Question about Vehicle Parts & Accessories
Vehicle Security alarm
I'm trying to wire my security alarm to my vehicle truck horn what do I need and how to do it?
  • swishs2k10 Jul 25, 2009
    will a foglight wire harness kit work? I was told to get one
    President:
  • 1,564 Answers
The simplest method is to go to the hardware store and pick up a couple of "dual" solderless connectors. Assuming that your running lights flash when the alarm is tripped, all you have to do is run a jumper wire from the positive feed that comes from the "alarm tripped" wire and jump it directly to one or both of your horns, whatever the case may be. A 12 volt test probe is invaluable if you are working alone.
Posted on Jul 25, 2009
The alarm randomly comes on for no reason, would this be related to the BCM? If not what could it be?
Some of the sensors are going bad or are too sensitive. A motion sensor or lock sensor can be intermittently setting it off. Do you have access to a scan tool ?
Jun 26, 2015 | 2004 Ford Explorer
How do I turn off honda 1998 horn. Security alarm system
try locking and unlocking the drivers door with the key. if it is a solid beeping your horn relay may be bad pull it and get one at parts store. they are cheap.
Jan 20, 2015 | Honda Cars & Trucks
I want to use my truck horn along with my alarm system. How do I wire it up?
Figure out what type of switching the horn uses. is it a positive voltage or a negative voltage. Is the horn earthed and a positive voltage is applied to make it activate. Then you would switch positive through the relay.
25259139-2hwhdwp04054ukehyojdwtcx-4-0.jpgtruck may use a 24 volt DC power system then horn may need +24 volt instead of 12V . If truck is 24 Volt then alarm system may need a 24Volt to 12 Volt converter device to power alarm system. You need to check what truck uses 12V or 24 V before connecting alarm to truck power.
Oct 28, 2014 | Viper Vehicle Parts & Accessories
The alarm doesn't horn
take off the siren and connect it to the battery, if it works check the alarm wiring. if the wiring is good check the output of the siren.
Mar 22, 2014 | Remote Start System
2005 dodge dakota horn honks while arming vehicle with Viper alarm instralled
You need to look under the dash for the model number then contact viper support
Feb 17, 2012 | Vehicle Parts & Accessories
Alarm is not responding ,alarm was also going off as i was driving ,loud horn followed by short churps ? how do i fix this i have , just brought this vehicle and i only have 1 alarm remote on the keys.
Hi there this once happened to me while driving along and all of a sudden the car alarm started to sound- I stopped at lights and tried finding wire to pull off battery but to no avail. I finally took to shop and found all that problem was the remote battery was flat and spent all of like $6 to replace it. Hope this is yr problem too.
Aug 04, 2011 | C3RS730 LCD (C3RS730LCD) 2way 4Channel...
Just baught a truck with a viper alarm, worked great then today i unlocked the truck with the viper remote and when i open the door the horn goes crazy for for about 1 min not the accual alarm! but at the...
Can be somewhat complicated to explain, particularly without knowing the make, model & year of the truck and which bypass was used to integrate into the factory systems. But here's one thing it might be. The Viper system is aftermarket obviously, when the alarm is triggered the siren with start to sound, and sometimes the horn will honk as well (depending on the vehicle and the bypass). If the siren isn't blaring that means the Viper system was disarmed when you unlocked the doors but not your factory security....or another way to word it is if only the horn is honking and no siren then you're factory alarm system isn't being controlled by the viper remote the way it should be. The factory disarm wire needs to be connected. It's a light green wire with a black stripe in a red connector in the Viper alarm brain. For anything more specific I'd need some more info on the vehicle. You can email me at jared@underground-audio.net if you'd like.
Nov 17, 2010 | 7752V Replacement Transmitter Supercode...
Which wire gose to the horn
That model has no horn output,only the siren.
Sep 23, 2010 | 3100l Auto Alarm Security System Viper
How to hook up my car horn to my alarm
Your tech is mistaken. The brown/white wire will hook directly to the lt.green/blue wire at the steering column in your car. Might require some programming at the alarm module.
Jan 12, 2009 | ' II' DIY Car Alarm Vehicle Anti-theft...
It will not burn it up take the two wires from the siren and tape 2 wires of that and run them to your 2 horn wires and tape into the horn. Thats what i did and i havent had a problem since.
Jan 12, 2009 | Toyota Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
48 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
