. There will be a mixture screw somewhere on the carburetor which will allow you to either richen (more fuel and less air) or weaken (more air and less fuel) by turning the screw either in or out. Only adjust this by a small amount (about a quarter turn at most) at a time and try the bike to see how it rides each time. After adjusting the screw each time let the engine idle for about 30 seconds or so to let it settle to the new mixture setting before riding. There will be another screw on the carburetor which is your "idle" or "tick over"speed adjustment screw which adjusts how high your engine revs while the engine is "ticking over". Turn it in to increase idling speed and out to lower the idling speed. This will probably need adjusting as you change the fuel/air mixture. I hope this helps you and good luck :o)
Jul 17, 2013 | Motorcycles
Need to know how many turns do i turn out the needle valves on the 11 hp briggs @ stratton. need to know for everyone. thanks
ADJUSTING THE IDLE SPEED AND MIXTURE
  4. Run the engine for five minutes at half throttle to bring it to its operating temperature. Then, turn the idle mixture screw slowly clockwise until the engine begins to slow. Turn the screw in the opposite direction until the engine again begins to slow (image A). Finally, turn the screw back to the midpoint.
  5. Using a tachometer to gauge engine speed (image B), set the idle speed screw to bring the engine to 1750 RPM for aluminum-cylinder engine or 1200 RPM for engine with a cast-iron cylinder sleeve.
  6. With the engine running at idle (image D), hold the throttle lever against the idle speed screw to bring the engine speed to "true idle." Then, repeat the idle mixture screw adjustments from Step 4 to fine-tune the mixture (image C).
Sep 18, 2009 | Garden
I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 17, 2009 | Garden
Toro lawnmower starts then cuts off. It appears to be leaking fu
If there is a fuel leak causing this problem it could be from the line going to the carburetor or the float bowl. If no leak is present there, could be flooding or a sticking needle in the carburetor allowing fuel to enter constantly.
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Mighty Lite 26CS starts at full choke but dies when moving to 1/2 choke or to run setting. Fuel is new.
Hello roda551:
This can be a Carburetor Problem or an Exhaust Problem.
I Suggest you Check the Exhaust First and then the Carbuertor.
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holding it to the Carburetor Body.
Try Setting the Carburetor Air Mixture Screws.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog Down Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
If the Above Did Not COrrect the Problem, then Remove, Disassemble, Soak and Clean the Carburetor.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace are the Needle Valve and Metering Pump Diaphram.
>>The Metering Pump Diaphram is Under the Carburetor Plate with 4 Small Screws in it.
>>The Dowl on the Diaphram should Just Touch the Metering Jet Actuator Arm.
>>The Actuator Arm is Adjusted by Carefully Bending the Actuator Arm Up or Down to get the Correct Clearance.
>>If you Order a Kit, then Replace All the Old Components with the New Ones in the Kit even if the Old Parts Look Good.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Tooo much fuel pull cord fuel expels through exhast.
Hello aurora12104:
The Carburetor Float Needle Valve is Not Seating Properly and is Causing the Engine to Flood or the Head Gasket is Blown between the Push Tube Galley and Cylinder and the Head Gasket Requires Replacing.
Check the Oil and Make Sure it has Not become Contaminated with Gas. Change Oil if it has a Gas Smell or the Crankcase is Over Filled.
Soak and Clean the Carburetor and Replace the Float Needle Valve.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Garden
Is the carb adjustment screw on bottom
Hello
>>The Following is an Instruction File I made for Correcting this Problem. Any Input is Appreciated.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is the Nearest to the Engine.
>>The Engine Idle Screw is Usually Easy to Identify because you can See where it Makes Contact with the Carburetor Throttle Shaft Plate Stop Ear. The H and L Air Mixture Screws Go Into the Body of the Carburetor and the Tips Cannot be Seen.
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns.****
>>Reset the Engine Idle if Required. If This Carburetor has a Single Air Adjustment.
>>Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Rapidly Throttling from Idle to Full Throttle.**
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
