I have a 60" samsung, 3 years old Model # un60fh6003fxza. When i turn it on, it works for about half hour. the sound stays on, but the picture starts blinking off and on. Is this fixable?
  • 9 Answers
SOURCE: no pic, no sound
Power light blinking mean that the internal power supply is not working correctly. Often the internal power supply itself need to be repaired ( usually a one hour work if spare parts available). Another basic circuit in the TV can be short circuited due to a component failure and consequently cause the internal power supply to block everything. A routined pro must be able to tell you within short time cost of repair and spare parts. Up to you to then decide wether or not have this set repaired. Be aware a pro will ask you a fee for this service, even you don't want the set to be repaired.You can save some cost if you bring your TV set yourself to the repair-shop. The kind of problem is not really age-related; if your TV is running daily 16 hours, with many on/off switching, and particularly in a cool place can degrade some components within warranty time.
Posted on Nov 07, 2006
SOURCE: SONY XBR 60" STANDBY
Check the door for the lamp...over time mine distorted from the heat, and this was an error code for the door now being closed. Temporarilty I wegeded something in there to hold the switch closed, but ended up replacing the door.
Posted on Mar 14, 2008
pra0099
  • 153 Answers
SOURCE: Samsung TV , black screen
Check for the timer settings if possible reset to default......
Posted on Sep 28, 2009
  • 5 Answers
SOURCE: LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
Posted on Dec 13, 2009
  • 732 Answers
SOURCE: My Samsung 2493HM Monitor wont turn on, the blue
sales660, Monitor should not be doing that!!! Use Samsung warranty if available. Complain about "premature failure". Examine black screen for very faint displayed image with aid of bright flashlight(test all owners of CCFL back-lit lcd displays should know) to determine full or partial SMPS shutdown mode. Read more in my fixya profile for more that you can do. It could be bad capacitors or a thermally intermittant solder connection that you or qualified electronics tech will need to fix if warranty not option. After reading and surfing net you will understand your CCFL back-lit lcd display and how it works. Your monitor no different than ANY other brand of CCFL back-lit lcd monitor in it's basic design and operation!!! 12fixlouie
Posted on Mar 07, 2010
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services (relampit.com) and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
