Question about Yamaha Electrical Supplies
How do you find the manufacture year of a Yamaha Generator EF6300SDI?
I bounced the "H" out of my generator. When i plug something in it goes straight into overload and quits.
You may have knocked something loose inside. Take off the generator end cover and look for anything obvious. There is nothing to loose at this point.
Jul 22, 2014 | Yamaha 2400is Portable Generator 2400 Watt...
Yamaha EF1000is inverter generator, never tused, won't start
Try searching for a fuel shutoff somewhere near the bottom fuel line exit for the fuel tank on somewhere on the fuel line.
Nov 12, 2017 | Yamaha 1,000 Watt Portable Generator...
Trying too establish what year this motor is it a 2 stroke 80 hp 6hoL450289 yamaha outboard motor.
Try contacting Yamaha direct or a reputable outboard dealers for the address, they will point you in the right direction, like all motors manufactured the makers keep a record of the serial number, i recently tracked this down for a friends Perkins Diesle engine that is running a generator in the middle of Spain, it turns out that his engine came from a 1912 lorry.
Good luck
May 14, 2011 | Computers & Internet
What servicing can I do for my generator which has not been used for 2 years now YAMAHA GENERATOR EC5000DVE
change the spark plug clean the fuel tank replace filters and oil change fuel line if cracking or stiff.
remove carb bowl clean out with carb clean remove any sch-lack from old gas run and test power.
hope this helps
Aug 28, 2010 | Yamaha 4500 Watt Electric Start Generator...
Problem with a ef1000 generator running rough. starts easy, gets to operation rev range, lasts for 5 to 20 sec, then runs rough, changed oil, air filter and plug cleaned carby, made little differance run...
I purchased a Propane Generator from Central Maine Diesel a few years ago.
20 HP Honda engine, Italian generator head.
Paid about $2300 plus shipping via Paradise Freight which was a few hundred.
I see the price is just a bit higher now... But the one I want most is Yuchai which i saw from a website.
Recently it blew a capacitor. Central Maine sent me 2 for the price of one even though it is out of warranty. $39 total for two.
I looked at generators on island but a similar Honda at Quality electric was close to $6000 and it wasn't even a 13750kw. More like 8 or 9000kw if I remember right.....
They have many generators at great prices but this is the one I settled for.
However, it is said that the Cummins generator is more popular than others.
Cummins Generator Cummins Generator Set Supplier and Manufacturer in China
Nov 12, 2017 | Yamaha EF2400iS Portable Generator
Can the ecu memory be flashed on a yamaha EF2800iportable generator? My 2800i will start and run for about 90 seconds and then shuts down. Carb is fine. Two issues: 1. It is not generating...
It sounds like its running on the gas in the carburetor and not the gas filling back up to run more, I bet you have a gas supply problem to the carburetor! Try Babbitts Yamaha Partshouse online...
Mar 12, 2017 | Yamaha 1,000 Watt Portable Generator...
Electrical Supplies Logo
104 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Level 1 Expert
Roland W VanLue
Roland W VanLue
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
