Question about Electric Tools & Hardware - Others
I have achicago electric pwr tls heat gun model #35776 wont turn on can i fix it myself?
2 Suggested Answers
  • 2694 Answers
SOURCE: my kenmore gas dryer model 110.7281201 turns but
unplug the dryer and change out the gas coils,two black coils on valve,coils will work for a while then shut down,when you change them make sure the metal spacer isn't inside the bad coil when you remove it,only the coil with 3 prongs has this,you'll should see it on the post when you remove coil,put the coils on the same way you take them off.vac out the dryer also,lint buildup will also make the dryer take a long time to dry,check outside and make sure the air is blowing open the flapper,if not blow out the vent line with a leaf blower if it's a long run,hope this helps
Posted on Nov 04, 2009
Started smoking, but good water pressure
This certainly is a fault in the electric motor. Try the machine without load. That is...remove gun completely.
If smoke still appears....windings in electrical motor are damaged.
Myself I prefer to change motor than to rewind. More than that...safety is my policy. If in doubt and you see it is going to get expensive, consider a new machine. If possible the same model if you agree. In this way you can turn to your old machine for certain spares.
Thanks,
Fulltech.
May 05, 2012 | Karcher K3.68MR Electric Pressure Washer
Hoe to reboot pdt6840 scan gun
Warm Boot:
- Press the "PWR" button to turn the unit off.
- Press the "4" and "5" keys at the same time.
- While still pressing the "4" and "5" keys press and release the "PWR' button again.
- Release the "4" and "5" button.
- The PDT6846 should perform a warm reboot.
Cold Boot:
- Press the "B", "D" and "A" keys at the same time.
- While still pressing the "B", "D" and "A" keys press and release the "PWR' button again.
- Release the "B", "D" and "A" button.
- The PDT6846 should perform a cold boot.
May 03, 2012 | Symbol PDT6842-NIS632EU Portable Data...
When i turn on the ps3 the main light turns green, yellow then red again
My friend had this problem and fixed it by taking the console apart, removing the motherboard and heating it up, presumably to let any dry joints re-solder. He actually had a friend do it by putting it in an oven but this melted a component which had to be replaced, so I would recommend using a heat gun or alternative if possible.
The same fault has occured on my brothers PS3 and since I have a heat-gun and soldering irons at work, I'm going to have a go at fixing it myself and shall report back when I've attempted it.
What a fantastic peice of machinery, eh?
Jun 22, 2010 | Sony Playstation 3 (PS3) Console
Hi my xbox360 wont turn on i tried to fix the e74 error when i turn it on to overheat it just shut down please help asap.
Josh_Wilson5
In regards to the E74 error unlike the normal RROD the E74 error normally means that the GPU is already damaged. So with the systems that are brought to me with this issue I usually recommend the customer send the system in if it is covered under the 3 year warranty because if the GPU is damaged then it can not be fixed with the DIY kits. I myself have only had one system that had the E74 error not come back after running a fix on it. So at this point you may need to replace the motherboard.
Note there is some walk throughs on the Internet where people have used heat guns to reflow the soder on the RROD fixes. I have not tried these my self as I do not have a heat gun to test with. You may try them but if the GPU is endeed damaged then this will not work.
Hope this helps
Issken
Oct 30, 2009 | Microsoft Xbox 360 Console
Maytag microwave Model MMV5100AA turntable no longer turns. Is this an easy fix? The rest of the Microwave works fine. I think I may have flooded the floor of the microwave with water. It worked awhile...
to be realy honest ,,, yes! but be warned there is a very big capacitor inside this microwave and it will be charged up with 1000's of volts,
if you tuch it, your dead! be warned dont tuch it!!!!!!!!!!!!!!
have you ever seen a stun gun working??? they realy hurt you!!!!
well this microwave has the stun gun's very big brother inside of it and it wont stun you,,,it will kill you!
if i were you i would drop it into the repair man to get him to fix it for you,,, or get a new microwave,, there very cheep now,, is it realy worth killing your self for a fuw bucks?
Oct 25, 2009 | Maytag Microwave Ovens
My bottome dryer wont heat up but the top dryer heats
I have the same problem and called a repair center to fix. They came out last Thursday and and ordered the parts (thermite and thermo fuse). Waiting for a call that they received and ready to repair.
Aug 01, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Td 4212 w Drier is not heating
Check if it still turns but no heat. If it's a kenmore or whirlpool, it's like a fuse in back of dryer. I would need mor info if it's not these models
Jul 28, 2009 | Zanussi TD4212W Electric Dryer
My heat element works but not the fan, tested the motor and its fine so it must be the elctronics. The element will burn out if that fan wont work, how can i bypass the electronics or what component may be...
i have fixed one like this and in my case it turned out to be the shaft from the motor to the fan was broken , so i just reglued the fan back onto the shaft with a really good heat resistant glue and it works fine .
May 07, 2009 | Steinel Intellitemp Heat Gun,...
Nothing happens when you load paper to staple. It is a swingline electric stapler model 270
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
Mar 05, 2009 | Staples Swingline® 36115 Staple Guns Tools...
RCA SCENIUM MODEL # D52W136DBYX1
If it's normal television, with CRT picture tube . then it's Blue gun which went off normally its a solid state circuit which can malfunction. which is located at the back neck of picture tube blue gun out put circuit a transistor or a resistance of 470 K or 390 K Ohms can blow off. or the tube base can loose contact with the blue gun pin.
Feb 06, 2018 | RCA D52W136D 52 in. TV/DVD Combo
Tools & Hardware - Others Logo
74 people viewed this question
Top Electric Tools & Hardware - Others Experts
Jim London
Jim London
R.A. Ellis
R.A. Ellis
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
