Question about HP Office Equipment & Supplies
I have an HP Officejet Pro 8625 printer. I do have new cartridges but don't know how too load them. can you help?
websnail
  • 419 Answers
SOURCE: HP Officejet Pro L7780 sucking out ink of new ink cartridge
Is this a refillable cartridge you're using or a genuine HP OEM...
If it's a CIS, refillable or some kind of cartridge which is not made by HP then chances are the ink nozzle has failed and allowed the yellow ink to leak everywhere...
There are a lot of problems with these 3rd party cartridges and I would never recommend using anything other than a refilled HP cartridge or a genuine one.
Hope that helps.
Martin
Posted on Jul 11, 2009
CW Oly
  • 240 Answers
SOURCE: Problem in cartridge of HP Officejet Pro L7380 All-in-One Printer
Every cartridge needs to have ink in it to print. Even if you only want to print black and white and one of your colors is empty. A dirty little industry secret is that when you print black....it also makes the colors print too...so you get to buy even more ink than you need to!
Posted on Dec 19, 2009
  • 17 Answers
SOURCE: I refilled HP 88 cartridge but printer (Officejet
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Posted on Feb 17, 2010
iron_luiggi
  • 91 Answers
SOURCE: Printer will not recognize the new cartridge installed.
Solution
Follow these steps in the order presented to resolve the issue.
NOTE: If error messages also display on the computer, clear the error messages after each of the following steps. You might have to delete pending print jobs from the print queue on the computer to clear the error messages.
Step one: Perform a power reset
Follow these steps to reset the product. Make sure you connect the product directly to a wall outlet and not a surge protector or power strip.
Press the Power button ( ) to turn off the product.
NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless.
Disconnect the power cord from the rear of the product.
Unplug the power cord from the electrical outlet.
Wait 30 seconds.
Replug the power cord into the electrical outlet.
Reconnect the power cord to the rear of the product.
Press the Power button ( ) to turn on the product.
If these steps resolved the issue , there is no need to continue troubleshooting.
If the issue persists , see the next step.
Step two: Clean the electrical contacts on the printhead and inside the product
The ink nozzles on the printheads might clog if you expose them to air for more than a few minutes. The ink nozzles also might clog if you do not use the product for long periods of time. Follow these steps to clean the electrical contacts on the printheads.
CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components.
Make sure that the product is turned on.
Open the top cover of the product.
Press and hold the OK button for five seconds. The carriage moves to the left side of the product. Release the OK button.
Wait until the carriage is idle and silent.
Unplug the product power cord from the electrical outlet.
NOTE: Do not turn the product off by pressing the Power button ( ). This causes the carriage to move out of reach.
Lift the printhead latch.
Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot.
Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead.
CAUTION: Wipe only the electrical contacts. Wiping the ink nozzles, located on the underside of the printhead, can damage the printhead.Do not touch the nozzles. Doing so permanently damages the ink nozzles, and the ink stains clothing.
Figure 3: Electrical contacts and ink nozzles
1 - Electrical contacts
2 - Ink nozzles
Wipe the electrical contacts with the swab until no ink residue remains.
Wipe the electrical contacts with a fresh cloth to dry them and remove lint.
After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
  1. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product
  2. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
  3. Plug the product power cord into the electrical outlet.
  4. Press the Power button ) to turn on the product. 'Printhead missing or damaged, replace the printhead' displays on the control panel.
  5. Insert the printhead into its color-coded slot. Press down firmly on the printhead to make sure the electrical contacts touch.
  6. Pull the printhead latch all the way forward, and then press down to engage the latch. If the error message indicates that both printheads are missing or damaged, repeat the steps in this procedure to clean the other printhead.
  7. Close the top cover of the product. The product restarts and then prints an alignment page.
Posted on Apr 05, 2010
  • 1218 Answers
SOURCE: HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Posted on Sep 06, 2010
How to fix Hp officejet pro 8625 are problem
Possibly needs a new head and cleaning station
May 23, 2016 | HP Office Equipment & Supplies
How do I put a new ink cartridge in
http://www8.hp.com/h20621/video-gallery/us/en/customer-care/4117382113001/replacing-ink-cartridges-on-the-hp-officejet-6810-and-officejet-pro-6830-e-all-in-one-printer-series/video/
May 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
How do i refill my hp cartriges in my hp 8610 printer step by step.
All refill sets, come with a good description. But before you buy ink, make sure your cartridges can be filled and the chip can be reset. So you won't end with filled and unusable cartridges and dirty hands.
Look here to see how things go:
Ink Refill Kit For HP Officejet Pro 8610 8620 8630 8625 8615
Mar 29, 2015 | HP Officejet Pro 8610 Wireless All-in-One...
HP Officejet pro 8625 stopped printing
Disconnect the electrical plug. Leave unplugged for a couple of minutes. Replug the machine and see if the printer has reset itself.
Jan 21, 2015 | HP Officejet Pro 8620 e-All-in-One...
I have an hp officejet pro L7680 printer and am having trouble finding new 88xl cartridges for it. Will the 940xl cartridges work in this printer
You cannot install HP 940 Cartriges for Officejet Pro L7650 as they are not compatible and the mechanism is different for both the cartridges,
In your printer, the HP 88 fits on the left bottom corner of the printer and the HP 940 cartridges are mounted on the Printhead inside the printer on HP Officejet 6500 AIO.
Regards,Suhail
Apr 19, 2012 | HP Officejet Pro L7680 All-In-One Printer
Can i print with only a black cartridge installed
No sir you can't. Your printer will only print if it has all cartridges installed and at least partially full - I don't know why they do this on new printers, but it's the way it is. Sorry about that! Alex
Jul 20, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Black ink not printing properly on HP Officejet Pro K5400. It's a new cartridge, have tried another cartridge too but same problem.
The print head may be blocked.
Run the cleaning cycle a few times on the machine.
This can be done through the software drivers loaded on your computer.
If this does not help, you will need to replace the black print head.
Feb 14, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
52 people viewed this question
Ben Johnson
