Question about Dryers
There are three wires loose in my Bushnell trkr t1250l flashlight... Red white and a black!!!! Which one goes to bt-? Which wire goes to r-? Which one goes to L+?
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
  • 4 Answers
SOURCE: I have a Hunter 27185
you can use the red or the blk for blk,wht red
Posted on Mar 31, 2009
  • 34 Answers
SOURCE: i have a black, white, red and a bare wire in the
black goes to black. white goes to white. red goes to blue. there should also be a green wire attached to the fan near where the other wires come out, if you do it attaches to the bare wire
Posted on Sep 09, 2009
jyackle5
  • 8197 Answers
SOURCE: Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Posted on Jan 02, 2010
  • 736 Answers
SOURCE: I have three house wires supplied- white, red, and
make sure power is off before working on the fan wiring ..(trip circuit breaker)
here is what the house wires are
1. black is hot (power) all the time .. its normally connected to the black wire of the fans speed control switch .. that is normally operated by a pull chain ..
2. red is the same power as black except it comes from a wall switch .. this would be connected to the blue wire in the fan (that goes to its light) .. that will allow you to turn the light on an off from the wall switch ..
3. white is neutral .. it connects to both white wires inside the fan .. one goes to the fan the other goes to the light. .. if there is more than one light bulb then there will be more white wires .. hook them all together and to the white house wiring ..
4 then there is safety ground .. usually green or bare copper ... that is connnected to either a green wire inside the fan or bolted to the metal of the fan (often a green bolt is provided) .. the green wire is not required for the fan to run but is required as a safety to make sure no one gets shocked on the fans metal parts ..
after you wire the fan ..then turn on the wall switch .. if the light doesnt light then pull its pull chain until it does .. you can then tie up or remove that chain to prevent anyone from changing that position since you can now control the light from the wall switch you dont need that chain anymore .. the fan should come on slow med and high then off .. each time you pull its chain ..
Posted on Jun 07, 2010
How to re-wire the flashlight Makita BML185
You have a battery a globe and a switch. It really only matters matter if you keep the circuit board(CB). Here's how mine was wired.
Red - Battery pos to switch to bottom of CB (BT+)
Red - top of CB (BU+) to pos contact pivot
Black - neg contact pivot to top of CB (BU-)
Black - bottom to CB (BT-) to battery neg
Or you could just bypass the CB altogether, wire the black to the black, and the red to the red. done.
Jul 31, 2012 | Makita 18V Lxt Lithium Ion Rechargeable...
Own a Heath zenith sh 5105 motion detector flood light. I wired it to plug into an outlet. Flood light comes on when I plug it in and stays on. Seems as if the sensor isn't working. Do I have it wired...
look to see how you have it wired, most sensor lights have many wires to put together, if it is not wired already from factory, you need to look to see how you have it wired, most sensors have three wires one black one red and one white, black wire goes to power, red wire goes to lamp, white goes to neutral, after all is wired you should have only 3 wires a black a white and a green, black to power white to home neutral and green to ground
Oct 31, 2011 | Home
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
I'm trying to install a GE digital timer (model number 15086). The timer itself has three wires (red, black and white) and the light switch has two wires, one red and one grey. How do I hook this up? BTW,...
the extra white wire from timer goes to the group of white wire ganged together in rear of box. you need to connect a jump wire to tha group and lead to timer. grey wire goes to black. red to red.
Dec 20, 2009 | Hardware & Accessories
New fixture, flourescent light controlled by switch. There are two bundles of three wires into connectors, one is black,one is white. Two single wires, one white,one red. Light has a black,white,and...
There should be two wires at the bottom of the fan that are loose ends ,, these wires connect to the two loose wires from the lighting kit, white to white and color to color .
Nov 18, 2009 | PROGRESS Lighting Ceiling Fan
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
The plug that connects to the alternator has three
Yes the White wire is the reason. It goes to the Internal Regulator.
As you view the connector that plugs into your alternator, look at where the lock tab is.
Lock tab on TOP. The Black wire goes to the Left side. The White wire goes to the Right side.
The Black wire, ties into the Red wire down in the wire loom. (The Red wire goes to the starter solenoid, and this is connected straight to the battery. This is why the Red, AND the Black wire, are both Hot wires)
The White wire goes through the bulkhead wire loom, and to the bulkhead connector.
(Down under the steering shaft, and on the firewall, you'll see a rectangular Black box shape, with a Bunch of wires, coming into it from the engine compartment. The bulkhead connector is two pieces. Following it through the firewall, the other side of it is the fuse panel)
Where the White wire connects in the fuse panel,
it should go straight to the ACC fuse. (Accessory)
May 15, 2009 | 1987 Chevrolet Camaro
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Basic wiring for craftman garage door opener
from left to right..
1. red. to wall button
2. white . common to wall button and white wires of sensor.
3. black. white with black strip of sensors
Jul 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Dryers Logo
128 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
