Question about Vacuums
My rainbow vacuum is not getting power to the motor
It worked perfectly last time I used it, no issues at all. It has never given me a moment of trouble, plugged it in tonight and it seems to not have any power at all to the motor. I've tried different outlets, so that's nt the problem. Does it have a reset button?
Noggin
  • 944 Answers
SOURCE: Rainbow Vacuum Model D3B
If it won't work without a ground wire, but still works with one, then you must have a ground/earth connection to make it work - it sounds like there is a safety device that needs an earth to release, you could almost certainly bypass this relatively easily, but it will be there for a good reason and that would be dangerous. Bearing this in mind, regardless of which 2/3 prong adaptors you use, without an earth connection it will not function without risk probably of electric shock from the case or damage to the vacuum, else the safety device would not be there. Get an electrician to your home, and make him install grounded sockets where necessary (should be all, but at least get a couple). Ungrounded/unearthed domestic power sockets at all domestic AC voltages are lethal eventually, to man or machines. A lot of devices don't need an earth, but especially something with a big motor or a metal case usually does. At least ask a local electrician what he thinks. If you want to do it yourself, an Earth circuit in your home is not too hard to achieve if you have basic wiring skills (and access to the ground floor), but most insurance would dislike the idea - if you want to - post again and I may talk you through it. Hope this helps :) Please be careful :(
Posted on Mar 24, 2007
SOURCE: My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Posted on Jul 13, 2008
nwj2468
  • 76 Answers
SOURCE: Bissell won't turn on
the motor could be ceased up. do you hear a buzzing noise? if you dont hear a buzzing noise, turn it on for about 1 minute, unless it starts smelling hot or starts smoking. if nothing happens after that, try replacing the power cord.
Posted on Apr 19, 2009
  • 4 Answers
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Posted on Jun 07, 2009
  • 11 Answers
SOURCE: Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
Posted on Jul 03, 2009
Why won't my Rainbow E Series won't turn on?
It sounds like your motor is probably dead.
You would need a new motor if the Rainbow is getting power and the power nozzle works.
You can find a new motor here:
Rainbow motor
GoodVac.com
800-775-6586
Jul 29, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow power head works but canister dont model d4
Chances are the motor died or went bad.
You would have to get a new motor.
You can find one here:
Rainbow D4 SE motor 120V
Or a more cost effective refurbished D4 motor unit here:
Rainbow D3 D4 SE motor unit
GoodVac.com
800-775-6586
Jul 04, 2014 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow E Series Vacuum won't turn on at all after it just worked fine
Allowing to sit on water pan for only 3 hours is not going to kill your Rainbow by itself. If there is no more information to this issue than what you described, the problem could be the motor is going bad and the thermal cut off is tripped. Possible reason it didn't do it while you were running the unit, is the motor cooling fan kept the temperature inside the motor just below the tripping point and then when you turned the machine off, this allowed the temperature to creep up past the limit and trip the thermal cut off.
RainVac
www.rainvac.com
800-523-0510
Oct 01, 2012 | Rainbow E series Canister Wet/Dry Vacuum
What happens when i run my rainbow vacuume without water ?
The Rainbow must have water as this is the only way it filters the dirt before the motor. If you don't use water, all the dirt will go through the motor and could create serious issues. We have a cleaning service that will clean your Rainbow inside and out making it like new. Call us for details.
RainVac
www.rainvac.com
800-523-0510
Jul 19, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vacuum head squeels
Your motor or brush roll needs repaired or replaced. The eSERIES has had several different versions and there is 2 different motor possibilities. Give us a call when you are able and we can walk you through on how to determine what version you have.
RainVac
www.rainvac.com
800-523-0510
Mar 24, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum, about 5 yrs old (bought new, no issues prior) - my 6yr old tipped it on it's side while water was in basin. Now when I turn the power on, it makes a very loud sound in the motor and you can...
Although a wet/dry vacuum, it cannot tolerate water in the motor. Water will cause the motor to short out, which will cause the motor to act/sound like yours does now, if it continues working at all.
To prevent additional problems, the vacuum needs to be taken to an authorized Rexair dealer for cleaning and repair. Expect at the very least to pay for a new motor and installation.
Problems like this are why I don't care for any wet/dry vacuums, especially spendy ones.
Oh, you should definitely discontinue use, and don't attempt repairs on your own. Special tools are needed, and if bolts and screw are rusted, breakage may result.
Feb 27, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E2 2 speed vacuum motor whines at startup
I used to sell rainbow vacuums and this latest 2 speed model does whine when it is first turned on. So you definately have nothing to worry about. I believe this is due to the fact that this motor is much more powerful than in the previous 1 speed E series model. I finally just purchased a 2 speed model after many many years of wanting one. Good luck to ya and enjoy your clean house!
Feb 18, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
Power head Motor
type rainbow vacuum parts in your search browser and there should be tons of sites where you can get the parts .if you want to call all-type vacuum and janitorial supply its 314-275-8006.ask for lisa she can probably get it for you.
Apr 30, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Older Rainbow Noisey
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=576894
Older Rainbow Noisy
Posted by Capt_Troll on May 06, 2008
I Have an Older Rainbow (i think it's a d4)
my Old roommate ran it once without water.
it Still works now (with water), but
it's Very noisy on start up
Also I Can't seem to remove the separator (no instructions) but the nut at the end of it appears to free spin the motor when i try to turn it.
Can I Take this apart and Clean/lube it? And if so how? Or is this thing on its last legs? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow D4 is an older Rainbow Vacuum and the part where the separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. Other wise the Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit as well. Watch out… the repair of the Rainbow D4 may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
