Question about The Audio Players & Recorders
How to make your ipod charger good and new again so that it can cut back on so that you can play on it and make your contacts the same that they was
My ipod want cut on it was charging over night and I really need it to cut on
SOURCE: My iPod 8GB Won't Charge Even Though It's Plugged In
Try resetting the iPod buy holding the home button and the shut off button on top at the same time, hold till unit shows it reset
Posted on Oct 19, 2008
  • 489 Answers
SOURCE: Samsung Alias will not charge.
try with another battery. if it charge you have battery problem. if it doesnt you have motherboard problem with phone
Posted on May 30, 2009
SOURCE: bought an MXT DV7000 digital camcorder, but the
I had the same problem.
Put the battery in an old Nokia desk charger (the docking type), aligned the contacts as the battery is smaller than the housing and left it overnight.
Eureka. Fully charged
Posted on Oct 01, 2009
hawk127311
  • 350 Answers
SOURCE: ipod says charged, but when i unplug it it cuts
  1. First thing to do is restore it to factory settings to see if that corrects the problem.
  2. Make sure you’ve installed the latest version of iTunes.
  3. Open iTunes, and then connect your iPod to your computer.
  4. After a few moments, it will appear in the Source pane in iTunes.
  5. Select your iPod in the Source pane and you will see information about it appear in the Summary tab of the main iTunes window.
  6. Click the Restore button. A window will appear asking "Are you sure you want to restore the iPod "iPod" to its factory settings? All of your songs and other data will be erased."
  7. Click Restore again. (If you're on a Mac, you'll then need to type in your password.)
  8. During stage 1 of the restore, a progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
If all else fails and the battery is bad, replace the battery. Here is a video that will show you just how easy it is. No need to pay Apple any more money than you already did to repair it.
http://www.youtube.com/watch?v=2h53otOBTsI
I hope this helps and good luck!
Posted on Nov 03, 2009
SOURCE: Jamo i200 doesn't charge iPod Touch
same problem ...it just doesn`t charge the f.. ipod any solution?
Posted on Apr 25, 2010
My ipod model a 1285 keeps turning itself off why
iPod keeps turning off Plug your iPod in overnight to make sure it has charge. If after a full night of charging it has a low battery, there is probably something wrong with your charger cable. Replace the charger cable, especially if yours is old or has ever gotten significantly dirty. Reset your iPod. This basic reset does not remove any content from your iPod. Apple suggests this soft reset as the first fix for any software problems or if the screen freezes. Eject your iPod from your computer first. For an iPod with a click wheel, toggle the hold switch on and off several times, then hold down "Menu" and the center button at the same time until the Apple logo shows up on the screen. For touchscreen iPods, hold down the "Sleep" button at the top right until the Apple logo shows on the screen. Perform a factory restore on your iPod if the previous steps do not fix the problem. Plug it into your computer and open iTunes. Click on your iPod, then click "Restore." This wipes all content from your iPod and re-installs the operating system.
b> iPod Keeps Cutting Off b> Your iPod may cut off during a song or video, or during an application. Different causes lead to different types of cutting off just the sound may disappear, or you may suddenly experience cutting to a different screen. For example, if your iPod cuts off during a song, you may have merely hit the "Pause" button. With a blank white screen, you're encountering a software problem. Whatever the reason, follow some simple troubleshooting steps before contacting Apple's customer service.
Headphones Check that your headphones are connected correctly if the sound cuts out suddenly. If the 3.5-mm headphone jack comes out even a little bit, it can make the sound cut out in one or both headphones. Check for debris in the headphone jack itself, which can prevent a solid contact between the headphones and the iPod. b> Other Sound Issues b> Make sure the volume is up high enough. Also, especially if the iPod is in your pocket, make sure you haven't bumped the pause or sleep button. To ensure that audio plays constantly, engage the lock on your iPod. The music will always stop when you pull out the headphones, and once the headphones are back in, you have to push "Play" again. Cutting to White Screen b> A sudden white screen may appear when a generic software malfunction occurs, one in which t you don't get an error message. You must reset the iPod by turning it off, then on again. If this happens several times and you are using the same application each time, that app may be faulty. Try re-installing or re downloading the app. b> Cutting to Black Screen b> An iPod that cuts out to a black screen and won't turn back on is usually out of power. Usually you'll see a low battery warning, but if you're not looking at your iPod when the warning flashes, you might miss it. Once you connect your iPod to a functional power outlet, you can turn it on immediately, but it's best to wait a few minutes when the battery is very low. This gives the iPod a chance to regain power so it can function normally when you plug it in. Hope it helps.
Jan 22, 2013 | Apple iPod Audio Players & Recorders
My ipod 30gb needs to connect to its charger before it power on, and sometimes when i disconnect it from its charger sometimes my ipod will also shutdown, My next problem is that, when my ipod 30gb...
The Batteries in these units like all rechargeable batteries only have a certain number of times they can be charged and discharged before begining to fail. Your only option is to replace the battery with a new one. They are cheap to purchase off eBay and YouTube has Videos detailing how to change them.
May 06, 2011 | Apple iPod MA446LL/A MP3 Player
have you tried changing the charger or charging it through a computer. some chargers are too outdated for the ipod to charge!
Jun 20, 2009 | Jamo I200 Ipod docking station
Popping noise and cutting volume on Iphone
i have the same problem. I started after an iphone software update.
Jun 15, 2009 | Apple Bose SoundDock Series II Digital...
Ipod won't work unless plugged in to computer or mains
alison65,
good day, the only possible cause why your player can only power up using it's own charger or through pc connection is:
1) The connection of the rechargeable battery inside the player is loose or out of contact
2) The rechargeable battery itself is faulty
3) The connection from the charging line is loose or out of contact
most likely your problem is within the internal of the unit.
cheers,
mark
Jan 29, 2009 | Apple iPod nano
Ipod wont take a charge
your ipod is exhibiting symptoms of a bad motherboard.
I would plug it in the charger with an a/c charger for a while and try it.
If you have been playing this ipod on a dock, chances are it has a bad motherboard.
You also may need a new battery but i don;t think the battery is making your ipod have the symptoms you explained.
i have replaced many motherboards in the 30 gigs due to people playing them on docks and the boards frying, mostly the charging circuit, and the sound. There is also a chip that comes lose on the 30's if your turn the ipod on with a headphones in and squeeze the ipod on the right side of the clickwheel just down from the middle of the click or >> button the ipod may create sound. if so your motherboard needs to be replaced.
Good Luck
Dec 26, 2008 | Apple iPod MA446LL/A MP3 Player
8 GB Ipod Nano went dead and now won't charge
does it work on the charger? if not, then contact apple or your dealer for more assistance or repairs.
If it works on the charger, plays music and so on, your battery is probably dead and you need a new one.
Mar 24, 2008 | Apple iPod nano
22 people viewed this question
Top The Audio Players & Recorders Experts
isojim
Level 1 Expert
 Sam R
Sam R
Level 1 Expert
obsteiner
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
