Question about Garden
Blades wont cut on when u pull the button out to ingaguge the blades
SOURCE: Need replacement cutting blades on my simplicity serger easy lock 804
Allbrand.com or go to Google, type in: "Replacement blades for a serger". Hope this will help. I have the same serger. --Tricie
Posted on Mar 29, 2008
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
EwingElect
  • 276 Answers
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Posted on Apr 11, 2009
  • 86 Answers
SOURCE: won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
Posted on May 10, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
I have a cub cadet rzt50 zero tudn. Blades are new and sharp but when i cut there is a trial of cut grass in the center of the mower tracks that is left behind. Mower is only a few years old with 100 hours...
if this started after the blades where replace make sure you have the right blades zero turn and reg mowers have different blades then check the bearings on the blade mandrels then last is to check for a rotted out deck with the belt tension pulling the blades apart
May 16, 2012 | Cub Cadet Garden
My blades are always running and wont shut off. Also they are running so slow that it wont even cut a blade of grass!!!!
there is generally a clutch for the blades, made with a spring loaded pulley or electrical device. when you move the lever (pulley type) or move the switch (electrical type) it engages the belt which drives the blades. You have a problem there and someone with mechanical skills needs to look at it and repair it. I suspect a spring loaded pulley type, it sounds like someone took the belt off and put it back on wrong. There is no magic button to fix this.
Mar 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Jun 08, 2010 | Andis 01690 Hair Trimmer
Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
May 26, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How do u get the blade going to cut grass
there should be a lever or switch that will make
blades turn..
Jul 02, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Blades will not engage when you pull up on the button
When you pull switch to turn on blades do you here a click sound ? If so clutch is most likely ok,did you check your belt to make sure its ok ?Seat switch is just a saftey feature it cuts all power to the clutch so thats why blades turn off,thats why I asked you if you here a click when pulling switch that will tell you if there is power to switch.there is also most likely a fuse in the line that goes from the clutch switch to clutch.
May 09, 2009 | Garden
Craftsman 42" riding lawn mower blade free spinning but wont cut
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades are not cutting
hi, yes blades can wear out but your sharpener should advise if there is a problem with them. check to make sure the clipper is moving your blades and your blade cannot be removed without depressing the latch. If your are experiencing tram lines with larger blades then it is more likely to be a clipper problem. However if your blades just wont cut i would recommend a new sharpener as it is a specialist area.
Jan 29, 2009 | Oster Golden A5 2-Speed Universal Motor...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
