Hello,My TV Aint Turning On - Televison & Video
Hello there I have a 6-1 maxview universal silver/black remote and for some reason it aint setting up my panasonic viera tv I put codes in every think could you help thanks
2956,2903,2953,2988. Try these codes. If these not help, try a code search method. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 07, 2013 | Televison & Video
Why isnt my generator turning on my 120 volt blower
i assume the blower works plugging direct to house current.
if so then the blower is probably too big for the generator.
(blower starting current too high for the generator)
Sep 08, 2012 | Pool & Spa
My nokia 5800 motion sensor aint working. may i know from where to dowanload the motion sensor software.thank you!
Hello, road_to_dest. Thanks for your question.
If your phone used to auto-rotate, and no longer does after the update, please try the following.
1) Go to Settings 2) Go to Phone Sensor Settings 3) Go to Turning Control and and uncheck "Auto Rotate Display". 4) Reboot your phone 5) Go back to the "Auto Rotate Display" setting, and check it back on.
If the phone's display still does not rotate, your auto-rotation sensor may be broken, and this is, unfortunately, unfixable.
Best of luck to you! =)
~Q
May 04, 2011 | Nokia 5800 XpressMusic Smartphone
I turn on the ps3 and my tv isnt receiving any signal from my ps3, i have tried switching HDMI imports on the tv and still nothing. The tv recieves signal from other imputs but it only searchs for the...
when turning it on try holding the power down for up to 5 seconds, it should reset display, if it still aint displaying you will have to search on GILKSY YLOD on YouTube
Oct 29, 2010 | Sony Playstation 3 (PS3) Console
Cooling fan not turning on
turn the A/C on and see if that kicks the fan on... if not , there is an issue with the fan motor you should address.
Sep 28, 2010 | 1997 Honda Accord
My xbox aint showing anything on mt tv ive tried my scart and that wasnt the problem i then tried my hdmi it still didnt work ive tried on other tvs too
Is there a game in the console when you start it up? If so, take the game out then retry it..
If not.. Then you're going to have to have this console repaired. I suggest 2 options.. Contact the https://www.newcorp.com/ for an extended warranty to have it repaired or search online for reflowing XBOX VGA Chip.
Apr 14, 2009 | Video Game Consoles & Games
Car ran fine then all of the sudden it died no sputter engine just turned off. now it wont start fuses ok starter ok fuel punp ok but no spark. whats the problem?
IF THE ENGINE IS TURNING OVER EASLY AND FAST IT COULD BE THE AUTOMATIC SHUT OF SENSOR OR RELAY.TRY MOVING THE RELAY TO ANOTHER SPOT SWAPPING IT OUT LIKE WITH THE HORNS RELAY.IF YOUR HORN WORKS.TRY WIGGLING THE POMER SUPPLY TO THE COIL CAUSE IT SOUNDS LIKE IT AINT GETTING FIRE IF THE PLUGS AINT. CRANK AND CAM SENSORS WILL DO THAT DEPENDING ON HOW MANY MILES YOU GOT.
Aug 13, 2008 | 2004 Dodge Neon
Wharfedale LCD3210AF
dose any 1 now how to fix this problem, i turn on my tv the light is just BLUE, the red light aint showing
Jul 10, 2008 | Televison & Video
Hello i am having issues with my tv (rca model #f31226es) it gets horazontal lines flickers then turns on and off untill you turn it off
why yall aint free fo advice you might want to lower prices and stuff man i got enofe money troble with my kid and stuff if you whould give a free trial of your support it might have people mo likely to pay fo it
Jun 01, 2008 | RCA Televison & Video
PS2 on a LCD
You will need to go to your PS2 system configuration screen and change from RGB to YPbPr component video output. The 1920ex (remember to switch source to YPbPr) will then correctly recognise the signal from PS2.
Hope this helps you. I am also a 1920ex user.
Apr 16, 2008 | Sony PlayStation 2 Slimline Console
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
