It shows 1 p sd when you turn on tv. Don't know what to do to get direct to work.
I recently bought an Xbox 360 and plugged it into the back of my TV. However, the TV refuses to show anything from the Xbox 360. I tried Autoprogramming it, and it erased all of my channels except for 1,...
MOST of their older sets are set up where the AV inputs are channels 90-93 ; if you had no signal other than the game the set will skip all those channels out.
If you have a working remote for it direct enter 90-93 one at a time .
Nothing hooked to cable fitting means set will see no signal and skip them out when auto program is engaged.
Sep 23, 2011 | RCA F25254GY 25" TV
I'm trying to fix my 21 inch JVC TV, its on standby mode i detected the problem it was Horizontal output transistor, when i replace it with new one it work but after 24 days it got shorted again so i...
depending on circuit design in some TVs when flyback becomes defective then (1) only flyback gets deffective or (2) flyback & 1 transistor big in size fixed near flyback gets deffective or (3) flyback,big transistor & resistor or diodes or some times ICs will get deffective flyback replacement is compulsory + which ever components gets deffective ....... usually flyback gets deffective after 4yrs (between 4yrs to 12 yrs depending on TV brand & usuage ) in your case along with horizontal transistor replace flyback also ..................... Remove that flyback from main board ? using marker make a mark (1 dot on knob & at the same line put another dot on flyback --- these 2 dots should be in same line ) on all the knobs on fly back turn all the knobs one by one in anticlockwise direction slowly until it stops .... Then observe from the mark which you made before turning .. --- you will get an idea which knob howmuch it was turned in anticlockwise direction.... now take flyback to electronic shop & buy same type ( equivalent will not work ) the shop itself check part number , number of pins & their position of old flyback with that of new flyback ----- everything should match 100% - nothing less nothing more .... it should be exact .... check many turn all the knobs of new flyback in anticlockwise direction very very very slowly until it fix it to mainboard very slowly & carefully....don't forget to connect red wire from flyback to TV TUBE ...again iam repeating don't forget to connect red wire from flyback to TV TUBE .... Now observe mainboard carefully whether any connector is not connected connect only tv powercord & stay at a distance & switch on Tv for 2 seconds & then switch of immediately....during this 2 seconds TV gets on & led also gets on continuosly (won't blink) & there should not be any smoke or sounds on main board ...this confirms you have replaced flyback without disturbing other components & not shorted any joints..... so now again switch on tv ..wait 3 or 4 seconds ...led will be on but there won't be any picture ... Don't worry the beginning you have observed howmuch knobs on your old flyback were turned in anticlockwise direction....remember..? see your old flyback again.... Now using suitable screew driver turn all the knobs on new flyback in clockwise direction one by one very very very slowly ...untill as it was in old flyback ( approximately ) --- remember TV is in on condition ... means high voltage will be there ... bymistake if you touch any part of the tv .. you will get very severe shock.... So be very very very carefull while doing this adjustment observe what is happening on the screen - how brightness is changing ... Now switch off tv....connect signal ( antenna or dvd or cable..) & again switch on TV now depending on brightness & clarity of the picture ..looking at the tv screen again you have to turn 1 or all the knobs on flyback either in clockwise direction or in anticlockwise direction very very very slowly ..once you start doing this adjustment practically then automatically you will come to know which knob should be turned . in which direction - & howmuch it has to be turned .... But remember this adjustment is very important .. Sometimes it will take 30mins to finalise the exact position.of knobs .. so take your owntime & finalise the exact position of those knobs..then switch off tv ..fix back the tv cover .. then switch on tv again ....that's all .......100% GUARANTEE again your tv will work normally ....vishnuswamy_23.jpg
Aug 31, 2011 | JVC Televison & Video
The New TV.don't come on, keep showing no signal, don't know what is wrong, can you help us, to get it going. thank you
The TV is turned on. The TV showing "no signal" is an indication that is turned on. Its just that the TV is not recieving any signal whatsoever from an antenna, DVD player or dish.
I suggest you connect thee TV to a DVD player. Click source on the TV remote to AV 1. Use a RCA (yellow white and red wire) for the connection.
Yellow stands for video and white and red stands for audio. Connect yellow to "vidoe out' from the DVD player to 'video in' at the back of the TV. Do the same for the audio white and red.
Now there should be a display on the TV. If there is not display, check your connection.
Let me know if need more help.
Your sincerely.
May 13, 2011 | Televison & Video
Whar channel should be on to play a DVD?
It depends on which input you have the DVD plugged into. The pictures below show the different inputs. One of those should match what you see on the back of your DVD. If you don't know which, you can turn on your DVD player and hit the INPUTS button shown on the picture of the remote control shown below. Or, if it's connected to one of the inputs pointed to by the DIRECT SELECT arrow on the picture of the remote control, you can go there directly from watching the TV. phillip_d971_1.jpgphillip_d971_2.jpg
Apr 12, 2011 | Zenith Z50P3 50 in. Plasma TV
TC-32LX24 slide show goes into screen saver with gray background and VIERA showing. Also, the effects are not working automatically. If the picture is manually changed, then the effect will work one...
Sounds like soft player problem. If this is directly from SD card on TV, then must be it. <br />Fix:<br />1) quick: - use HTPC or HDD external media-player. <br />2) slow - go after Pan tech support to upgrade the frimware (customer reps are useless).<br />
Aug 04, 2010 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
Moultrie MFH-DGS-200 .... says SD Card Locked on
ck postion of switch on side of SD card...should be pushed toward contacts
Oct 23, 2009 | Moultrie MFH-DGS-200 Digital Camera
I donĀ“t known how watch videos on SD card - Jensen vm9512. Format
yes you can watch video
I alredy did it in my jensen
all you have to do is:
xvid avi
video codec: mpeg4
video bit rate: 887kbits/s
video size: 576x320
aspect ratio: 16:9
set this setting in total vide converter
do the convertion and that's.
Mar 19, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Navigon 7100 Fatal Application Error
I had the same problem with my unit.
Did you try to reload ALL the files back to the memory card?
This as a slow process,but it seems to go a little faster if you use a card reader.
Format card using FAT option,not FAT32.
Hope this helps
Jan 21, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Hi I am trying to connect my sd box via my video player or so it works any where, I dont know where the plugs should go, been trying for two hours. I know it works as my partner had it going earler, but...
I fixed this myself, I pluged the av cord directly from the sd box into the video input, the scart into the tv dvd, the rca into the video from the sd box then from the video rca to the tv rca, works a treat
Nov 16, 2008 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
