My Goodman furnace model GMP Series runs the blower fan without calling for heat or cool! I can disconnect the thermostat completely and the fan still comes on. Thanks!
It never used to come on this often but now it's all the time!
  • Heating & Co... Master
  • 1,657 Answers
Likely have a stuck relay. You can replace the board or install your own relay that controls the fan.
Posted on May 21, 2017
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Mar 26, 2011 | Audio Players & Recorders
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
Rachellewis250@I have mislaid my Stoves 720 EF manual. How do I set the timer?
There are five buttons. from left to right they are Minute Minder, Cook Time, Ready Time, Plus, Minus.
To set the time of day press the Cook Time and Ready Time together and then use the plus and minus to set the time. Use the Minus button alone to change the alarm tone.
To set the Minute Minder, press the button and use the Plus and Minus to set the time period. To cancel use the Minus to ge back to 00.00
Jan 07, 2011 | Stoves 720EF Electric Double Oven
Let me know the functions of microwave?
Sorry to read about your problem, I hope this helps you out.
Display: This is used to show the time, cook time and options you chose during you use.
Cook: Use this feature to cook fresh vegetable, frozen vegetables, rice and cassroles.
Enter/Start: This is used to start and enter any option you choice while operating the unit.
Stop/Clear: Use this function to clear or stop the unit during cooking or choosing a feature.
Reheat: This is use to reheat dinner plates and left overs. Be sure that you do not use any plastic foam or metal plates/utensils this can cause damage to the unit and may cause injury.
Auto Defrost: This is used to defrost food by weight and type. EX: If you have 1 pound of chicken, meat or fish press in the food code by using 1,2,3 and then the weight in pounds (1 pound would be 1.0 enter.)
Quick Frost: This is use with the Rapid defrosting method for 1.0 pound frozen food. If you have a pound of meat, chicken or fish press Quick Frost and it will defrost for that weight only.
Cook Time: This is to set the cook time for the food you are trying to heat or cook. Enter the time you wish to cook and press enter/start (EX: 7mins and 30 secs = 730/start.)
Clock: This is used to set the time of day. Press Clock the the time of day it is and clock again (EX: 11:00 would be 1100 then clock.)
Number: This is the key pad used to enter the cook time, clock or power level.
More: This feature is to add time to the cooking time only in ten second intervals. If you want to add time without restarting press this button to add ten seconds each time it is pressed.
Less: This is used to decrease the cooking time by ten second intervals. If you want to decrease time without restarting the time press this to decrease cooking time in ten second intervals.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Power Level: This is use to choose the power level in which to cook or heat food or beverages. To change the default setting of 100%, press the power level button and press the level you desire, if you desire only 50% then press power level the 5 and enter/start. Hint: Change the Power level before entering the time your setting to cook
EZ-ON: This is to quickly start the power level to 100%.
Vent High/Low/Off: This is to turn the vent located on the outside of the unit during use. You have the option of turning it off, on, high or low.
Light High/Low/Off: This controls the light on the bottom of the unit if you have a mounted range above your stove or under your top counter cabinets.
Hot Water: This is used to heat water for beverages such as coffee and hot chocolate. Use Extreme caution when removing baverages from your unit, they will be hot and could cause injury.
Popcorn: This is used to pop popping corn, when placing the popcorn in the microwave press the this feature and enter/start and it will automatically start the correct time for cooking. This feature is designed for the individual packaged popcorn use. Do not place any foil or loose popcorn in the unit this could cause damage or injury.
Kids Meals: This is used to REHEAT meals for children it works at a lower power level. This can be used to reheat hot dogs, oatmeal, baby food and soup. Do Not place any metal objects or objects than can melt this can cause damage or injury.
Warm Hold: This is to keep foods or drinks warm for any length of time up to 99 minutes and 99 seconds. Although it is not a recommended to run a unit at the maxium time limit.
Melt: This is used to melt butter, margarine, chocolate, cheese and marshmallows. Do not leave these items unattended during the duration of melting time to prevent any unwanted over heating.
Soften: This is used to soften ice cream, butter, cream cheese, and frozen drinks. Do not place anything in a container that is made of foam or metal this can cause damge or injury.
*Child Lock: If your model has this feature it is used to lock the unit to keep a child from pressing buttons or causing injury.
Open: This is the handle or button on the front of the unit to open the unit after the unit is done cooking or in use. Do not open the door during the use, always press the Stop/Clear button first. Also do not remove hot items without oven mits or waiting time food is at a safe handling temperature.
