Question about Coffee Makers & Espresso Machines
I cleaned my coffee pot a week ago and it is already telling me it needs to be cleaned again.
cactus bob
  • 267 Answers
SOURCE: Coffee pot
durabrand has no contacts outside china this is a unit made for and imported for walmart only walmart is the only contact ...... your problem is not anything you or walmart can do anything about the problem is the cheap plastic that is used , when it gets hot some people can taste and smell it and others cant . .. its getting more common in everthing that heats water .. personaly i would not drink anything from an appliance that puts a plastic taste in my water ..... if you move up in price the problem is reduced , better plastics are used , but your not going to get one for 10.00 ! "you get what you pay for " more now than ever .... good luck Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 05, 2009
SOURCE: ge coffee pot model number 169165 clean mode botton wont shut off
fyi - manual is at
http://www.gehousewares.com/Browse_Product.aspx?content_id=332
SOURCE: cooks coffee pot stopped working
I bought the coffee/espresso maker. The espresso side still works, but the coffee side does nothing. I only had used it for about a week, but that was long enough for me to throw the box. I was going to contact the company but I see that will do no good, so my suggestion is to buy a new one (same exact model) then put the broken one in the box and return it. You will have a new coffee pot, and you won't be out anymore money.
Posted on Aug 01, 2009
Cuisinexpert
  • 61 Answers
SOURCE: DCC-1200 coffeemaker cleaning button flashes
Make sure that when you do the vinegar solution, you do at least 4 cups of white vinegar, and fill it up the rest of the way (max fill line) with water. The manual says to "fill to capacity with a mixture of 1/3 vinegar and 2/3 water," which lots of people misunderstand, and think it means "1/3 CUP vinegar and 2/3 CUP water," which is not the case. It means 1/3 of your 12 cups (and 1/3 times 12 is 4 cups) of vinegar, and 2/3 of your 12 cups (aka, fill it up the rest of the way) of water.
You might have to let it soak for an hour before you try to brew it--this lets the vinegar work at the calcium buildup a LOT better (kind of like soaking your pots and pans before you try to clean them), but it should definitely work for you. If not, call Cuisinart's tech support (1 800 726 0190) and they might be able to get you a replacement :)
Posted on Aug 21, 2009
SOURCE: The cleaning button keeps flashing after cleaning.
We have this problem as well. We simply clean it as directed once or twice with the vinegar and water mix and then unplug for an hour. This resets our machine for several weeks. Based on the number of comments I've seen on this issue, it seems that the "off" sensor doesn't work.
Posted on Oct 13, 2009
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
May 24, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
The cleaning button keeps flashing after cleaning. I have cleaned this with water & vinegar several times, but can only make one or two pots of coffee before the cleaning button begins to flash again....
Oct 10, 2009 | Cuisinart DCC-1200 Coffee Maker
My coffee maker works very slowly after about three weeks of use. Specifically, the water does not pass through the filter and into the pot quickly, if at all. Suggestions?
Try cleaning it with white vinegar. Put in one cup with a potful of water, and let it soak. To get more cleaning, pour the water/vinegar through again, hot. Put in a coffee filter to catch/strain the debris, and you will be able to see if it's helping. When you're through cleaning, pass fresh water through the machine by potfuls, until no traces of vinegar can be detected.
Best regards, --W/D--
Aug 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
My stay or go coffee maker. When I try to make a full pot of coffee I only get half a pot I push it on again and still only get a little bit more coffee. I have to start up about 4 times to get a full pot.
Try cleaning out the water system, it may need to be descaled, buy the descaler from the supermarket, follow instructions, make sure machine is well flushed out with clean water after cleaning operation.
Jul 07, 2009 | Hamilton Beach Stay or Go 45234 Coffee...
Clean button keeps blinking
Unplug the coffeemaker for one hour, and the self-clean light should come off.
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DCC-2000
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
No Coffee
do not fil the pot past 8 cups, you have to give some space for the water to circulate while running the cleaning solution.
Mar 28, 2008 | Faberware FCP412 Coffee Maker
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
