Question about Black Office Equipment & Supplies
Does my mg3250 need both black and colour ink to print
Silverblade
  • 173 Answers
SOURCE: Black ink not printing and colour ink very faded
Check the ink status of the printer's cartridge.
Posted on Oct 14, 2008
worldvet
  • 859 Answers
SOURCE: epson stylus DX 7450 doesn't print black
Hello, This can be FIXED. I'm not trying to be helpful. I'm here to FIX your problem.
You want to make changes to the printer settings to once again print in Black and White or Grayscale mode by going to Start Menu, Control Panel, Printers. Right click your printer and select Properties. Now make the changes to everything prints Black and White or Grayscale. This will make the change effective system wide as opposed to what you did which was for a single print job in a program.
Now, unfortunately, you will still get an error message that your color cartridges are empty anyway because they are.
To disable the error message do this.
Press and Hold the Stop/Reset button for 6 full seconds and then release it? Use the one Mississippi method of counting.
This will disable the empty cartridge error on most Epson printers.
Let me know of your results as I am here to FIX your problem. I'm not here to be helpful. I will work with you until this is FIXED or is now FIXED. OK? Use the comment box below to let me know your results.
Regards,
Worldvet
Posted on Nov 09, 2008
tigertail
  • 163 Answers
SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Posted on Apr 02, 2009
SOURCE: Using colour ink without black ink in Epson CX5500
this cannot be resolved, Epson software is useless it will force you to buy an INK
Posted on Jul 13, 2009
  • 116 Answers
replace print head assembly
Posted on Aug 02, 2009
HOW DO I PRINT ON TWO SIDES?WITH MG3250
Not sure if MG3250 has 2 sided printing option, but if it does, there is a tick box with 'Duplex printing' next to it in 'Printer properties' on 'Quick setup' page. Tick the box!
Feb 27, 2015 | Canon PIXMA MG3250 All-in-One Inkjet...
I was low on black ink and needed to print flyers , the Epson 630 asked me if i would like to continue printing and use other colors , i pushed yes, and have changed out ink and its still prints in r
Is it possible that you accidentally put the wrong colour cartidges in the wrong spots? Otherwise, it should work fine. Also, the printer's default is usually to print in colour, therefore even pages in black and white will usr colour, which uses up coloured ink. Always check the prooerties when printing to switch to b&w:)
Jan 20, 2014 | Epson WorkForce 630 Wireless All-in-One...
Need to print black only but low colour cartridges cause error
Most likely you cannot. If you do not have any of the colour cartridges with ink in them, the print heads will dry out and when you want to print in colour you will not be able to print in colour.
Feb 02, 2012 | Canon Office Equipment & Supplies
I have a new black ink cartridge but my printer wont print because the color ink is empty is there a way to get it to print without refilling the colored ink since i only need black???
When printing in BLACK, a small amount of the COLOUR ink also is used.
This "trick" prevents the COLOUR ink-jets from clogging, due to not being used.
So, you need to have a "good" COLOUR ink-cartridge.
Mar 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Do you have to have colour ink when only printing in black
Yes you have to have ink in all of them. No, accordign to Canon it wil not work without them.
Feb 04, 2009 | Canon i80 InkJet Printer
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
19 people viewed this question
Top Black Office Equipment & Supplies Experts
Walter Dominguez
Level 1 Expert
Lawrence Oravetz
Jude24
Are you a Black Office Equipment and Supply Expert? Answer questions, earn points and help others
