Question about GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
VvMy GE Spacemaker XL 1800 was working fine and then it just stopped working. I checked the circuit breaker and it is on. This is a JVM1850CF001
  • 67 Answers
Check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Posted on Jul 25, 2009
I have a microwave GE spacemaker XL 1800 that stopped working. None of the touch control panel buttons work. Is like death. Is it a fuse? if so how expensive is it?
probably fryed the magnetron, with something like foil or metallic, try unplugging it for 12 hours maybe it will reset if not throw it out
Jan 28, 2014 | GE Profile Spacemaker XL 1800 36 in....
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
Ge profile space maker xl 1800 shut down during cooking
Unplug unit..reset circuit breakers..check agin and then see if it starts up. It may need drying out due to excess steam
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table does not work. How do you fix it? I have a GE Spacemaker XL 1800, Model # JVM1842BD. Thank You
i have a ge 1800 model and it cooks fine but after awhile it shuts down and in about a hour it comes back on and ask you to set the clock.....
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE Spacemaker XL 1800 microwave's controls are locked
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
We have a GE Profile Spacemaker XL 1800. It began making a laboring noise and stopped cooking at the same time.
Sounds like the Magnatron or the HV Cap or diode is failed. Process of will show you which one. Very dangerous area to work in, not for the untrained. Eric
Aug 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,452 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
