Question about Air Tools & Compressors
3 cyl john deere engine with stanadyne jdb331md2406 inj pump want exploded view to strip down and clean out think plungers stuck.
  • 89 Answers
SOURCE: 1989 Ingersoll-Rand 185 cfm air compressor will not build up air
ITS A POSSIBILITY AND YOU BETTER HOPE ITS NOT SPINNING BECAUSE THE SCREW COMPRESSOR IS LOCKED UP. CHECK THE OIL LEVEL IN THE SUMP AND SEE IF THE ROTOR WILL TURN WHEN NOT RUNNING. TYPICALLY THE DIESEL ENGINE WILL TURN HIGHER RPMS WHEN IT HAS NO DRAG ( NO COMPRESSOR HOOKED UP ). YOU CAN GET THE PARTS FROM INGERSOL RAND OR ANY RENTAL YARD - UNITED, PENSKE, SUNBELT, ETC. THEIR MECHANIC SHOPS ARE USUALLY FOR HIRE AND CAN EVEN INSTALL IT FOR A CHARGE. ALSO MAKE SURE NOTHING BUILT A NEST IN THERE. IF YOU REMOVE THE SCREW, MAKE SURE AND WATCH FOR SHIMS. THOSE SHAFTS NEED TO LINED UP PERFECT TO REDUCE VIBRATION. GOOD LUCK
Posted on Apr 07, 2009
MNfisherman
  • 11896 Answers
SOURCE: drive gear is stripped on ertl riding john deere
www.greenfunstore.com/John-Deere-Toy-Parts.html
They have your parts.
if you googe ertl parts, you will find more sites that carry them as well
Posted on Oct 24, 2009
rwvanlue
  • 486 Answers
SOURCE: Starter solenoid on John Deere (Kawasaki) 17 hp engine
It hooks onto the fork.
NOTE: Remove the plunger from the solenoid.
Move the gear to position the fork as close to the solenoid plunger as possible.
Hook over the fork,
Re-insert plunger into solenoid
'a light film of grease could be applied to the plunger, but not TOO much'
Posted on Nov 20, 2009
  • 5603 Answers
SOURCE: have a john deer engine on a 375 sullair keeps shuting off
You can be very safe by using a diode capable of say 600 volts. You can probably take it to Radi Shack and get one of about the same physical size and be safe. The epoxy diodes typically come at 1 amp size about 1/8 inch diameter, the 3 amp at about 1/4 inch diameter and the 6 amp pnes are about 3/8 inch diameter.
You can also procure these fromDigikey.com and Mouser.com
The diode MAY be transient protection for a fuel shutoff solenoid.
DIODES ARE POLARITY critical so make sure you have it wired correctely.
Posted on Nov 28, 2009
Testimonial: "thank you i have asked everyone this should do it "
  • 183 Answers
SOURCE: John Deere GX85 Riding Mower engine surges
did you drain the gas before putting it away last season? If not, I would drain all of the gas and put in fresh gas, also replace any in line gas filters
Posted on Apr 06, 2010
REPLACE THROTTLE CABLE ON F-525 JOHN DEERE
John Deere Throttle Cable Repair
The above is probably not for your model of John Deer. You can get an exploded view of the section for your model on http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
There, Enter the Model Number and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. You can Drag the View Windows for Better Viewing.
Jun 11, 2017 | John Deere Garden
My brakes are sticking and/or locking up on my john deere 2355 tractor has anyone had this problem and fixed it
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/...J7/Output/OMLVU17926_J716.html
See your John Deere Dealer. Fuel pump not ... Brakes dragging. Misadjusted .... Parkbrake locked. ... Cruise Set/Decel switch is held or stuck on. No cruise ...
Service Engine - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM139226.../OMM139226_A99.html
Warranty repairs must be performed by an authorized John Deere dealer. ... 3. Push down on front of hood to lock latch. ... brake. 2. Stop engine. Allow engine to cool. 3. Raise hood and latch open. 4. ... Remove right side engine shield from tractor. ....Check engine speeds when engine is warmed up and not under load.
Oct 29, 2015 | John Deere Garden
I have a john deer stx38 fuel shutoff solenoid is bad can I bypass this
Unless the solenoid is shorted or opened electrically; or physically damaged have it ultrasonically cleaned. No chemical dip as it will damage the enamel coated wires.
Removing and bypassing can cause exhaust system damage from raw fuel igniting in the exhaust during shut down.
Apr 19, 2015 | Garden
John Deere LA 135 Fuel will not pass through carb. feul is getting to it .
yes solenoids do stick and at $130 for it try and clean it first and at that price i have cut the tip off and just added a manual fuel shut off valve in line to the carb
May 26, 2012 | John Deere Garden
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
May 15, 2012 | Briggs & Stratton Briggs Stratton...
Stanadyne injection pump timing 4.5L john deere diesel engine
  • More Ports: Turn one of your computer's USB ports into four.
  • SuperSpeed Data: Up to 5 Gbps data speeds let you transfer an HD movie in seconds.
  • Ultra Portable: About an ounce in weight and super small, making it easy to grab and go.
  • Extra Durable: Cable reinforcement, sturdy exterior and heat-resistant connectors ensure ultimate durability.
AmanStino Ultra Slim 4 Port USB 3 0 Data Hub white AmanStino
Apr 25, 2012 | Cars & Trucks
Truck cummings 9800 valve settings
On the Celect,you adjust valves & inj on same cyl.The mark A is now 1-6,B is 2-5, & C is 3-4.Valves are Int 0.014 & Exhaust is 0.027.The injector you hand tighten screw until injector plunger bottoms out.Back screw out 2 flats,ie turn corner of lock nut to align with the rivet in the rocker lever(pushtube side),then back out screw two "corners" then tighten the jam nut down.Adjust the Injector first,then the valves.
What is the CPL because it makes a different on injector setting.
CPLs 821,833,903,904,& 806 are 105 INLBS
CPLs 910,827,1185,1188,1210,1211,1256,&1280 are 90 INLBS
CPLs 1374,1380,1395,1405,& 1507 are 125 INLBS
On the STC,you adjust valves & inj on same cyl.The mark A is now 1-6,B is 2-5, & C is 3-4.Valves are Int 0.014 & Exhaust is 0.027.The injector you torque to specs to bottom injector plunger.Then tighten the jam nut down.Adjust the Injector first,then the valves.
On STC it would be greatly advised to run injector flush through the fuel system for an hour to clean carbon off injector tips to prevent plugging spray holes causing a missfire.Cummins sells it in a metal can & you sill need a return & suction line to hook up to engine(one at fuel inlet & one on fuel return) and run it out of the can.
Firing order is 1,5,3,6,2,4
Oct 19, 2011 | OTC 7471A CUMMINS DIESEL ENGINE BARRING...
I NEED INJECTOR PUMP SCHEMATIC FOR JD 400 PUMP
I'm getting hydralic fluid in my engine oil. I was told that it's coming from my power steering unit. It's a JD 400 tractor/backhoe. Would this be correct?
Jun 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere 2020 water pump repair?
Hello:
From your Description it Sounds like a Bad Water Pump Bearing and Seal.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 10, 2009 | John Deere Tractor Side Screen...
Air Tools & Compressors Logo
294 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
