Question about Blu Cell Phones
New blu life x2; cant get anything but talkback. no home screen or symbols; can't even volume up/down
Unable to unlock the Nook. Screen lights up but the small green circle which I allign with the lock symbol does not appear. Screen shows correct time and date as well as my wallpaper photo.
Sound like voice activation try and hold the volume buttons till it say talkback suspended press ok a few times quickly and then it will say talkback suspended
Aug 07, 2017 | Apple iPad Tablets & eReaders
My tablet is froze on talk back. Unable to turnoff the talk back nor can I turn off tablet.
Android? Press and hold the Power Button and the Volume Up button until you see the Android logo.
iPad? Press and hold Power button and the Home button until you see the Apple logo.
/or
There are two ways to unlock your device once TalkBack is turned on:
Two-finger swipe up from the bottom of the lock screen. ...
Explore by touch to find the Unlock button at the bottom middle of the screen, then double-tap.
Turn on TalkBack - Android Accessibility Help - Google Support
https://support.google.com/accessibility/android/answer/6007100?hl=en
Jun 17, 2017 | Cameras
How do i turn off talkback mode and reboot the phone to factory settings
You can try the below if you are having Samsung Galaxy phone.
  1. Double-tap on the Settings icon to get to Settings.
  2. Scroll down to "Accessibility" using your two fingers.
  3. Double tap on the switch to turn it off. Talkback is now disabled on your Samsung Galaxy Core
And to reset to factory setting, follow the below steps.
To do a factory data reset, follow these steps:
  1. If your phone is on, turn it off.
  2. Press and hold the Volume up button and the Power button at the same time until the device turns on.
  3. Press the Volume down button to select "Recovery mode." If you need to navigate to the "Recovery mode" option, use the Volume up button to move the arrow and the Volume down button to select it.
  4. You'll see an image of an Android robot with a red exclamation mark and the words "No command."
  5. While holding down the Power button, press the Volume up button and release it.
  6. Use the volume buttons to scroll to "wipe data/factory reset" and press the Power button to select it.
  7. Scroll down to "Yes - erase all user data" and press the Power button to select it.
Your Android One device will erase all of your data and restart with its factory settings. You'll see the Welcome screen just as you did when you turned the device on for the first time.
May 16, 2016 | Cameras
I accidently turned on accessibility and now can not turn it off
Hey Misty,
On some devices you have to double tap the icon or name you wish to enter.
On other devices, you have to double tap the home screen for a pop up window to show you a Disable TalkBack option, which will allow you to go into your settings.
HOPE THIS HELPS MISTY. :-)
Jan 31, 2015 | Blu Cell Phones
HOW TO UNLOCK SCREEN
To Disable TalkBack mode
  1. 1 Go to the home screen of your Samsung Galaxy S3 S4 or Note2. Was this step helpful? Yes ' No ' I need help
  2. 2 Now, go to settings, menu option. There is an invisible button to the left of your home button. Press that button, and select Settings. While in TalkBack mode you will have to double tap to select menu items. So double tap settings. Was this step helpful? Yes ' No ' I need help
  3. 3 Now select accessibility. Share this Share this on FacebookTweetPlusPinShareRedditDigg settings-accesibility.png While in TalkBack mode you have to use two fingers to scroll / swipe to get down to the accessibility menu item. Again, you will need to double tap to select accessibility because you are in TalkBack mode. Was this step helpful? Yes ' No ' I need help
  4. 4 In accessibility you can now disable TalkBack mode. Share this Share this on FacebookTweetPlusPinShareRedditDigg accesibility_-_talkback.png There is also an option here to disable "Text To Speech," which you must also disable. You can disable it here or an alternate method is covered in the next section. You can use either method. If you have trouble with one method, try the other.
May 23, 2014 | Samsung SGH Cell Phones
How do i set my galaxy dx 88 hl so the talkback is on all the time
turn the talkback knob to the right and push it in to engage talkback.when you get the volume you want leave it alone .Now key the mic.You will probably hear a squeal coming from the speaker.Now turn the volume down on the talkback knob until the squeal goes away.If you run your RF gain wide open it may squeal also.
Sep 25, 2013 | Galaxy Radios DX- 88HL Base CB Radio
Orange key appears and cannot open or do anything with AIWA DVD/Video player - How can I get it to unlock and work?
1. Turn the television on.
2. Take the remote and walk up to the television. Press the "Volume Down" button on the front of the TV and press the "7" button on the remote at the same time.
3. Enter in a new PIN code and new customer ID.
Jun 13, 2012 | GE Televison & Video
My tablet is showing the usb symbol on the screen and will not go anywhere cannot power down or anything tried plugging to my laptop and now to the electrical plug still nothing .
Mine did the same thing, son told me to hold the power, home button and volume up button for about 10 second and it would reboot, which worked for me.
Aug 25, 2011 | HP Tablets & eReaders
I have a Connex 4600 Turbo mounted in the headliner of a W900L Kenworth using Wilson 2000 twin antennas and a RK56 mic. When trying to use the "talk-back" feature all I hear is constant...
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Nov 08, 2010 | Connex 4600 Base CB Radio
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Cell Phones Logo
29 people viewed this question
Top Blu Cell Phones Experts
Hjalmer Lamminen
Hjalmer Lamminen
Dustin
Dustin
Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
