Question about Cell Phones
Phone started to power off, then stopped, will not turn on or off
Pop ups saying certain items are not working i.e. google etc
Willie_watt
wake the screen then press the power button to start power down. Then long press the pop up power down button til a prompt appears to reboot into safe mode. Select ok and then use your phone in safe mode. If it works without those errors then there is some app affecting your other functions of your phone.
Have you disabled apps on your phone that came on your phone?
Mark
Motorola Support
Mar 12, 2015 | Motorola Moto G (2nd Gen)
The process com.android phone has stopped unexpectedly. please try again. This message comes up on 90 % of my incoming calls. Force close ? Any ideas Thanks
I would start with a Master Reset. That's the best place to start.
Pulling the battery doesn't really do anything but fix little problems.
Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state. Press HOME > MENU, then tap Settings > Security > Factory data reset. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the HOME, END CALL/POWER, and BACK buttons. The reset process will start after a few seconds
Mar 29, 2011 | HTC Hero Smartphone
End/power button on samsung sght429 doesn't work, can't turn on
i have just started having the same problem with my samsung sgh-429, have you found a way to bypass the problem? it would be a huge relief to get the info off the phone before upgrading.
Nov 13, 2009 | Samsung SGH-T429 Cellular Phone
Wont stop truning on and off
Take out the battery for an hour or so, then replace it. If the problem persists hold down the power off button (usually the end call button) for as long as it takes for the phone to turn off. If that turns it off, wait a few minutes and power it on again.
Hope this helps, let us know?
Sep 03, 2009 | Samsung Behold Cell Phone
Hey good day :) my moto v3i just stopped
my moto v3i just stopped turning on. everytime i press the power button, the keypads just lights for about 1 second ands then turn off again. i tried to use the combination key, POWER BUTTON (+) * (+) # and then the screen displays the BOOT LOADER thing so i thought this phone might be ok
Jun 05, 2009 | Motorola Mobility RAZR V3i Cellular Phone
My phone stopped working. I checked the battery
Check that the base station has power and then place the phone on the cradle on the base station for a minimum of 20 seconds this will reregister the phone security code. If the phone does not start charging or the base seems dead then check that the power pack for the base station in plugged in and turned on.
Apr 13, 2009 | GE 25952EE1 Cordless Phone
Phone won't ring or vibrate and keys click and beep when pressed
I brought my phone in to my service provider and they removed the battery and sim card (because I was unable to turn of my phone with the power button) and rebooted the phone. It's all good now.
Mar 19, 2009 | Nokia 2600
Htc touch diamond freezes on start-up
I called and spoke to HTC ..apaprently there are issues with some of the handsets .. and its power related ... the best this is to do 2 things to solve any number of issues....
A: Get a replacment battery, and recharge it fully without turning the phone on. So plug it in and charge it until the white pulsating light is fully lit and not 'breathing' ..as they say. Once fully charged then turn on your phone...
B: Once on ... 'hardware' reset it -  (you turn on the phone, holding the volume down button, and the hang up button and pressing the 'software reset button, at the same time)
Should solve it ... IF it dosent .. and your getting the same issues after battery replacment, software and hardware resets ...you've basically got a 'hardware' issue with the phone in which case you need a replacment or repair... (make sure your phone is insured)
Hope that helps folks...
p.s. My phone eventually stopped charging ...nothing, no power so i sent it back for a replacment which im waiting for to arrive...
Nov 17, 2008 | HTC Touch Diamond Smartphone
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
