Question about The Audio Players & Recorders
When charging what color is supposed to show and is it supposed to show on the USB chargeing indicate ? It won't turn on even switched on and holding power button .. what could be issue .?
SOURCE: battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Posted on Aug 17, 2008
SOURCE: My mp3 won't turn on. At all.
Its the problem with the battery. You will need to change it.
Posted on Apr 27, 2010
SOURCE: Fully Charged Sony NWZ-E436F Doesn't Turn On
did anyone ever get back to you on this? I'm having the same problems.
Posted on Jan 10, 2011
  • 123 Answers
SOURCE: My laptop won't turn on,
Good day. You can try to do these steps which is usually a normal solution to this kind of issue:
1. Take out the battery of your laptop
2. Remove main supply, or power cord
3. Hold power button down for 30 secs,
4. Put only power supply in or power cord
Note: do not put battery in yet
5. Turn laptop on
6. Put the battery in.
If this will not work you might consider contacting toshiba tech support for laptop for other resolution. Hope this information will be helpful in resolving your issue. Thanks for using fixya and have a great day.
Posted on Jun 25, 2011
  • 4 Answers
SOURCE: My rear flea light won't
it might be water damaged return it to bike shop and ask for full replacement under the lifetime warranty
Posted on Sep 28, 2011
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
Apr 20, 2013 | Tablets & eReaders
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
I have an Curtis MPK4099UK MP3 Player. It says to charge it I need to install setup.exe from the CD. After I done that I restarted my computer then I put My MP3 Player on charge,(with the on switch) It...
I had the same problem but have now resolved as follows. Turn the top switch to on and connect via USB port. Picture should come on the mp3 player indicating it is connected. For some reason unknown to me in order to charge you need to turn the MP3 player on - but this is impossible if there is no charge. What you need to do now is leave the MP3 player connected like this overnight - it will then have gained enough charge in the morning so that when you then disconnect the MP3 player from the USB lead you are able to actually turn it on. PLEASE NOTE this is not turning on by the switch at the top. What you do it press and hold the circle/dash symbol i.e. at the bottom of the white keypad bit on the front of the MP3 player. As you then let go it comes on. Let it finish turning itself on, then reconnect to the USB lead and leave over night to get a full charge. Good Luck
Sep 25, 2010 | Curtis MPK2066 MP3 Player
How do I charge my daughters amt mp3 hello kitty clip on. when I plug it into my computer do I turn the player on to charge or keep it off. she was kind enough to lose the directions.
G'Day To charge your AMT mp3 player you must first plug it into your PC USB port using the supplied cable. Next turn on the player using the sliding switch on its side.The indicator shows the battery is charging, but it is not. To make it charge you have to turn the player off. To do this, hold down the "play" button until you get the "Bye-Bye" message. The screen will go black and the battery will now charge. Do not use the slide swich to turn off!...woozie. Australia
Jan 18, 2010 | Audio Players & Recorders
Low battery
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............ Just make sure it is not Locked or On Hold and then try to charge it............. Will Work Fine.......... Goo Luck
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
No power
I am having the exact same problem. I put songs on the MP3 player and it hasn't worked since. I'm not getting any help or support. If you find out what the problem is, please contact me. This is is so disappointing to buy a Xmas present that doesn't work!
itsmesusan@roadrunner.com
Dec 27, 2007 | GPX MW3837 MP3 Player
13 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
chrisheman
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
