Question about Celestron Optics
Celestron Astro Fi, please can you help why the scope control is not working properly, it is keep moving on its own ? winnie
5 Suggested Answers
SOURCE: I have a CPC11GPS telescope that was working the
The clutch is not engaging in RA. Maybe the gears are not actually meshing together? A loose worm gear?
You can open it up and look and see if anything obvious is loose. Otherwise it's a trip back to Celestron.
Posted on Dec 04, 2009
SOURCE: Celestron Nexstar 114gt telescope,hand controller lights up only
Do you have a fresh set of batteries in the scope? Better to use an outside 12 volt power pack with the Celestron 12 volt "cigarette" lighter cable.
This can be three things:
Low power
Bad cable from hand controller to scope.
Or a broken hand controller
Try fresh batteries first.
Posted on Dec 31, 2009
Wallwart
SOURCE: Celestron CPC 800 frozen display in the Hand Controller
The power cable is the problem. The connector is loose fitting, and the cable is long and high resistance. Combined, these two things result in a significant voltage drop when slewing both motors. Replace the power cable with bigger wire, and tape the power plug down in the socket so it can't move. The other suggestion may help as well.
Posted on Jul 16, 2010
Not able to see anything would like how to use cerlestron EQ 114
This is a small reflector style telescope on an equatorial mount. The mount and tripod must be polar aligned in order to be used. Read this:
http://arnholm.org/astro/polar_alignment/index.html
Simply pt the eyepiece with the largest number written on it into the telescope, take the scope outside during the day time and practice focusing on a distant object like a building.
Celestron's manuals are located on this web site-- find your scope and download one for free:
http://www.celestron.com/c3/downloads.php
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Aug 13, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
The hand control isn't working properly. Haven't used the telescope for 12 months. I have replaced the batteries. When I try to align to a star or other object, the direction buttons only work in one...
First thing to do is to buy a new hand controller cable from Meade, If this does not correct the problem then either the hand controller is defective, or something is broken inside the scope.
Cables are not expensive, call Celestron:
http://www.celestron.com/c3/page.php?PageID=37
Jan 23, 2011 | Celestron NexStar 130SLT (31145) (306 x...
I bought a used nexstar 130 Gt. The hand controller lights up and will move the scope, but will not display any information . Can this be fixed or do I have to get a new one? Thanks Lenny
First do a RESET on the hand controller --- also the b. Some of these scopes have a brightest adjustment.===rightness and contrast may be set too high.
The problem will be navigating the menu tree without seeing anything-- the menu tree is shown in the manual try to get to the reset by "touch". or to the contrast by touch.
Contact Celestron here is you continue to have issues with this:
Jan 21, 2011 | Celestron NexStar 130GT (306 x 130mm)...
I just bought an Optus 553 telescope and the instructions are not in English. Where can I get operating manual and set-up instructions please? I live in Spain.
Sorry, but that is NOT a major brand of telescope like Skywatcher, Meade, Celestron, Astro Physics, and so forth.
You will not find a manual anywhere. Try to locate a local Astronomy club and get the members to help you with the scope. Most clubs welcome new members and will help them.
Sep 02, 2010 | Optics
Celestron 114EQ polar setting and Equatorial settings
The ALTITUDE adjustment matches your LATITUDE. I live at 32.5 degrees North latitude. So the scope is first adjusted to 32.5 degrees UP.
Then the Right Ascension is point to Polaris the North star by MOVING the entire scope and mount.
Read my Equatorial mount TIP on my profile page, and read this web site.
http://www.astro-tom.com/tips_and_advice/precision_polar_alignment.htm#Rough%20Polar%20Alignment
May 05, 2010 | Celestron PowerSeeker 114 EQ Telescope
Celestron advanced gt declination motor does not working
You did tighten the clutches?
If you did the DEC gears are either loose and not meshing or have broken.
Dr. Clay in Arkansas can repair this scope but it would cost several hundred dollars-- Celestron will probably sell you the parts to fix it. Here is their web site. You can also return the mount to them for repair.
http://www.celestron.com/c3/support3/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=1790&nav=0,220
Mar 13, 2010 | Celestron Optics
Low power
Dec 31, 2009 | Celestron Optics
I have a CPC11GPS telescope that was working the last time I used it, which was 6 months ago. It is in NEW NEW condition. I pulled it out last night, turned it on, allowed the system to align itself using...
Dec 04, 2009 | Celestron Optics
Problem with Celestron Starseeker 100mm refractor
Could be several different mechanical or electronic issues with the scope.
From a dirty encoder disk inside to a bad motor clutch.
Best to return it to Celestron for repair.
Jul 01, 2009 | Orion Celestron StarSeeker 100mm GoTo...
GoTo Problem
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
Apr 06, 2008 | Celestron NexStar 130 SLT (306 x 130mm)...
Optics Logo
43 people viewed this question
Top Celestron Optics Experts
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
