Pump works at the start of the spin cycle but then it stops and all you can hear is the electrical hum and it will not pump out but will keep spinning There is nothing caught in the pump I checked it
catriver
  • 878 Answers
SOURCE: drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Posted on Nov 05, 2006
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
SOURCE: fills washes rinses but wont spin properly or empty out
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Posted on Oct 19, 2007
SOURCE: SPIN CYCLE
Front load Neptune model
Posted on Nov 25, 2007
  • 30 Answers
SOURCE: Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Posted on Mar 14, 2008
Washer agitates but won't spin or drain - makes a humming/buzzing sound during those cycles
check the pump,could have a sock or something stuck in it.usually i would say to check the lid switch,open and close the lid,if you don't hear a clicking sound the washer won't go into spin or drain but if you're hearing a humming sound that's the motor watch this video
http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw it will show you how to get to the pump.pop off the two clips that hold the pump on and remove the pump just pull it backwards off of the motor shaft,now get a piece of wire and strip the ends on it,2 to 3 inches long,unplug the washer before you start to work on it,get your jumper wire and stick it into the wire harness that connects to the lid switch, don't plug it into the ground plug it into the other two wires not the green wire,i'm pretty sure it's the two outside wires and the green ground is in the middle,plug the washer back in and pull the timer out in the spin cycle,if the motor runs and spins you know something is stuck in the pump or the pump is bad,but just to make sure it's not the lid switch and it is the pump put the pump back on and start the washer again if you hear the humming it's the pump or before you pull the pump jump out the lid switch and see if it spins and drains,if it doesn't then pull the pump so you don't have to stick the bad pump back on the washer,all the lid switch is for is so the washer will not run in the spin with the lid open and some washers won't even agitate if the lid is open by using the jumper wire we are bypassing the lid switch to check the washer while it's apart.hope this helps and if you can let us know how you make out so if someone else reads this with the same problem it will help them out too.
Mar 13, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
Final spin cycle I get sud error code or f2, water mostly drained but no spin. When I restart the spin cycle just starts to spin then stops, sounds like it drains some more water then makes a small...
Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
The water will not drain. The tub starts
The pump is clogged. The only way to fix this is to clamp off the hose to the tub and remove the hose from the pump and remove what ever clogged the pump. Expect to get a little wet.
Mar 04, 2010 | GE WBSR3140DW Top Load Washer
Cycle knob just hums
cycle timer needs replaced. Try first cleaning it with electrical contact cleaner. you can get that at home depot or lowes.
Jun 02, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Nov 29, 2008 | Maytag EPIC MFW9700S Front Load Washer
Drain pump starts and stops prior to final spin cycle
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
