I set up my tv but can't get any sound. - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,473 Answers
If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Posted on May 21, 2017
Sound Appeal sound bar set up. Not getting sound from tv except tv's speakers. Help!
You have to check the sound setting of your tv. In most of the lcd tv there are two option that you can select. Internal speaker of the tv and external speakers while using sound bars or other amplification devices. Fist of all Check that setting. Check the link bellow to understand How to setup a sound bar to your tv.
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=QQ3zFnnsiMs
Dec 27, 2015 | LG Televison & Video
Trying to connect Surround sound system with 3 Other Components!?
hi, you need to have 3 pair of audio-in ports for that. i think your sound system has 3 input ports. ie, 1.tv in ->u can connect this to audio out of your tv 2: vcr in ->u can connect this to audio out port of vcr 3: aux in -> this can be connected to your TV Receiver then you can use the soundsystem remote to switch between the source to listen one at a time. pls come back if u have any thing more sreejith
Aug 31, 2007 | Panasonic SC-HT75 System
Sound problem with Standard (CRT) Televisions along with set top box
From your description, it is likely that there has been a failure in the TV sound system.
Dec 27, 2013 | Televison & Video
TV speakers have switched off (i dont know how) how do i switch them back on again have used remote control to access sound options and does not seem to be a feature for on of off sound adjustment
Go into ur tv menu again,go to sound option again check what on the writing highlight on the tv SOUND SETTING now is it said VARIABLE SETTING.Than it is the sound setting problems,go into that highlight word VARIABLE SETTING just press the enter button on the remote to change it back to FIX SETTING.This should and will solved ur tv sound setting problems.If the sound setting already highlight word is said FIX SETTING.Than the tv have bad incomming broadcasting input signal cable or ur tv have bad or dead speakers problems to the tv itself.Not Sound Setting problems.
Apr 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Sound becomes distorted after changing channel requiring pushing mute button and back to sound again to restore proper sound
Tries tv unplug,replug it back like about an hour.By letting the tv by resetting itself back to the factory setting.Now goto the tv menu goto Audio Setting,go down to do resetting,so resetting the tv Tuner board for resetting sound,setting back to factory setting.This should solved ur sound problems.
Jan 30, 2011 | Vizio M370VT 37 in. LCD TV
My TV doesn't have any sound with its cable. The
Tries difference setting in the SOUND setting,see how it turn out.Like setting in Variable setting,instead of fix setting.Setting in MONO setting,istead of STEREO setting.
Jun 25, 2010 | RCA 32F531T 32" TV
No sound on TV
If the TV programs come's up with sound, then is possible that the TV set could be problem free. then cheek the system frequency if it need to be adjust from NTCS, PAL, AUTO MESECAM and so on. Cheek the DVD and VCR if they are in one of the following system settings and adjust the TV set to the settings at which the DVD or VCR is set to. Then you can also cheek if the cable is properly inserted, that is audio to audio and video to video. Nevertheless, if you have properlly connected your cables and set the system frequency to match with each other, and still no sound, then the TV could have sound problem.
Possible courses of sound failure in TV are as follows:-
1 RF stage
2 sound Ics or transistors
3 broken speakers
4 a break down resistor which supplie positive voltage to the sound curcult
Dec 09, 2008 | Televison & Video
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
