Question about Electric Garden
A wiring diagram for the switch on a Talon Black Hawk 14 electric chainsaw
2 Suggested Answers
  • 403 Answers
SOURCE: A Talon Black Hawk 14 electric chain saw AC
if the motor comes on, but no movement, then the clutch is smoked
Posted on Mar 26, 2011
What fuel do I put in it. straight petrol or mix with oil. cheers pam
It uses an extension cord, a 50 footer would work best. It is not gas operated.
Sep 24, 2017 | Electric Garden
Need a new Talon Chainsaw sprocket for 35cc 35cm Timber Hawk AC3100-35C
most chain saw chain sprockets are either 1/4 or 3/8" pitch
in your case I would suspect it is 3/8 pitch
measure the distance between the link pins ( not the teeth but the pivot pins of the chain itself )
after that the sprocket will be available as a generic sprocket from any chain saw shop or mower shop
Talons went bust but are being reproduced under a new brand name ( ozito I think)
Jun 28, 2016 | Talon 219 Kart Sprocket 62 Tooth
Have dual light switches - one for fan one for lights on fan. incoming to box is white (neutral) black(hot) then out to switches two sets of w/b. fan has one each of the white, black blue(lights). How do...
From your switch box to your fan run a 14/3 wire. Take the incoming 14/2 white wire,and connect to white of the 14/3 wire to fan lite combo ,and hook both white wires from fan and lite. Hook the fan black wire to the black wire from the 14/3 Hook the black wire from the fan to the red wire from the 14/3. Then go back to the switches, and add a black and red pigtail about 4"long to the black wire from the 14/2, now connect the red wire to one side of switch, and the other red wire from the 14/3 to the other side of switch. Do the same to the black wire on the other switch.
Sep 17, 2011 | Garden
Talon grass hawk trimmer wont run on full power seems to labour. How do I adjust the mixture
should not have to adjust mixture, they are factory set to climate. are you running it on choke, or in the run position ?
Apr 22, 2011 | Garden
Hawk talon v3 wont get enough power to lift off the ground after being fully charged. another hawk talon v3 rear tail rutter wont spin to go forward. how do I fix these problems in these two...
I too had the lift-off prolem and I fixed it by gently pushed the upper gear all the way up, using a nail through the bottom of the copter and a hole in the lower gear, while pushing the lower rotor down.
Dec 29, 2010 | Team International Hawk Talon V3 RC Indoor...
Starting Instructions Talon Grass Hawk
i would like insructions how to replace trimes cord
Mar 13, 2010 | Talon Electronics - Others
Talon electric chainsaw, what grade oil?
Hi there... Electric chainsaws only use bar and chain oil. If you go to a hardware store or garden power tool outlet, you will find bottles of bar/chain oil. That is all you need. Just fill the reservoir up and top up as needed. Any decent brand will work well.
Feb 17, 2010 | Talon Electronics - Others
Talon oil feeder wont oil chain 38cc tree hawk
first check the oil filter from the oil tank,the oil hose,remove the oil pump and check it(especially the plastic gear inside,if it worn is because of the bearings from crankcase).Clean the holes where oil goes.
bye savumihai71
Jun 08, 2009 | Garden
What is the radio wiring diagram for 1992 eagle talon
1992 Eagle Talon Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger Wire: White/Black
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
Mar 29, 2009 | 1992 Eagle Talon
Garden Logo
21 people viewed this question
Top Electric Garden Experts
Steve Oakes
JohnPaul Robertson
Are you an Electric Garden Expert? Answer questions, earn points and help others
