Help! In need your help the DVD/vcr combo I have used to have a picture and audio in hdmi1 mode but now it only has audio and no picture no wires have been moved
  • 1074 Answers
SOURCE: how to hookup dvd.vcr to tv
first of all the the VCR has two connection from the tuner at the back one has out to tv the other has in from antenna you connect the wire from the cable company to the in from connect another from the out to tv to the tuner connnection of your tv.and you are connect the dvd to your tv.the tv has either at the front three female connector basic colors red white and yellow.the red and white is for audio in, left and right, and the yellow is for video in.the dvd has similar connections but they are output just connect them matching them color to color.there are some female connectors on the back of the dvd if you want to use surround sound.or play it through a reciever.good luck.
Posted on Mar 26, 2007
  • 593 Answers
If using 3 color RCA (r/w/y) the red and white is audio and should go into your stereo under video or AUX. The yellow is the only video cable you need, that should go to your TV aux in or video1 or video2. You can also put all 3 colors into the tv and then run another red/white OUT to the stereo AUX in and have stereo sound for whatever you are watching.
Posted on Feb 28, 2008
  • 547 Answers
SOURCE: Need code for Emerson TV,DVD,VCR Combo
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Posted on Feb 12, 2009
called comcast
Posted on May 28, 2009
SOURCE: I NEED A MANUAL FOR A DAEWOO DF4150p dvd recorder/ vcr combo please help
go to Daewoo website and download it
Posted on Aug 07, 2009
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
Using your DVD-V4600, how do you play a vhs tape on TV? Need step by step instructions.
In order to watch either DVD or VHS on your TV ,you need to make the following connections ..
  • You need to connect "DVD Player / VCR Combo" to" TV " as (Audio/video output of DVD Player / VCR Combo -TO- Audio/Video input of TV) ..
  • use either "RCA analog (red/white +yellow ) " or "SCART "or "Optic " cable.(any standard optical cable )...if exist ,optic is the best way to connect it..Remember your DVD Player / VCR Combo 's "OUT" goes into" IN "of the TV ..
  • pls also remember,wherever you connect your DVD Player / VCR Combo on your TV ,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Jun 30, 2011 | Samsung DVD-V4600 DVD Player/VCR
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
Magnavox zv427mg9 sound problem - VCR/DVD combo connected to a Vizio VW42LFHD TV. After some playing around we got the DVD running OK. We can see video and hear the audio. However, the VCR does not play...
sr you can disconect hdmi cable and use a litle speaker and check for audio in rca cables output , when you put your vcr play you can have audio in rca red cable and rca white cable i think when you put hdmi your loose in rca the audio , remember in hdmi you have audio and video , if you dont have audio in vcr the audio head are bad thias is used only in vcr mode. good luck
Jul 08, 2009 | Televison & Video
How do i/can i record tv to a DVD ]
If your using RCA cables (thats the red, white & yellow leads) you need run yellow RCA from the 'VIDEO (or) TV OUTPUT' at the back of your tv, to the 'VIDEO (or) TV INPUT' in the back of your DVD/VCR combo unit, & do the same with the red & white 'AUDIO' leads only run them from AUDIO OUTPUT(tv) to AUDIO INPUT(dvdrecorder). Now set the mode of the dvd recorder to TV IN or AUX IN. Now it should record whatever you see on the tv screen. But if your tv has an S VIDEO OUTPUT option, using an S VIDEO cable would be much easier & produces a better copy! Hope this helps!
Jun 19, 2009 | Symphonic WF803 DVD Player/VCR
Problems with Sansui VRDVD4005 DVD Player / VCR Combo.
the only problem i have is the remote reciever works only part time. I bought aa new remote control but didn't help.what do you think the problem is.
Mar 02, 2009 | Sansui VRDVD4005 DVD Player/VCR
I want to record a dvd from my tv/dvd/vcr combo to an external vcr. i'm not trying to break any laws, it's only for my babygirls personal enjoyment. please tell me how the wires should be
as long as you're not breaking any laws you can connect the video/audio output of your combo unit to the video/audio input of your vcr using audio/video rca cables where the yellow plug goes to the video input/output and the red plug to the right audio and the white to the left audio input/output.
Oct 16, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Only works when playing a DVD.
This is an easy and quick fix.
What you will need:
RCA cables (audio)
( possibly Line out converter )
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
Feb 19, 2008 | Durabrand STS92 System
Hooking up a DVD player to a Quasar TV/VCR Combo
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Quasar VV-1302 13 in. TV/VCR Combo
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
