Question about The Computers & Internet
I read on line about a head gasket repair sealer that you order on line and it was guaranteed or the people will refund your money ,I just can't remember the name or how to get to info. To order it
It said in reviews that you could call the company and a mechanic would talk you threw using it right
jusus
  • 57 Answers
SOURCE: Refund money back to Best Buy credit card
If I were you I would call best buy direct.They are in better position to answer your question.
Good Luck
Posted on Jul 24, 2008
  • 68 Answers
SOURCE: Craftsman 3.5 hp portable air compressor keeps blowin head gasket
I would say the head or block is warped. Use Majic Marker to cover the mating surfaces , the head can be rubbed on a flat surface like a cast iron table saw to find the high spots, or the head can be rubbed on the block.
Careful work with a good flat file will remove the high spots.
The torque value sounds low even for an aluminum block, you could check with a small engine shop to get their opinion.
Posted on Apr 25, 2009
juggernautxt
  • 145 Answers
SOURCE: blown head gasket .... ran the car hot
sealers usually end up costing you more in the long term than the short term. these sealers react to heat and air. so you end up doing nothing more than plugging up you radiator, water passage ports, water pumps get damaged. causing more over heating problems than they solve. no i would go for what the shop gave you as a quote. that seems a pretty reasonable quote for the position you are in.
Posted on May 07, 2009
  • 462 Answers
SOURCE: my 06 hyundai elantra is in the shop right now for
Major service means tune up and timing belt.
Look up your owner manual , there is a service schedule section , you'll find what needs to be done at 60k on your car , but in any case it shouldn't add up much more cost sience engine all apart,
And as for the timing belt (if you have one) , they have to replace it anyway , because when you do a head gasket , you take timing belt out.
Posted on Jul 20, 2010
Testimonial: "THANK YOU FOR YOUR RESPONSE!"
  • 4350 Answers
SOURCE: My 24 hp Briggs v
There is no sealer that will resolve a head gasket issue, if that is what you have going on. and, if the head gasket failed remember it is a victim and not the cause, something else in happening.
I suspect that you have a compression related failure, based on the oil consumption and the smoke is probably blow by. This issue requires surgery to diagnose and fix.
Posted on Oct 11, 2010
How to fix a head gasket leak?
Hello Mark
The only real correct way to repair a leaking head gasket is to remove
the head and replace the gasket, and at the same time have the head checked for cracks, flatness, valves checked etc. at the same time replacing other parts that are worn out that just don't make since to reinstall back on the engine. All of this means big money out of your pocket :o(
Now if you were just looking for a short fix they have engine sealer in a can at most auto stores you can buy that might buy you a little more time, but you better figure out what you plan to do fast if it does seal because it will most likely be short lived.
Good luck and be safe.
Mark / aka RagenRat
Amazon com BlueDevil Pour Go Head Gasket Sealer 16 Ounce Automotive
May 12, 2014 | Cars & Trucks
Does that dura-seal head gasket repair stuff REALLY work?
I had a blow head gasket on my BMW 6 cyl. and it was blowing white smoke and losing alot of coolant. After doing alot of research I found that all the other brands like blue devil, steel seal, KW and bars all use water-glass. The only company that does NOT USE WATER-GLASS is Dura-Seal. If you have aluminum heads it's very important to use a sealer that can flex with your engine's aluminum heads. The DuraSeal actually stays flexible! So I tried it and it stopped the smoke and overheating. No more coolant loss either. It's been running fine for over a year now. I would reccomend Dura Seal head gasket sealer to everyone... Great product! Also the tech department guys really know what they are talking about...
Apr 25, 2012 | 1999 Cadillac DeVille
A relative of mine let her Jeep Cherokee freeze. It got the radiator but seemed to run ok. Now its steaming some out the exhaust like it got the head or gasket. It not worth doing a head job on. Is there...
I may be the head or head gasket, but the intake gasket can do the same thing and much easier and cheaper to try.
I would remove all the spark plugs and use the tool to presurize the radiator. I would then wait at least an hour with 10 lbs of pressure on the system. Then turn it over withe the staster to see if water comes out a plug hole. Hopefully you will find it leaking at the rear of the intake manifold.
If it will not hold 10psi for the hour, it must be leaking somewhere.
Hope this helps, ROBERT
Mar 08, 2011 | 1999 Jeep Grand Cherokee
BLOWN HEADGASKET- Gasket Sealers? I have heard that there are a few additives that work to fix a blown head gasket. Mechanics seem to like "BLUE DEVIL." One stated that he has used the product...
My personal experiences with gasket sealers for Head gaskets has been very poor due to the fact that it's difficult for the sealer to stick in the leak when there's so much combustion pressure trying to push the sealant out of the leak on one side and only about 17 psi of coolant pressure trying to keep it in from the other side. On both a 2.0L or a 2.4L engine I would suggest having the head removed and inspected and the gasket replaced....then your problem is fixed and done. Sealants may work for a while but I view them as a temporary band aid approach at best. If you have over 100,000 miles on the engine and haven't yet replaced the timing belt then it would be a good time to do that also as a worn timing belt can cause some pretty severe engine damage should it fail. Hope this helps and good luck!
Feb 20, 2011 | 1996 Dodge Intrepid
Chev s10 1998 over heating water in oil can i do a quick fix with gasket sealer an still drive truck until i can afford to replace gaskets
Over the years I have seen quite a number of sealers advertised to repair gaskets etc. There are newer ones out that make the same claims (also expensive @ about $100). Though it is possible that they work, I have no idea for how long. As always, the best cure for a cylinder head gasket problem is still to actually do the repair.
Regardless of how you correct the problem, make certain that you drain the oil and filter or you will be looking at a bearing failure shortly.
Feb 04, 2011 | Chevrolet S 10 Cars & Trucks
How to fix leaking air from top of gun
If this unit is new to you, return it for replacement or refund. If the repair is up to you, remove the head (top) of the gun and check the seal (either an 'O' ring or gasket) for damage. Check the head itself for damage or warping of the seal face. Try placing a small ring of Permatex silicon gasket sealer on the head, let cure for a little while until it sets-up, and reinstall the head. Tighten the screws evenly and firmly. Hope this helps!
Apr 02, 2010 | Stanley Factory Reconditioned Bostitch...
Broken head gasket leaking anti-freeze
hi you sure it is the head gasket
i have done alot of 3.4 head gaskets but NEVER THAT DESIGN 3.4
just make sure before you spend unnessary money that may not fix your problem
Nov 30, 2009 | 2005 Chevrolet Equinox
Blown Head Gasket and Steel Seal
ok for cracked block in conjuntion with a coolant sealer but not for much else
Jun 21, 2009 | 2003 Ford Taurus
Oil Leak after head gasket repair
If u now have an oil leak that was not there before the repair of course they should have a look for free and show u what the problem is, and from what u say fix it for free as well, stand by your guns, if they give u the song and dance be nice but insistent.
Mar 09, 2009 | 1997 Dodge Ram 1500 Club Cab
Computers & Internet Logo
18 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
