Question about Zenith Televison & Video
How do set the tape speed on a zenith vre 200 vcr
  • 10 Answers
SOURCE: Toshiba M674 Lost Remote can't change tape speed
Is this an older VCR? If you can set the timer on the VCR itself
like on an older model you can set the timer and set it to record
in another speed. But if you can't do this. You are stuck at
recording in sp. If you can set the timer, if you make just
one mistake it may not come on at all. That's why vcrs
are not as reliable as dvrs. if you don't want to miss a show
diffinatly make sure you re at home and see it come on
like fill up the whole tape and put the show on the end of the tape. like a 2 hour movie comes on a 8pm-10pm set the
timer at ep speed to come on at 4:05pm- 10:05pm and put a 2 hour tape in it. in ep it will record for 6 hours. tape will stop
automatically so you will record it, and it will be on the tape
at the end. that's the way i do it. if I'm not going to be at home
if i really don't want to miss a show at all. because when you set the timer it still might not come on if you see it on you know
its going to record it.
note its cheaper to just buy a new vcr than buying a $72 remote.
you might as well do that if it is a newer model.
I bought an older model vcr in a thrift store for $10 and it worked good for a year for recording shows. I got lucky I guess.
it didn't have a remote I use the timer to set the ep speed
to record.
Posted on Nov 13, 2007
  • 979 Answers
SOURCE: taping speed
No...accordianman
Posted on Feb 15, 2008
SOURCE: ZENITH VCR TAPE KEEPS EJECTING
Happened to me last nite wi 2 old tapes - the end of the tape came off the right wheel when it rewound - that was the cause - look up how to fix tapes by taking the casette apart - only thing I cant find is a picture of how the tape will feed between the heads inside he case since i suspect the tape will have fully rewound
Posted on May 26, 2008
Danmart
  • 291 Answers
SOURCE: dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
Posted on Aug 16, 2008
  • 19 Answers
SOURCE: I have a Zenith DVD/VCR and I am recording a tape
unless the security camera has a setting for recording the date stamp you probably can't. The camera probably has a setup tab to enable embedding the date stamp on the video.
Posted on Nov 14, 2009
Nov 14, 2009 | Zenith XBS448 System
Copying VHS tape to DVD
Hi.
I'm sorry, but according to zenith xbv323 VCR/DVD combo user's manual page 24 you can ONLY copy DVD to VCR and not the other way
Feb 26, 2009 | Philips Magnavox DVD/VCR Dual Player
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Dubbing from vcr to vcr
May 24, 2008 | Zenith VCS442 VHS VCR
Need to play a T-160 recorded in slp at normal speed to watch
This is automatic, as the record speed can only be manipulated, not playback unless youhave that setting which I have never seen,
May 11, 2008 | Zenith VCS442 VHS VCR
Unable to record
if you have a cable or sat box, the vcr should be on channel 3 to record. if this setting is right, check to see if the tab on the left side of the tape is broken off. if it is, just put a piece of tape over it
hope this helps
wg
Feb 11, 2008 | Zenith VRC420 VCR
Got pets or young ones? This problem just smacks of having something lodged inside. Could also have come from a label coming off inside, too...accordianman
Jan 19, 2008 | Zenith VCS442 VHS VCR
Tape Speed
Most late VCRs of the last 10+ years had just basic operating functions with the VCR mounted buttons. Setup of timed recording, and other advanced functions require a remote box, either the manufacturer original, or a universal unit which specifically is able to do advanced. Not all universal units have that capability, so if you go to your local electronics store, check this out carefully. Manufacturer remotes are available: Look here- http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=6711R1N051A Zenith may offer their own universal remotes- again, check them out for the capabilities required.
Sep 26, 2007 | Zenith VRD4235 VCR
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
to record.
Nov 22, 2006 | Toshiba M674 VHS VCR
Televison & Video Logo
19 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
