How can I add freon on split airconditioner - Heating & Cooling
  • Heating & Co... Master
  • 1,711 Answers
You need a manifold and some freon. If you have to ask you shouldn't be doing it.
Posted on May 21, 2017
Where can I buy a regas kit for my split unit airconditioner I live on the Gold Coast
I've never heard of a regas kit for a split a/c system. You need a declaimer, a vacuum pump, the designated refrigerant, gauges, and a digital scale. Evacuate the system, when system holds a vacuum, look up amount of refrigerant and type from mfg. tag on unit of spec book. Add specified amout of refrigerant and your done. If noy familiar with pressure on gauges you can use an amp meter to ensure unit is not over charged or has a restriction which would cause higher discharge pressure and therefore high amperage. Best to call a tech. Cheaper and safer.,
Jan 01, 2015 | Sanyo 33,000 Btu Ductless Airconditioner
How to do a freon recharge on roof top rv airconditioner
there are no access ports to add freon you would have to put a line tap valve on it.
May 10, 2014 | Coleman Mach 15 Air Conditioner
Where do I add the air conditioner liquid
generally only HVAC certified A/C technicians are able to have and administer Freon. It's not like the cars these days we can't do it ourself
Jul 14, 2012 | Coleman York Freon Pressure Switch...
Help me please have a R410a 12000 btu mini split airconditioner heat pump that lost gas how do l regas it have closed all the leaks and have the R410a refregerant with the adapter.i have not charged a...
Mini splits need to have the refrigerant weighed in. First, ( if the system is already empty ) pull a vacuum down to 500 microns. Second, add the amount of refrigerant listed on the mfg. tag. Hope this helps!
Jun 07, 2012 | Heating & Cooling
How many months before we replace/add freon to the airconditioner
The refrigerant never wears out. You should never have to put refrigerant into a system unless it has a leak. Hope this helps.
Sep 06, 2011 | Samsung Heating & Cooling
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
How can I recharge the airconditioner with freon. thank you john
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 27, 2010 | Daewoo High Energy Efficiency Air...
Where do you add frion coolant for the airconditioner i have never done this.
what year what tpye of freon 134a ,R12 do you have the equipment gauges, deep vac, and if it is R12 do you have certifcation to handle freon?
Sep 18, 2010 | Mercury Sable Cars & Trucks
I want to recharge the airconditioner, but the computer in the dash states refregerent to low compresser shut off! how do I turn on?
Add freon if not done yet, disconnect battery for 5mim, should reset, if it don't reset after disconnecting battery, your low pressure switch's are bad, that happens about 50% of the time when freon get's low. the low switch's are located on a very thin a/c line that run's along the top of the fire wall, there will be two about 12" to 18" apart, on the same a/c line, recover freon before removing switch's, install new one's evac a/c system and recharge with 2lbs of freon, hope this was very helpful.
May 24, 2010 | 1994 Cadillac DeVille
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
