Question about VIA Computers & Internet
I have an old BlackBerry curve 9310. I cannot access internet via the roaming. Mobile connection seems suddenly gone without wifi.
This phone does not have SIM card. Just stopped roaming suddenly.Network connections: mobile network home network selection mode: automatic. Available networks shows as home. I haven't changed any of those...
SOURCE: USRobotics USR5461 - WiFi local network intermittently available and unable to connect
I've been having the same problem where even hard wiring to the router won't work. I called USR and they had me reset to factory defaults. Now three days later, the same behavior is happening. I reset to factory defaults and it works again but I don't know for how long. Maybe these things just wear out after a while...who know.
Posted on Apr 20, 2008
TanyaAD138
  • 77 Answers
SOURCE: Blackberry curve 8330's blocking mobile network
Sounds like you're in a dead zone. If not then ...
Check in the upper left corner... IF:
1x = you are not connected to any data at all - No emails, text, internet will work send/receive.
1xev= you're connected to data but not blackberry usually the same as above though sometimes you might get lucky and receive only text/pix messages.
1X= Phone calls only. Usually no data (email, text, web, etc)
1XEV = everything is connected and you should be working fine.
If you have 1XEV (upper case and lower case matter ALOT...everything should always be UPPERCASE) and you're still having that problem then go to:
options> advanced options> host routing table
In the host routing table click the button to the left of the roll ball (called the blackberry button) and click on "Register now" and just leave the phone alone for a minute so it can register all your service books again. Then try the web again.
If all else fails pullthe battery and try again ..> Still no good? Call your carrier.
Hope this helps
Posted on Mar 26, 2009
  • 77 Answers
SOURCE: can't connect Blackberry Curve 8320 to 2wire wifi
W002 - Wi-Fi Connection Failed
Means The phone cannot get an IP Address from the Server.
Common issues are
The signal is to weak to make a reliable connection
WEP is configured incorrectly or WPA
DHCP may be disabled, it needs to be enabled on the router
There are other more technical issues to this but without more information this should be a good start.
Posted on Jul 15, 2009
SOURCE: Iphone Unlocking Problem
hi,try this way.cydia hit MANAGE,go to sources,you will see repo666.ultrasn0w.com,please instal it,if you did try reinstal..it will work.good luck
Posted on Sep 06, 2009
  • 69 Answers
SOURCE: blackberry curve 8520 internet via gprs
You will have to be connected to EDGE or GPRS to use data services. If you are on edge or gprs (lower case), you will only have voice and sms.
Posted on Nov 01, 2009
Fix my mobile phone
Hi Dennis, your internet access has different settings to calls & texts so that is why you can have the others without Internet access! The settings for Internet on your phone has to come from your service provider..........Mobile network settings - set options for data roaming, network mode & operators, access point names (APNs) and so on! Contact your service provider and get the settings for your phone sent to it from them.....have they done this?
Dec 17, 2014 | LG Optimus Spirit P690f black MobiPhone,...
How to factory reset
Follow below steps:
From the home screen, scroll to the All tray and press the trackpad.
Scroll to Options and press the trackpad.
Scroll to Security and press the trackpad.
Scroll to Security Wipe and press the trackpad.
Scroll to the desired options and press the trackpad to check or uncheck as desired.
Enter blackberry in the text field.
Scroll to Wipe Data and press the trackpad.
The handset will completely reset and restart.
This will take several minutes.
Jan 04, 2014 | Blackberry Curve 9310 Black Smartphone -...
I removed sim card in my blackberry when return it to the phone it blink red light and won't switch on
Hello, thanks for using Fixya, you should go to the Blackberry service center, I hope your problem will be solved, i hope it will work, Thanks & Regards, Syed Gulam Fareed
Nov 02, 2013 | Blackberry Curve 9310 Boost Mobile
Im conneced to wifi but can connect to internet on my blackberry
if ur phone is connected to wifi your phone uses wifi to connect to internet .....if connected to network it uses normal network and connects and data charges will be taken from your phone.
Oct 29, 2011 | RIM BlackBerry Curve 8520 Smartphone
How do i get on the internet with my blackberry curve 8520 phone and is it free
Data is never free unless your phone can use wifi.
Which I think the curve 85xx series can use wifi.
Mar 29, 2011 | RIM BlackBerry Curve 8520 Smartphone
Can't connect Blackberry Curve 8320 to 2wire wifi
Common issues are
Dec 25, 2008 | RIM BlackBerry Pearl 8100
Blackberry Curve UMA (unlicensed mobile access)
If you haven't tried a soft reset, try it. Alt+Right shift+delete.
Jul 09, 2008 | AT&T Blackberry Curve 8300 Smartphone
Computers & Internet Logo
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
