Question about GPX D1816 DVD Player
Can not install to telivision, need help with wire connections,do not know what hookups go where lost manual,have three connections on wire,red,yellow and white, where do they go on dvd player and to where on telivision or cable box
    Scholar:
  • 151 Answers
This is very simple
First on the back of your dvd player there should be the holes with the same colors as the cable you have, yellow (video in) in the yellow, red (left audio) in the red e.t.c.
Then either on the side or the back of your tv there should be the same sorta thing, depends if you have a HD TV or a regular freeview/analog tv. With hd there should be green blue red white and yellow, just the same as the DVD player, plug the cables into the right colors as i said,
Same goes for the regular TV, just do exactly the same as you have done with the dvd player,
Switch your channel to dvi or av1/2/3 and your dvd player should be working
Regards
Posted on Jul 25, 2009
Can you get me a diagram on electrical hookup?
Hello;
My name is Peter. I am a retired field service technician.
I do not know if you have a 3 wire or 4 wire connection. For a 3 wire connection you need 15 AMPS at the breaker box. For a 4 wire connection you need 30 AMPS at the breaker box.
Three wire hookup. Center wire goes to N, the other two wires are hot. It makes not difference witch of these two wires go to L1 or L2. The ground goes to the cabinet.
Check the voltage - With a volt meter between L1 & N = 220V, L2 & N = 220V, L1 & L2 = 240. These readings are general. You may get something like 210V instead of 200V
Mar 10, 2015 | Dryers
I cant connect my dish satalite to my ILO telivision, should it be connected to the ATV port or the DTV port.
If you satellite is HD don't connect it to either port, Use an HDMI or component (5 wire cable) so as to receive high def signals. If you must uase channel 3, You want the ATV input. On channel 3 YOU WILL NOT RECEIVE HD PROGRAMMING> check your hookup guide from Dish network.
Jul 09, 2011 | iLO Televison & Video
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
Moving into new home had to buy a 4 wire Dryer cord, need to know how to wire to the dryer
A three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
A 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Here is a link to a very informative site
http://www.applianceaid.com/general.html#3to4
Nov 15, 2009 | Dryers
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
I need to know how to wire the plug into the back of the dryer
Current electrical codes require a 4 wire hookup for all dryers. There needs to be a separate ground and neutral. If you do not know how to hookup the 4 wire version, it is worth calling an electrician to install the correct wires. If there is a problem down the line, the improper installation will invalidate your insurance claim. Dan
Jun 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Roper Dryer
Mar 02, 2009 | Roper Dryers
Need to hookup home theater system
http://www.4electronicwarehouse.com/connectionguides/htib.html
click the link all help with perfect diagrams given just look at it and connect youras as per the diagrams.
Feb 26, 2009 | Samsung DVD-V4600 DVD Player/VCR
Stove
Go to page 8 here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=JKP15AAAA
Essentially, you need a 220 volt hookup kit from any hardware store. Match the plug to your outlet. Several styles are out there. There are three wires in the cable. Knock out one of the holes in the box on the oven. Install a strain relief for the cord into the hole and clamp on the cord. Generally, they're in the kit. The Red and Black wires are 'hot' and white is neutral. The connections are labeled on the stove. Make sure your connections are neat and tight.
Dec 05, 2007 | GE JKP15 Electric Single Oven
GPX D1816 DVD Player Logo
134 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