Jan 03, 2011 | LG LMVM2277ST Microwave Oven
Model 31981B Replaced AAA battery's and now it is 3 hours behind
PROGRAM MENU: b> TIME ZONE: Use a pencil or paperclip togently press and release the TIME ZONE button one time. Press and release the PLUS button to choosefrom: PST= Pacific Time MST= Mountain Time CST= Central Time EST= Eastern Time Press and release the SET button to return to a normaldisplay. DAYLIGHT SAVING INDICATOR: The DST indicator isdefaulted to the ON position. If your area does not observe DST please removethe battery cover on the back of the station and move the DST switch to the OFFposition. SET CALENDAR, TIME, 12/24HR & F/C: Press and release the SET button once toenter the program menu. NOTE:Holding a button will move the digits faster. YEAR: The Year will be flashing. Use the PLUS or MINUSbutton to set the Year. Press and release the SET button one time. MONTH/DATE: The Month and Date will beflashing. Use the PLUS or MINUS button to set the Month and Date. Press andrelease the SET button one time. HOUR/MINUTES: The Hour and Minutes will beflashing. Use the PLUS or MINUS button to set the Hour and Minutes. Press andrelease the SET button one time. 12/24-HOUR TIME: 12Hr will be flashing. Use thePLUS or MINUS button to switch to 24-Hour time. Press and release the SETbutton one time. FAHRENHEIT/CELSIUS: The Temperature will beflashing. Use the PLUS or MINUS button to switch from F to C.
Dec 06, 2010 | Equity Time USA Sky Scan 44100 Clock Radio
Where are the timing marks on ford ascape 2001 v6 3.0
On the crankshaft:
Timing Lights There are two basic kinds of timing lights--DC powered timing lights, which operate from your vehicle's battery, and AC powered timing lights, which operate on 110 volt house current. Of the two, the DC light is preferable because it produces more light to see the timing marks in bright daylight. Regardless of what kind is used, the light normally connects in series with the No. 1 spark plug using an adapter. Models that are more expensive sometimes use an inductive pickup, which simply clamps around the plug wire and senses firing impulses. Inexpensive models use alligator clips; one clamps onto the connection between the plug and the plug wire, and the others clamp onto the vehicle battery terminals. NOTE: Some timing lights will not work on electronic ignition systems, so unless you still own a vehicle equipped with points, check to make sure the timing light you buy will work. The biggest problem you will probably have when using a timing light is trying to see the timing marks on the crankshaft pulley. Before you time the engine, mark the appropriate timing indicators with fluorescent paint or chalk. Stay out of direct sunlight when you time the engine and buy a timing light with a xenon light, not a neon light. Timing lights that use a xenon tube provide a much brighter flash than those that use a neon tube do. Fig. 1: A modern electronic timing light. Note the inductive pick-up clamp. 88521p22.jpg
Nov 12, 2010 | 2001 Ford Escape
How to use a Matco Diagnostics Advance Timing Light
Hook it up like any other timing light. The difference is that you can look at the timing mark and turn the dial n the light until the timing mark on the engine is at zero. Whatever the dial read, that is the timing. This is most useful when you want to look at total advance at higher RPM's where the timing gets into 20 or 30 degrees, which is more than is on the timing pointer on the engine. If you want to use it like a regular timing light, just set the dial to zero.
Feb 23, 2010 | 1985 Buick Riviera
the timing light is used only to see if you installed correctly, crank & cam have aero marks make sure when you align those aeros they stay on position when you tight the tension they might move so set it a little off counterclockwise so when you tight it it will come to the right position hope this helps you.
May 26, 2009 | 1986 Plymouth Reliant 4 Door
I don't know who posted that but yes you need to use a timing light. Unplug the coolant temp sensor and set the timing to what the underhood sticker says with a timing light.
Set the time and date on a canon mp25dv/instructions
To set date:
1. Press the calendar/clock button (display should show date)
2. Press and hold the 'time set' button for 3 seconds (first digit of the date should flash)
3. Use the numeric keys to enter date using mmddyyyy format
4. Press 'time set' button
To set time:
1. Press the calendar/clock button twice (display should show time)
2. Press and hold the 'time set' button for 3 seconds (first digit of the time should flash)
3. Use the numeric keys to enter time using hhmm format, press 'AM/PM' button as needed
The '12/24' button changes between 12 hour and 24 hour format for time.
The 'format' button changes the date format from mmddyyyy to ddmmyyyy or yyyymmdd.
Feb 26, 2009 | Canon MP-25DV Calculator
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
