Question about Tappan Microwave Ovens
Tappan microwave, serial TMV151FB, the letter L appears when you press any button, nothing works
5 Suggested Answers
SOURCE: Kitchenaid Microwave kcms145ss - serial no FGR3919211
Buy a new micro......... the front panel just went bye bye
Posted on Oct 17, 2008
  • 244 Answers
SOURCE: have old tappan speedwave 1000.
Unplug the unit for 15 minutes...plug the unit in and try again. If that doesn't work - take the back cover off and look for any blown fuses...should be obvious.
Posted on Nov 30, 2009
  • 6771 Answers
SOURCE: caracell keeps turning and does not heat
There three common causes, open magnetron, cracked high voltage diode developes high resistance short, or a shorted high voltage capacitor.
Posted on Mar 28, 2012
  • 12223 Answers
SOURCE: Tappan microwave vent motor and cooktop lights not working
see this test . God bless youThis microwave oven repair is only for over the range(OTR) models. First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start capacitor. get the part from
Posted on Apr 04, 2013
I have O'Keefe and Merritt stove with attached microwave labeled Tappan FCC ID ABM964To3. The "start" button on the microwave quit working. Can I get this repaired?
I had very old parts for the tappan units but they have been out of circulation for quite some time. Unless this is a new tappan that I am not familar with, Most of those parts are no longer available. The FCC ID does not help, you need a model number of the unit to try to look up parts. A Microwave puts out radio waves and such has to be regulated by the FCC. Federal Comunications Commission. That number wont help find parts for the unit. Sorry
Oct 03, 2017 | Tappan Microwave Ovens
My TMV151FB beeper stopped working. Is it worthwhile fixing it?
if ever thing else works but the beeper I would not worry about that
May 24, 2015 | Tappan Microwave Ovens
When I press the button to open myMicrowave it starts to run. It did this for I week. Today I did the same thing push the bottom to open the door it open but nothing happen meaning no light on or nothing....
There are several switches (usually 3) located and attached to the door latch area of the microwave. One is a safety interlock that keeps the Micro from running with the door open. At first one of the switches were sticking slightly giving you the attempted run. Then enough stuck to cause the safety to sense it. The safety usually will blow the internal fuse or house breaker. If you are going to get it fixed, best to replace all the door switches and then the fuse also. If by chance it still blows the fuse again you have other problems. At this point I think its just the door switches and fuse.
Mar 24, 2015 | Tappan Microwave Ovens
Tappan tmv151fb
Chances are you have a failing bottom door switch, or its mount is loose, misaligned, or broken.
See my help file on door switches:
The service manuals are here: f
You can usually order Tappan parts from the Pros here or contact them via the info no the service manual cover.
Jan 15, 2014 | Microwave Ovens
Caracell keeps turning and does not heat
Mar 27, 2012 | Microwave Ovens
Tappan Convectionaire stove with built in microwave. Purchased in 1985. This is the 4th time the handle on the microwave door has broken off. We were able to replace it in the past, but I cannot find it...
we have the same tappan oven/microwave combination. We are looking for the knobs for this. Its a great oven, but we need these parts. Our microwave handle broke a long time ago and we had one made from wood. If you are going to ditch the old oven would you be willing to sell the knobs?
Aug 25, 2010 | Tappan TMT104E1 Microwave Oven
Have old tappan speedwave 1000. buttons work but when you press start nothing work except the countdown on display
Nov 29, 2009 | Tappan Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Tappan microwave
I think the membrane/button for the number 4 is stuck or broken. Due to the nature of a microwave my advice would be to entrust the work to a competant technician. Hope this helps.
Oct 01, 2008 | Tappan Microwave Ovens
Microwave Ovens Logo
21 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
Mark Gough
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
