Question about Sanyo Televison & Video
My Sanyo tv model num dp42d24 turns off momentarily then turns back on wether hooked up to cable box or streaming device? What do you think the problem is
CrazyLarry
  • 173 Answers
SOURCE: Sanyo DS 31520
make sure your got the right cable mode selected through the remote or autual switch on back of tv. if not it youll only see cable channels up to channel 13 that means in is standard tv mode or air. once you selected cable ...run autoprogram and it find all the channels for you. these newer sets, dont bother with looking for a cable switch, its all done automaticly when you hit that autoprogram button but it would be in the menu under setup.
Posted on Sep 06, 2007
SOURCE: Help!!Hook-Up DVDvideo to TV
There are two options. If you already have a VCR, run the RCA cables(red, white, yellow; one audio OK) into the inputs at the back of the VCR and then the single "plug for cable" from the VCR out to the TV's input. You can also buy a device at any electronic store, and even at Big Lots, which does the same, but without the VCR, just the inputs and outputs.
Posted on Nov 12, 2007
  • 979 Answers
SOURCE: sanyo mts stereo tv
This set is not compatible with the new digital standard. You'll need a converter box to receive off-air signals...accordianman
Posted on Feb 19, 2008
  • 75 Answers
SOURCE: I was watching my tv (sanyo) with cable hooked to
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Posted on Mar 06, 2009
maatmartin7
  • 1213 Answers
SOURCE: I have a Sanyo Tv
You will have to purchase cable that was once used to connect an older VCR to the TV. This cable connector will go into the RF connection of the TV to the RF connection on the cable box. If the RF connector you are looking for in the back of the TV is gone...you will have to find a TV tech to attach a new RF connection to the tuner of this TV. Hope this will help with a solution!
Posted on Feb 13, 2011
How do I run a channel auto scan?
There are many different ways, because each TV manufacturer calls each menu option something different. In your TV menu there should be an option that says Set Up, or Channels, or something similar. Your TV should be, Menu, pan right to Channel, select whether you are using Air (air meaning antenna, picking up channels that are broadcast free over the air) or Cable (only if you use cable with no box). Then the option below should be auto scan. Allow to run completely. Sanyo DP42D24 User Manual Channel
Apr 06, 2015 | Sanyo DP55D44 55" 1080p 60Hz LED HDTV
How do I find the remote code for a sanyo tv
The code is in your unidentified remote.
Oct 23, 2014 | Sanyo Televison & Video
The code for Sanyo TV
0101 0102 0107 0131. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 23, 2014 | Televison & Video
I HAVE A SANYO LCD TV dp42d24. wANT TO ENHANCE SOUND WITH EXTERNAL SPEAKERS. THE RED/WHITE ON THE TV BACK SAYS audio input. i WANT AUDIO OUTPUT
There's probably a digital audio output you can use if you have a digital receiver. If you don't have a digital receiver you can take the audio out from the cable box or satellite box. Since I have an old analog receiver it's the way I connect my equipment. I use a hdmi cable for the TV so it frees up the rca output jacks on my cable box. Works great.
Aug 25, 2014 | Televison & Video
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
While watching tv on our new 42in.lcd flat screen and hooked up to our new hd cable box from comcast there are intermitent total signal losses from 3-5 seconds . Tv says searching for signal for a few...
yes we have to do a process of elimination to fix or narrow the problem down. try another box and see the results.if box work on another tv then u have tv problem
Aug 17, 2009 | Polaroid FLM-2632 Television
I was watching my tv (sanyo) with cable hooked to it. The cable all of a sudden went out. I tried hooking up the dvd player and the tv is no longer recognizing the cable box or dvd player. I don't know...
Mar 06, 2009 | Sanyo AVM-2506 TV
Sanyo mts stereo tv
Feb 19, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
