Question about Home
I need a pegasus GA58, B5022 toilet lever / handle
Toilet tank pegasus GA58 B5022
  • 21 Answers
SOURCE: faulty pegasus toilet
a local plumbing supply company with have acsess to a company called master plumber wich will have your part.  you can also go on line and talk to the manufacturer and complain.  they might send you the parts for free.
Posted on Jun 23, 2009
  • 297 Answers
SOURCE: pegasus HET toilet splashes water when it flushes
make sure the fill valve is not cracked,that's the long tower looking thing on the right side of the toilet when you stand in front of the unit. you can replace this part at homedepot. it is called a fluidmaster 400A.good luck.
Posted on Jul 27, 2009
  • 11 Answers
SOURCE: Pegusas toilet.
I have the same problem .... I took it apart and found that there is not any screws, nuts bolts, washers .... what it is (was) is a piece of lead (like a sinker on the end of a fishing line) attached to the end of the cable, yes the cable, that hooks into the handle and into the top of the flush mechanism - that yellow plastic tube )the cable goes through it) I was able to take it apart and repair the end of the lead weight with a split shot sinker BB - is the size I used. I also had to deform and cut some of the sinker away since the hole it sits in, is small. When I went to Home Depot to buy/get a repolacement unit, one store told me to call the manufaturer -- Foremost and gave me the number, I lost that piece of paper now that I have time to call again, I was left on hold for 10 minutes the first time. 1-888-256-7551 http://www.foremostcanada.com/warranty.php
I just called and pressed a few buttons, waited 2 minutes, got a live person, she asked me what was wrong, I told her that my handle was just spinning, she asked for my model number 131-926 (found on the inside back of the toilet) when I purchased it (make this up, within this year ... and yes you have the receipt - she never asked for it, just that I had one!) she took my address down and gave me a client number .... tada!
Posted on Dec 16, 2009
  • 150 Answers
SOURCE: Toilet flushing problem!
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Posted on Jan 20, 2010
SOURCE: The lever (handle) to flush
I had this issue as well with my toilet. My chain was unattached and had been sucked down the drain under the stopper valve preventing the toilet stopper valve from completely closing and causing the water to continually run. After re-attaching the chain I noticed when I flushed the toilet that the handle did not rise again until I manually pushed it up. After readjusting the chain to a tighter position where the chain was not floating at all but instead holding the stopper valve in place I again flushed to check the reaction. This fixed the issue of the water continually running and also the handle not resetting itself properly.
Here is the steps I took to resolve my issue:
Step 1: Remove the lid off of the tank.
Step 2: Check to see if the chain coming from the Toilet Handle to the Stopper Valve is loose, unattached, or broken.
Step 3: Flush the toilet and check to see if the problem has been fixed. If not readjust the chain to a different position and flush again.
Step 4: If all is resolved replace the tank lid.
Other possible things to check:
Check the Float Ball to see if it's Half-way or more submerged in the water. If it is it needs to be replaced.
I hope this helps!
Posted on Nov 08, 2010
Pegasus toilet tank Model # 840565. Handle is cheap plastic and breaks about once a year. Super glue works OK, but would like another handle. Can't seem to find it on the web.
You should be able to procure a side mount toilet tank handle at most any of your local plumbing supply store, it shouldn't have to be 'Pegasus' brand.
Aug 23, 2010 | Home
Handle for toilet
Pegasus Plumbing co.
2455 Paces Ferry Road
Atlanta, GA 30339
888-328-2383
May 18, 2010 | Pegasus Technologies Two-Piece Round...
The toilet is very poorly desigend - the cheap plastic flush handle is not designed to carry the weight of flipping the tank within the bowl. Of course the handle broke off - what do I do now - short of...
You said it.
Pegasus stuff is designed to fail from what I've seen. Every faucet or fixture they have is prone to failure.
Go back to your place of purchase and have the part replaced under warranty.
Feb 03, 2010 | Pegasus Technologies Two-Piece Round...
I puchased a new Pegasus toilet about 6 months
it is filling up too much you can adjust the arm there is a screw on the side that adjusts the leval of water in the tank
Jan 22, 2010 | Pegasus Technologies Elongated 2 Piece...
Pegasus Dual Flush Toilet - How to repair damaged handle
any good plumbing supply company will help you. " Furgoson " i think thats how you spell it.
Jul 18, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Home Logo
21 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
