Question about Garden
Bodyworx A115B spin bike tension knob not engaging, how do i repair this? It only works on easy setting and doesn't engage any further
  • 101 Answers
SOURCE: 2000 yamaha breeze 125 starter not engaging
The intermediate cog will spin freely one way but not the other, works on a principle similar to a centrafugal clutch.
Posted on Dec 30, 2008
  • 31 Answers
SOURCE: The tension adjustment does not get difficult enough
If you are refering to a regular bicycle this means the derailer is not making the chain jump from gear to gear. You probably need a new shifter cable or the shifter cable came unhooked from the derailer. I would take your bike to a bike shop to have this reconnected and then they will adjust it for you.
If you are refering to an exercise bike then here may be your solution. From what I have seen on exercise bikes there are three different kind of bikes. I am refering to how there resistance works.
First type has a strap that wraps around the wheel. There is a some kind of a nut and a bolt that holds that strap around the wheel. You simply need to tighten that nut. The strap will stretch over time and that is why you do not have the same resisteace you had when the bike was new. Afer you tighten this you will find that regular tensioner works better.
The Second type of exercise bike has what appears to be brake pads contacting the wheel. Basically your peddaling the bike with the brakes on. Pretty simple concept. Again there should be some sort of adjustment around this pad that is touching the wheel. Probably a screw or a bolt. Some even have adjusters that you can turn with your fingers.
The new and improved exercise bikes have what is called magnetic resistance. This is where your resitance is created by a magnet and some sort of power source such as batteries or your bike being plugged into a wall outlet. If you are using batteries replace them. I found that with my elyptical exerciser new batteries made a world of difference in the resistance settings. If changing the batteries doesn't help then there may be another problem. This could be the computer. Just check your user manual and I am sure you can get it replaced.
Posted on Mar 14, 2009
  • 376 Answers
SOURCE: knob on lawn tractor for blade engagement
Sounds like you need a new PTO switch.
Posted on Jun 15, 2009
  • 202 Answers
SOURCE: drive belt not engaging. need more tension on
does the lever feel spongy when you try to engage it(not solid as it felt new)? usually this is caused by tightening the adjustment screw too far out.if so you brobally have a bad engagement lever on the transmission. the bad news is the lever is not avalible alone. you either have to bite the bullet and buy a transmission or find a junker that dosen't have the same problem.
Posted on Jul 14, 2009
SOURCE: When attempting to start the bike, it will only
You will have to check the starter motor , but have you tried to by pass the soleniod switch?, try to do so by connecting the two points at the solenoid, if the starter truns thn its the solenoid switch which is faulty ..if it doesnt still turn, thn you will have to remove the starter and overhaul it.
Hope this helps!
Posted on Aug 02, 2009
Kawasaki starter not engaging
Hi, Ricky the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starter spins but engine does not crank
Starter spins but doesn start the bike Ex 500 com The home of the Kawasaki...
Starter spins but doesn turn the engine
Mar 22, 2017 | kawasaki Motorcycles
Troy bilt lawn mower
sounds like wrong belt you raise it belts tighter lower belts looser or the tensioner has come loose
Jul 13, 2013 | Garden
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My 2002 neon's A/C blows warm air. The vent pressure is working well- but it blows warmer than the outside air. Can I fix this myself? What might the problem be?
If you are handy, yes you can. Most likely causes are loss of freon which would prevent the compressor clutch from being engaged and operating the compressor, a lack of 12 volts being applied to the compressor clutch because the a/c compressor fuse or relay has failed, preventing the clutch from engaging the compressor, or the compressor clutch itself failing. Easy test is to watch the compressor pulley with the motor running. The pulley will, of course be spinning, but the circular assembly mounted to the front of the pulley will spin with the pulley only when the compressor is engaged. There is a sensor mounted to the a/c line that prevents the clutch from engaging the compressor if there in not enough freon in the system. You could go to auto zone or checker and buy a can of freon r-134 with a hose for around $15.00. It is fairly easy to follow the instructions to charge the system. If, after allowing some of the can to pressurize the system, the compressor clutch engages then you can continue to charge the system. Cold air should start to blow by the time the can is empty. Or you can locate the a/c relay located in the fuse panel, remove its plastic cover and manually close the contacts while observing the compressor pulley assembly. If the clutch doesn't engage then the problem in probably electrical, a fuse, the relay or the electric clutch itself. Go to auto zone and check you their dvd on a/c repair for under $9.00. Hope this helps! Dano
Jul 01, 2011 | 2002 Dodge Neon
My 650 series self propelled is not working. the propell engage cable still has tension but when I grip it to engage it does nothing. It doesn't make any funny sounds or any thing like that. The mower...
I believe your problem to be with belt adjustment. Your engage cable is apparently working because there is tension. Check end of engage cable where it attaches to tighten belt, check to see if belt is broken or close to being broken, or so worn down there is no grip left. You may need to replace belt or just adjust belt. I hope this will ease your up hill struggles.
Jun 14, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Have a Maytag washer LAT9635AAE. It fills with water and does not proceed. The timer seems to move the dial around but doesn't engage the washing functions. At first I thought it was simply not...
Remove the timer and get the outer skin off of it. Twist the timer around and hunt for burn marks on the barrel. I suspect it is the timer. To get it off you pop the cap on the knob and under it is a keeper and spring you remove. Then the knob and skirt will come off and you can get to the screws which hold the timer to the consolethemobilian_29.png
If the timer turns out to be ok then the motor is suspect.
Note: This washer is well worth repairing. Anything out there on the market now is trash compared to this machine. Invest in repairing it. You will be glad you did.
May 18, 2011 | Maytag Washing Machines
Warn manual hub install 2000 f-250
Nov 29, 2008 | 1995 Ford F250
Loose image when focusing
The focus knob can have the play reduced. Turn counter-clockwise a turn or 2, then loosen the knob's set-screw and carefully turn clockwise until a little drag is felt. Then tighten the set-screw.
A further item that may pertain to image shift, especially at low powers, is that the baffle tube that the main mirror slides on, may be loose in the back housing. There have been reports of poor thread engagement due to poor tolerences. That tube can be re-tightened - just be careful not to strip the threads!.
Jun 16, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
