Question about Cell Phones
Charger wont completly charge and shut off, needle on charger stays about two thirds charged
    Top Expert:
  • Cell Phones Master
  • 45,079 Answers
The battery may be old and incapable of charging more than two-thirds.
Posted on May 21, 2017
SOURCE: mouse
I cleaned the terminals on the charger and the mouse using a little rubbing alcohol. This solved the problem right away.
Posted on Jan 12, 2009
SOURCE: zen mosaic frozen on charging screen
Try hitting the reset button. Its the small one on the left side. You might have to push it with a pen or something,
Posted on Feb 02, 2009
  • 62 Answers
SOURCE: sony mp3 walkman wont charge
i would get a new charger and go from there
Posted on Feb 26, 2009
SOURCE: my enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Posted on Apr 06, 2009
  • 7 Answers
SOURCE: My Casio Exilim EX-S880 wont turn on. Battery is
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
My portable charger wont stay on. How do you make it stay on to charge the phone?
If you're using the charger supplied with the phone, it should either work or not. If it doesn't; either the phone battery, charger or both require replacement.
If the battery is "good" and you are using a "3rd party" (non-original equipment) charger, you may not have one that is incapable of providing the correct voltage, charge current or both. If the charger can not provide adequate charge current or voltage, it is very possible that the charger is shutting off due to excessive heat. Once sufficiently cooled, it charges again.
Make sure that you've got the correct charger - or one that is designed to charge the type battery in your phone at the correct voltage and current rates.
Apr 08, 2015 | Cameras
I have 2 sony mp3 players and they both won't charge. charger is working
hello there !
Check your charger pins First are they OK.
then go for the Sony player charging point . is it clean enough that pins can make charging , if they aren't then clean with a needle.
thirdly do try to use a original Sony charger as i had some players back and it wont work cause i didn't use a branded charger .cause the out put sometimes get different and they are not of slandered quality.
Do comment if it helps you in any manner
ill give you a feedback
Apr 23, 2011 | Sony Walkman Video NWZA818 MP3 Player
New phone that I've used for a week without problems. Yesterday it shut itself off and I tried to charge but it won't stay charging and I can't get it to stay on. It will say it is charging for about 30...
Battery of device been depleted completely of functionality requiring a new replacement. Refer with the device user for details with power malfunctions also recommending direction to resolvment
Apr 04, 2011 | Cell Phones
Nokia 6500 wont charge
Where you connect your charger there is a loose connection there,what i can tell you for your phone to stay alive is just buy an universal charger it is not expensive,you put your battery in then after charging replace it in your phone and the problem is solve .
Feb 09, 2010 | Nokia 6500 Classic Cellular Phone
I tried to charge my car battery with a Chicago Electric charger model 66783. I followed the directions for charging the battery in the vehicle. After selecting the charge rate of 10 AMPs, the ammeter...
Relax, the charger is working fine. What it is doing is charging the battery to 15.5V. During this time, the "charge complete" LED is off, and the current meter shows the needle going to the right. When 15.5 volts is reached, the current is shut off, the needle goes back to the left, and the LED goes on. When the battery voltage drops to 13 volts, the current goes on again, etc. At the beginning, with a very depleted battery, the needle will be towards the right, then as the battery gets charged close to full capacity, the needle will bounce back and forth because the charger is feeding current in short pulses. Towards the very end of charging, the needle will stay longer and longer at the left end (the LED will be ON), and spend less and less time to the right (LED will be ON for longer periods, and "blink" OFF less and less). Finally, at full charge, the LED will stay ON, the needle won't make excursions to the right, etc.
Dec 29, 2009 | Chevrolet Classic Cars & Trucks
My iphone wont charge
Trying using the wall charger.
Aug 01, 2009 | Apple iPhone Smartphone
I have an Energizer E2 Slider battery charger, Is the green light supposed to stay on when charging. Does it shut off when charge complete.
all chargers show a light of some colour when charging , green or red , depending on make of charger , when the battery is fully charged the unit monitor this and automatically switch of to stop from over charging , a safety feature that has to built in for safety reasons ,
Jul 19, 2009 | Energizer NiMH Compact AA/AAA Battery...
Wont charge
it might be the battery. cause batteries on cell phones only last for so long [depending on how long you've had it] or you might just have a bad phone. go to the phone company where your phone is from, and tell them about it, and they'll probably give you a new phone.
May 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Sony mp3 walkman wont charge
Feb 26, 2009 | Sony Walkman NWZ-S616F MP3 Player
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
