Question about Pinnacle Video Transfer
All LEDs are in constant switched on state(BLUE)
When the unit is switched on, all the lights turn blue(irrespective of whether inout/output is connected). Even on connecting, the lights still are blue and the unit does not respond to anything.
  • drajananda Jul 26, 2009
    I am trying to record from a TV. The buttons(rec/mode) do not respond. All the lights are constantly lit in Blue.
  • Keith Fox
    Keith Fox May 11, 2010
    Are you still having a problem with your Pinnacle Video Transfer?
  • 641 Answers
When you plug in the source device and the output device, all of the LEDs light blue, letting you know that the device is ready to capture. When you are ready to capture, simply press the play button on your source device, the Rec button on the Video Transfer, and the LEDs light red, both on the source side and the output side, letting you know that a recording is in process. To stop recording, press and hold the record button and when the lights turn blue, recording has stopped.
this is the source: http://www.pinnaclesys.com/PublicSite/us/PinnacleLife/Content/Reviews/video+to+ipod.htm
Posted on Jul 25, 2009
Hp compaq 7620s wont start ( constant blinking blue light )
The adapter output appears correct, the batteries often work in that voltage range. But the problem you have is the motherboard, the HP line has constant trouble with the main board, only option is board replacement.
May 12, 2012 | Computers & Internet
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
Fridge light takes 2.5 sec to come on
Hi!!!
Have you cleaned the switch actuator? It is usually located on the door frame since it is activated by the door. Some times accidental spills will keep the switch from working correctly.
Good Luck
Mar 11, 2010 | Refrigerators
When turns on, tv gets off
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Check to see if you get any DC voltage on the output connectors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 16, 2009 | Polaroid 4226TLMB 42 in. LCD TV
AVR amber light will not return to blue after
There is an internal reset switch mounted on the transformer board. Open the unit, look at the boards attached to the transformer, the pushbutton is facing up. Measure the voltage on the 2 pins of the switch. If it is a logic low, the switch is partially shorted. Replace the switch or just cut the jumper wire just below thw switch. When this switch fails, it constantly resets the receiver and stops it from powering up. It does not fix a protection mode problem.
Dec 01, 2009 | Harman Kardon AVR 130 Receiver
PHONE WON'T TURN OFF
For Nokia 6300
  1. Remove the battery to turn it off then insert it again.
  2. Press the power button. The blue LEDs on the sides should flash and the phone turns on.
  3. If the blue LEDs do not flash, you have a broken power switch.
  4. If the blue LEDs flash but the phone does not turn on, you have a weak battery or hardware/software problem.
  5. If the battery is good, have your phone checked by a qualified technician.
Nov 29, 2009 | Nokia 6300 Cellular Phone
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
I have a blue symbol (one of the camera short cuts i think) lit up constantly on my phone. Any ideas how to turn it off please?
it actually sounds like you have the bluetooth switched on permanently - this is a blue "b" like shape symbol
Jul 29, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Pinnacle Video Transfer Logo
212 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
