Question about Electrolux Washing Machines
ERR message being shown on Electrolux EWF1083 washing machine when I try to run any program. Can not start machine. Tried turning off at wall for 10 minutes. Made no difference. Any suggestions please
  • 190 Answers
SOURCE: err 10 message on Fridgidaire front load washer
The E10 error indicates a long fill error meaning the machine thinks it took to long to fill with water.
            We recommend u to check that the drain tube is now stuck to far into the stand pipe and possible causing as siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow.
             u can hook the drain hose off, forcethe  water through it with a water hose, unclog the stinky mess and  hook it back up again and  work it.. tat woul do..
Plz rate this solution.. thank you..
Posted on Apr 08, 2009
  • 3 Answers
SOURCE: Machine stops and the Start light is blinking
It might be teh same problem I have. in my case, teh machine works for a few seconds and then stops i.e. nothing else happens. no alarms go off either. In my case it appears that teh door interlocking device is faulty. You can by this spare part for around 22 euro. Replacing it is a bit tricky because you need to take off the locking device(the slot where the door locks into) and redo wiring. DONT mess up teh wiring becasue then you will need an engineer. Before you go looking for a spare part, you can take off teh interlock adn manual try to operate it. do this by turning on a wash and pressing teh two metal parts together on the lock.
Posted on Aug 27, 2009
You can download from here:
Posted on Feb 25, 2011
  • 17 Answers
SOURCE: I have a Bosch WFL2061
Hi marc709, il start off by saying WOW! thats an awsome stint for a washer:) on a more sad note the ticking noise you can hear is most likely the power control module. Due to constant wash cycles and electrical switching the machine produces over the years can cause an electrical breakdown in the power supply. As much as id hate to say it mate your better off cutting ur losses now and buying a new or second hand recondition appliance as buying a new power control module would set you back the same amount in price as a new unit and even if you did find a power supply for a reasonable price, (murphy's law) replace a part and be prepared to replace something else, thumbs up if this helps thanks.
Posted on May 02, 2011
  • 123 Answers
SOURCE: Where can i get a manual for electrolux ewf1083 front loader
You can download one from here:
They carry every electrolux manual ever produced.
Posted on Mar 02, 2013
Electrolux EWF1083 Front Loader washing machine.
Your right not draining-see your other post-cheers Denny
Oct 24, 2013 | Washing Machines
When the water drain, the machine just make noise and the drum stay still for more than 10 minutes based on the timer countdown. Then I pause and start. Noise & no movement. However this does not happen at...
Angie This happened to my washing machine. What I did was I tried some programs , empty, spin, short washing. After I had tried quite a few programs it started working correctly again. It is worth trying. Kolbrun
Sep 19, 2013 | Electrolux Washing Machines
Electrolux ewf1074- cycle time flashing and beeping and not running cycle
Consult the manual first, if there is no troubleshooting , contact your dealer (thinking about the warranty term)
Dec 02, 2017 | Electrolux Washing Machines
Electrolux ewf1083 stops mid cycle displays e10 .press start button and continues but can happen up to 4 times per wash.any ideas?
We had the E10 error on EWF1083, I opened the top cover and looked into it. It's the 2 way solenoid valve and should be a easy replacement. Looked on ebay and $59 for the part ex postage
Oct 12, 2011 | Washing Machines
Hi, Our Electrolux EWF1083 is not spinning and ...
Hello,E20 is "A problem with water draining"
The drain hose may be squashed or kinked
The drain pump may be blocke.check
May 19, 2010 | Washing Machines
Where can i get a manual for electrolux ewf1083 front loader washing machine
May 14, 2010 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
