Question about The Health & Beauty
I replaced the battery and still not getting anything, all the fuse are good, what do you think is the problem? I rode the scooter three weeks ago with no problem
Mikey108
  • 475 Answers
SOURCE: 1989 Jeep Wrangler Standard wont start
You have to check if this is fuel or spark related. You HAVE to put a filter in the system or the fuel injectors will get clogged. Check for spark first. If you have a good spark at the plugs, then your problem may be fuel related. If uou don't have any spark, then the problem could be a bad crank sensor.
Posted on Nov 17, 2008
  • 200 Answers
SOURCE: batteries won't hold a charge
Are the batteries really gettin a full charge or is your charger faulty. If you can borrow a voltage meter you can see what your battery is putting out and check the charger (plugged in) to test how much voltage it is putting out. If the Razor is 12 volt you can hook up a car/motorcycle charger to pump up those batteries. I don't think your batts are not holding a charge, i think they're not gettin a charge....good luck to you...Tim
Posted on May 09, 2009
SOURCE: I replaced my Garmin Forerunner 50 battery three
Took out the battery for 3 min and put that back
Posted on Nov 22, 2009
wd4ity
  • 4565 Answers
SOURCE: I had my 2001 Fatboy running 2 weeks ago, went to
The power from your battery goes fromt the positive post of the battery directly to the starter. At the starter, there should be two connections. The large battery cable and a smaller red wire. This red wire is "hot' wire to all the "accessories" on your bike. The wire runs straight from there to the ignition switch. If you don't have power to the main switch, you have a main fuse blown somewhere. You'll need a schematic to trace the wiring out from there. I'm sorry but I don't have a schematic for that model bike. Make sure all your connections are clean and tight and your "Run/Stop" switch in the in the proper position.
Posted on Feb 15, 2010
emissionwiz
  • 76848 Answers
SOURCE: Used 2002 Honda Metropolitan II
one of many main connectors has either come loose or a crimp connection in one of the main power circuits is corroded, have the tech pull and twist the wiring harness to see if it does anything to indicate the problem is in the area u are bending and pulling on, work all around the harness, there is no MAGIC fix for problems like this, have fixed this type of problem 100's of times over my 45 year career, never the same from one problem to the next. Also have him pull apart all the main connectors and check for greenish looking corrosion, repair as needed
Posted on Sep 05, 2010
Honda metropolitan 05 Met II blowing 15 amp fuse
Did the scooter start OK when you first started it after bringing it out of storage, or did you have to use the kick starter? Maybe the battery is faulty and is pulling a lot of power.
Check the charge rate with an ammeter (use a multimeter that can measure 20 Amps DC) and see if the current exceeds the 15A rating of the fuse. If it does, replace the battery.
Sep 27, 2014 | Cars & Trucks
Scooter wont stay on
Just a thought...it might be cheaper to get another charger (or at least the cord that goes from the charger to the scooter), splice the ends, and bi-weekly or so charge the stored batteries by stripping the ends of the other charger. I cannot think of any other way to preserve the batteries, which are not cheap, because even if the scooter is not driven they batteries need to be charged regularly. I have not tried this solution, but that is what I think I might try if I wanted to preserve stored batteries. Also, perhaps via ebay or amazon, you can find the case cheaper than $600. Personally, I think this handicap business is a racket, often over-priced, and they have got us over a barrel. Good luck! :)
Jul 08, 2013 | Health & Beauty
I rode my 50cc scooter in the rain, with no air filter.
If you allowed water to get into the air inlet, if a 2stroke, I suspect the crankcase seals are damaged. If 4 stroke check compression for damaged piston.
May 28, 2017 | Star 50cc MOTOR SCOOTER
I have a 2000 Heritage Softail Classic. I rode it 2 Weeks ago without any Trouble. This Weekend it had no Power to anything, Battery shows charged but nothing works.
Hi Carmen, make sure your battery cables are clean and tight especially the negative cable at both ends. Then check your main circuit or maxi fuse for loose connections or negative function. Finally test your ignition switch for continuity. Good luck
May 28, 2012 | 2000 Harley Davidson FLSTC Heritage...
I have 2006 super glide I just picked up a teo months ago. I rode it for a few days. I was out on it last week in the heavy rain. When I went to start it yesterday it was dead. I put the battery...
The battery on most motocycles cant take much abuse.Most batteries on bikes with proper care last about three or four years.If the one you have is this age or older I would purchase a new one.Good Luck.
May 09, 2011 | 2006 Harley Davidson FXDI Dyna Super Glide
I have a 1985 GL1200 interstate. When the key is inserted I get nothing, no accessories or lights of any kind. All fuses check out OK. Battery is brand new and working as I have extra fog lights wired...
Follow your positive battery cable from the battery to the starter solenoid. Take apart the starter solenoid (unplug the harness) and flip down the door. This will expose the main fuse for the motorcycle. These are prone to cracking. Replace the fuse with the spare in the cover and the power should return to the motorcycle. Drive to the nearest Honda dealer and buy some spare fuses or rewire the fuse and replace it with a flat push fuse.
Apr 24, 2011 | 1985 Honda GL 1200 Interstate Gold Wing
Pride celebrity XL won't go.
Have you checked the motor brushes for wear and spring tension, sometimes the spring becomes brittle and breaks but can sometimes still make contact.
Regards Steve.
Sep 01, 2009 | Drive Medical Mini Phantom Three Wheel...
Honda cbr 400 rr starting problem
i could not find a schematic of a 96 cbr400rr, so guessing this bike is not from the USA. however, there should be a master fuse near the battery on the positive side mounted to the battery box somewhere. i would check this fuse first to see if its burned out.
also, is battery fully charged? might have to top charge the battery to get good juice if its old (>3 years) and been sitting for a bit.
good luck.
Jan 28, 2009 | 1996 Honda CBR 400 RR
Schwinn S180 won't charge
NashvilleDan, this scooter has 2 12v 10 amp batteries in series, you should read over 24 volts at the charging hub if the batteries are good. I would think that if the scooter sat for over a year you have bad batteries, They can be purchased at battery plus.
Mar 19, 2008 | Transport Schwinn Rechargeable Portable ...
Health & Beauty Logo
18 people viewed this question
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
