Taipan microwave ovenser# TMV151FB, it starts beeping, when you push one of the buttons the letter L appears, and nothing works
SOURCE: microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Posted on Sep 30, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: wolf - microwave oven not turnin ON
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Nov 09, 2008
  • 3 Answers
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
SOURCE: buttons dont work on danby microwave
I had the same problem, but only with 4 buttons. The 3,6,9 & Start/Stop button stopped working.
Hard reset & leaving unplugged did not work. Eventually, I tried picking it up and dropping it from several inches, and smacking it on the side. That did the trick. Works great now!
Posted on Apr 25, 2010
  • 65 Answers
SOURCE: dryer will not start display
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Posted on Jan 19, 2011
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
We have a BAM2801 Microwave oven that has started to randomly beep and 8's keep coming up on the screen. No other buttons appear to work and we can't stop it beeping. Are you able to provide any...
Ours did exactly the same thing. Fortunately we are still in the warranty period and it is to be replaced, but the 2801 is apparently out of production and we are now in discussions over its replacement. They brought a BAM253TK today, but it is smaller, has fewer features, fewer heat options and has a rotary dial, not push pad and the one they brought had a faulty door opener. I'll see what eventuates!
Dec 12, 2010 | Baumatic BTM24 Microwave Oven
Apr 08, 2009 | Emerson Black Microwave Oven
Ultrex microwave won't start
hi gud day.did u have a manual to check before to try to operate, or u think the item is ok to use in ur country coz some model & brand have a diff in tecnical power,what HSN or ur unit is stock for how many years?sometimes this the coz of the problem.tnx
Feb 02, 2009 | Cooktops
Buttons dont work on danby microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If it still isn;t working I would contact Danby Customer Service US / Canada.
Jan 08, 2009 | Danby DMW1146SS Microwave Oven
Kenmore microwave
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Sep 09, 2008 | Microwave Ovens
Microwave shows F3
Jul 25, 2008 | GE JE1460 Microwave Oven
Microwave will not respond to any button being pushed
The service man just left it was the 20 amp line fuse. Have one on order.
Jun 11, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
